  3. About DS18B20 onewire.
dallasone wireonewireds18b20
48 Posts 5 Posters 19.1k Views 10 Watching
    @pepson yes. Just change the present call, just like in your sketch.
    Example: change
    present(i, S_HEATER);
    to
    present(i, S_HEATER, "Description goes here");
    pepsonP
    pepsonP
    pepson
    @mfalkvidd Can you help me... or change it ?
    • F flopp
       * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
       * http://www.mysensors.org/build/temp
      #define MY_NODE_ID 14
      #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
      #define ATTACHED_DS18B20 40
      unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
      byte D[ATTACHED_DS18B20][8] = {
      { 0x10, 0x04, 0xB8, 0x3F, 0x02, 0x08, 0x00, 0xBD }, //KökTbx
      { 0x10, 0xF4, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0xB1 }, //UppTbx
      { 0x10, 0x92, 0x9F, 0x3E, 0x02, 0x08, 0x00, 0x98 }, //KökUt
      { 0x10, 0x4E, 0xE4, 0x3E, 0x02, 0x08, 0x00, 0x3C }, //ToaUt
      { 0x10, 0x1E, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x33 }, //EfterPump
      { 0x10, 0x09, 0xA1, 0x3E, 0x02, 0x08, 0x00, 0xF7 }, //HallTbx
      { 0x10, 0x59, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xFA }, //UppUt
      { 0x10, 0x07, 0x1B, 0x3F, 0x02, 0x08, 0x00, 0x99 }, //ToaTbx
      { 0x28, 0xFF, 0xB1, 0xAA, 0x63, 0x15, 0x03, 0xC8 }, //Kök
      { 0x10, 0x80, 0xB6, 0x3F, 0x02, 0x08, 0x00, 0x29 }, //Panna komp
      { 0x10, 0x3C, 0x9C, 0x3E, 0x02, 0x08, 0x00, 0x99 }, //Hall ut
      { 0x10, 0x42, 0xE0, 0x3F, 0x02, 0x08, 0x00, 0xD1 }, //Tvätt
      { 0x10, 0xCE, 0xE9, 0x3E, 0x02, 0x08, 0x00, 0x3A }, //T12
      { 0x10, 0x99, 0xAC, 0x3F, 0x02, 0x08, 0x00, 0x25 }, //V mellan
      { 0x10, 0x15, 0xDB, 0x3E, 0x02, 0x08, 0x00, 0x01 }, //Hallen
      { 0x10, 0xF3, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0x34 }, //Panna El
      { 0x10, 0xFB, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xC8 }, //Toa Nere
      { 0x10, 0x97, 0x23, 0x3F, 0x02, 0x08, 0x00, 0x92 }, //Varmvatten
      { 0x10, 0x0F, 0xE6, 0x3E, 0x02, 0x08, 0x00, 0xFD }, //Carport
      { 0x10, 0xF3, 0xC6, 0x3F, 0x02, 0x08, 0x00, 0x85 }, //Förrådet
      { 0x10, 0x9C, 0x3B, 0x52, 0x02, 0x08, 0x00, 0x25 }, //Mark 60
      { 0x10, 0xF2, 0x24, 0x3F, 0x02, 0x08, 0x00, 0xEB }, //Vrum V
      { 0x10, 0x6A, 0x5E, 0x52, 0x02, 0x08, 0x00, 0x26 }, //Mark 30
      { 0x10, 0x76, 0xCE, 0x3F, 0x02, 0x08, 0x00, 0xBA }, //Plattan
      { 0x10, 0x0E, 0x7B, 0x13, 0x02, 0x08, 0x00, 0x7C }, //Utetemp
      { 0x10, 0xEE, 0xEB, 0x3E, 0x02, 0x08, 0x00, 0x0F }, //Uterum
      { 0x28, 0x8C, 0x2D, 0xB4, 0x04, 0x00, 0x00, 0x9C }, //Kyl uppe
      { 0x28, 0xFF, 0xB2, 0x74, 0x63, 0x15, 0x02, 0xCC }, //Kyl mitten
      { 0x28, 0xFF, 0x08, 0x07, 0x52, 0x04, 0x00, 0xFF }, //Kyl nere
      { 0x28, 0xFF, 0xE6, 0x06, 0x52, 0x04, 0x00, 0x08 }, //Frys uppe
      { 0x28, 0xFF, 0xB4, 0x07, 0x55, 0x04, 0x00, 0xEB }, //Kyl bakom
      { 0x10, 0x1C, 0xA8, 0x3F, 0x02, 0x08, 0x00, 0x3B }, //Lucas
      { 0x10, 0x83, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x06 }, //Allrum
      { 0x10, 0xA3, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x7E }, //Theo
      { 0x10, 0x33, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x01 }, //Sovrum
      { 0x28, 0xFF, 0xFB, 0x3D, 0xC3, 0x16, 0x03, 0x58 }, //Panna luft in(varm)
      { 0x28, 0xFF, 0xD4, 0x1C, 0x00, 0x17, 0x03, 0x43 }, //Dränering
      { 0x28, 0xFF, 0x97, 0x11, 0x01, 0x15, 0x04, 0xC0 } // Poolvatten
      float lastTemperature[ATTACHED_DS18B20];
      MyMessage msg(0,V_TEMP);
      MyMessage heat(0,V_STATUS);
        sensors.begin();
      void presentation() {
        sendSketchInfo("OneWire Temp+Heating LED", "20180709");
        //numSensors = sensors.getDeviceCount();
        for (int i=0; i<ATTACHED_DS18B20; i++) {
           present(i, S_TEMP);
        for (int i=ATTACHED_DS18B20; i<ATTACHED_DS18B20+5; i++) {
        sleep(conversionTime);
        //Serial.println(sensors.getResolution(D[i]), DEC);
       //   float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
            float temperature = sensors.getTempC(D[i]);
          #if COMPARE_TEMP == 1
          #else
          if (temperature != -127.00 && temperature <= 85.00) {
            send(msg.setSensor(i).set(temperature,1));
         for (int i=0; i<5;i++){
          int value = analogRead(i);
          /*Serial.print("Pin");
          Serial.print(i);
          Serial.print("=");
          Serial.println(value);
          int j=i+ATTACHED_DS18B20;
          if (value>150) {
            send(heat.setSensor(j).set(1));
          else {
            send(heat.setSensor(j).set(0));
        sleep(SLEEP_TIME);
      pepsonP
      pepsonP
      pepson
      @flopp said in About DS18B20 onewire.:
        sensors.begin();
           present(i, S_TEMP);
          #else
          Serial.print(i);
          Serial.print("=");
          if (value>150) {
          else {
        sleep(SLEEP_TIME);
      When i try compile this sketch it get me error:
      C:\Users\Piotrek\Desktop\Temp dallas\Arduino_dallas_18B20_with_desc\Arduino_dallas_18B20_with_desc.ino: In function 'void presentation()':
      Arduino_dallas_18B20_with_desc:117:3: error: expected initializer before 'sensors'
      exit status 1
      • pepsonP pepson
          sensors.begin();
             present(i, S_TEMP);
            #else
            Serial.print(i);
            Serial.print("=");
            if (value>150) {
            else {
          sleep(SLEEP_TIME);
        exit status 1
        #43
        @pepson you have a stray } after setWaitForConversion
        Tip: use ctrl+t in the editor to easier see this type of mistake
        pepsonP 1 Reply Last reply
          pepsonP
          pepsonP
          pepson
          @mfalkvidd
          Still is problem after use CTRL+T
             The MySensors Arduino library handles the wireless radio link and protocol
             between your home built sensors/actuators and HA controller of choice.
             The sensors forms a self healing radio network with optional repeaters. Each
             repeater and gateway builds a routing tables in EEPROM which keeps track of the
             network topology allowing messages to be routed to nodes.
             Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
             Copyright (C) 2013-2015 Sensnology AB
             Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
             Documentation: http://www.mysensors.org
             Support Forum: http://forum.mysensors.org
             This program is free software; you can redistribute it and/or
             modify it under the terms of the GNU General Public License
             version 2 as published by the Free Software Foundation.
             DESCRIPTION
          #define MY_GATEWAY_SERIAL
          MyMessage msg(0, V_TEMP);
          MyMessage heat(0, V_STATUS);
            sensors.begin();
            for (int i = 0; i < ATTACHED_DS18B20; i++) {
              present(i, S_TEMP);
            for (int i = ATTACHED_DS18B20; i < ATTACHED_DS18B20 + 5; i++) {
          #else
                send(msg.setSensor(i).set(temperature, 1));
                lastTemperature[i] = temperature;
            for (int i = 0; i < 5; i++) {
                Serial.print(i);
                Serial.print("=");
              int j = i + ATTACHED_DS18B20;
              if (value > 150) {
              else {
            sleep(SLEEP_TIME);
          exit status 1
          • pepsonP pepson
            @mfalkvidd
               DESCRIPTION
              sensors.begin();
                present(i, S_TEMP);
            #else
                  Serial.print(i);
                  Serial.print("=");
                if (value > 150) {
                else {
              sleep(SLEEP_TIME);
            exit status 1
            @pepson you’re missing a } before start of loop.
              pepsonP
              pepsonP
              pepson
              @mfalkvidd
              Where ? please show me more.... :( i am beginner
              • pepsonP pepson
                @mfalkvidd
                pepsonP
                pepsonP
                pepson
                @pepson ok fixed it :)
                • pepsonP
                  pepsonP
                  pepson
                  But.... Can you also help me to add to this sketch option to send to example to Home Assistant also DESCRIPTION to each sensors ? And description will be get from sketch from name about address sensor ?
                  As in this sketch which i have for relay:
                  #define USE_EXPANDER
                  //#define MY_DEBUG
                  #include <Bounce2.h>
                  #ifdef USE_EXPANDER
                    #include <Wire.h>    // Required for I2C communication
                    #include "PCF8574.h"
                    uint8_t expanderAddresses[] = {0x20};
                    const int numberOfExpanders = sizeof(expanderAddresses);
                    PCF8574 expander[numberOfExpanders];
                    #define E(expanderNo, ExpanderPin) (((expanderNo+1)<<8) | (ExpanderPin))
                  // No Button Constant
                  #define NOB -1
                  #define MULTI_RELAY_VERSION 9
                  #define RELAY_STATE_STORAGE 1
                  const uint8_t RELAY_TRIGGER_LOW  = 0;
                  const uint8_t RELAY_TRIGGER_HIGH = 1;
                  const uint8_t RELAY_STARTUP_ON   = 2;
                  const uint8_t RELAY_STARTUP_OFF  = 4;
                  const uint8_t RELAY_STARTUP_MASK = RELAY_STARTUP_ON | RELAY_STARTUP_OFF;
                  enum ButtonType {
                    MONO_STABLE = 0,
                    BI_STABLE = 1,
                    DING_DONG = 2 // HIGH state immediatly after push, LOW state after release
                  typedef struct {
                    int sensorId;
                    int relay;
                    int button;
                    uint8_t relayOptions;
                    ButtonType buttonType;
                    const char * relayDescription;
                  } RelayButton;
                  // CONFIGURE ONLY THIS ARRAY!
                  // Row params: sensor ID - sensor ID reported on MySensor Gateway
                  //             relay pin - Expander supported
                  //             button pin - <0 for virtual buttons (only available in MySensor Gateway); no support for Expander
                  //             relay options - [RELAY_TRIGGER_LOW|RELAY_TRIGGER_HIGH] {RELAY_STARTUP_ON|RELAY_STARTUP_OFF}
                  //             button type - [MONO_STABLE|BI_STABLE|DING_DONG]
                  //             relay description - reported on MySensor Gateway, can help identify device on initial configuration in Home Automation App, can be empty ("")
                  RelayButton myRelayButtons[] = {
                    {0, 2, A0, RELAY_TRIGGER_LOW, MONO_STABLE, "Ł2 - kinkiet [C10]"},  // WŁ: Ł2
                    {1, 16, A1, RELAY_TRIGGER_LOW, BI_STABLE, "Salon 2 [A9]"},  // WŁ: Salon 2
                    {2, 15, A2, RELAY_TRIGGER_LOW, BI_STABLE, "Salon 1 [A10]"},  // WŁ: Salon 1
                    {3, E(0,1), A3, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, BI_STABLE, "Halogen - Taras [B8]"},  // WŁ: Taras
                    {4, 22, A4, RELAY_TRIGGER_LOW, BI_STABLE, "Kuchnia [B2]"},  // WŁ: Kuchnia 1
                    {5, 23, A5, RELAY_TRIGGER_LOW, BI_STABLE, "Kuchnia - Kinkiet [B3]"},  // WŁ: Kuchnia 2
                    {6, 28, A6, RELAY_TRIGGER_LOW, BI_STABLE, "Jadalnia 2 [A4]"},  // WŁ: Hall I/Jadalnia prawy
                    {17, 17, A7, RELAY_TRIGGER_LOW, BI_STABLE, "Ł1 - Kinkiet [A11]"},  // WŁ: Hall I/Ł1 prawy
                    {8, 31, A8, RELAY_TRIGGER_LOW, MONO_STABLE, "Garaż [A7]"},  // WŁ: Kotłownia/Garaż
                    {8, 31, A9, RELAY_TRIGGER_LOW, MONO_STABLE, "Garaż [A7]"},  // WŁ: Garaż
                    {10, 14, A10, RELAY_TRIGGER_LOW | RELAY_STARTUP_ON, BI_STABLE, "Halogen - wejście [B4]"},  // WŁ: Drzwi wejściowe
                    {11, E(0,7), A11, RELAY_TRIGGER_LOW, DING_DONG, "Dzwonek [?]"},  // WŁ: Dzwonek
                    {12, 29, A12, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 1 [A5]"},  // WŁ: Hall I/Jadalnia lewy
                    {12, 29, A13, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 1 [A5]"},  // WŁ: Hall I/Wiatrołap
                    {14, 32, A14, RELAY_TRIGGER_LOW, BI_STABLE, "Wiatrołap [A8]"},  // WŁ: Wiatrołap/Hall I
                    {15, 19, A15, RELAY_TRIGGER_LOW, MONO_STABLE, "Kotłownia [B1]"},  // WŁ: Kotłownia/Hall I
                    {16, 24, 53, RELAY_TRIGGER_LOW, BI_STABLE, "Ł1 - Taśma LED [C1]"},  // WŁ: Hall I/Ł1 środek
                    {17, 17, 52, RELAY_TRIGGER_LOW, MONO_STABLE, "Ł1 - Kinkiet [A11]"},  // WŁ: Ł1
                    {18, 18, 51, RELAY_TRIGGER_LOW, BI_STABLE, "Ł1 [A12]"},  // WŁ: Hall I/Ł1 lewy
                    {19, 6, 50, RELAY_TRIGGER_LOW, BI_STABLE, "Klatka Schodowa [B7]"},  // WŁ: Hall I/Schody 1
                    {12, 29, 49, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 1 [A5]"},  // WŁ: Hall I/Schody 2
                    {21, 26, 48, RELAY_TRIGGER_LOW, BI_STABLE, "Gabinet [A2]"},  // WŁ: Gabinet
                    {22, 7, 47, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 2 [B5]"},  // WŁ: Hall II/Schody 1
                    {19, 6, 46, RELAY_TRIGGER_LOW, BI_STABLE, "Klatka Schodowa [B7]"},  // WŁ: Hall II/Schody 2
                    {24, 10, 45, RELAY_TRIGGER_LOW, BI_STABLE, "Garderoba [C12]"},  // WŁ: Garderoba
                    {25, 4, 44, RELAY_TRIGGER_LOW, MONO_STABLE, "Pok. nad kuchnią 2 [B10]"},  // WŁ: Pok. nad kuchnią 2
                    {26, 5, 43, RELAY_TRIGGER_LOW, BI_STABLE, "Pok. nad kuchnią 1 [B9]"},  // WŁ: Pok. nad kuchnią 1
                    {27, 8, 42, RELAY_TRIGGER_LOW, BI_STABLE, "Pok. nad salonem 2 [B12]"},  // WŁ: Pok. nad salonem 2
                    {28, 9, 41, RELAY_TRIGGER_LOW, MONO_STABLE, "Pok. nad salonem 1 [B11]"},  // WŁ: Pok. nad salonem 1
                    {29, 3, 40, RELAY_TRIGGER_LOW, BI_STABLE, "Ł2 [C7]"},  // WŁ: Hall II/Ł2 1
                    {30, E(0,3), 39, RELAY_TRIGGER_LOW, BI_STABLE, "Ł2 - Taśma LED [?]"},  // WŁ: Hall II/Ł2 2
                    {22, 7, 38, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 2 [B5]"},  // WŁ: Hall II/Sypialnia
                    {32, 11, 37, RELAY_TRIGGER_LOW, BI_STABLE, "Sypialnia 2 [C9]"},  // WŁ: Sypialnia 2
                    {33, 12, 36, RELAY_TRIGGER_LOW, BI_STABLE, "Sypialnia 1 [C8]"},  // WŁ: Sypialnia 1
                    {34, 25, -1, RELAY_TRIGGER_LOW | RELAY_STARTUP_ON, MONO_STABLE, "Halogen - Garaż [A1]"},  // WŁ: Virtual Button 1
                    {35, 30, -2, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, "Ł1 - Wentylator [A3]"},  // WŁ: Virtual Button 2
                    {36, E(0,2), -3, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, "Halogen - wschód [B6]"},  // WŁ: Virtual Button 3
                    {37, E(0,4), -4, RELAY_TRIGGER_LOW, MONO_STABLE, "Lampki schodowe [C6]"},  // WŁ: Virtual Button 4
                    {38, E(0,5), -5, RELAY_TRIGGER_LOW, MONO_STABLE, "Lampki podłogowe I [C4]"},  // WŁ: Virtual Button 5
                    {39, E(0,6), -6, RELAY_TRIGGER_LOW, MONO_STABLE, "Lampki podłogowe II [C2]"},  // WŁ: Virtual Button 6
                    {40, E(0,0), -7, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, "Ł2 - wentylator [C11]"},  // WŁ: Virtual Button 7
                  const int numberOfRelayButtons = sizeof(myRelayButtons) / sizeof(RelayButton);
                  typedef struct {
                    int firstButton;
                    int nextButton;
                  } RelayMultiButtons;
                  RelayMultiButtons relayMultiButtons[numberOfRelayButtons];
                  uint8_t myRelayState[numberOfRelayButtons];
                  // MySensors - Sending Data
                  // To send data you have to create a MyMessage container to hold the information.
                  MyMessage msgs[numberOfRelayButtons];
                  Bounce myButtonDebouncer[numberOfRelayButtons];
                  //Function Declaration
                  uint8_t loadRelayState(int relayNum, uint8_t forceEeprom = 0);
                  void saveRelayState(int relayNum, uint8_t state, uint8_t useEeprom);
                  void saveRelayState(int relayNum, uint8_t state);
                  void changeRelayState(int relayNum, uint8_t relayState);
                  // MySensors - This will execute before MySensors starts up
                  void before() {
                    Serial.begin(115200);
                    #ifdef USE_EXPANDER
                      /* Start I2C bus and PCF8574 instance */
                      for(int i = 0; i < numberOfExpanders; i++) {
                        expander[i].begin(expanderAddresses[i]);
                    // initialize multiple buttons list structure
                    for (int i = 0; i < numberOfRelayButtons; i++) {
                      relayMultiButtons[i].firstButton = -1;
                      relayMultiButtons[i].nextButton = -1;
                    // find multiple buttons for the same relay (uni-directional list)
                    for (int i = 0; i < numberOfRelayButtons-1; i++) {
                      if (relayMultiButtons[i].firstButton == -1) {
                        int prevRelayButton = i;
                        for (int j = i+1; j < numberOfRelayButtons; j++) {
                          if (myRelayButtons[i].relay == myRelayButtons[j].relay) {
                            relayMultiButtons[prevRelayButton].firstButton = i;
                            relayMultiButtons[prevRelayButton].nextButton = j;
                            relayMultiButtons[j].firstButton = i;
                            prevRelayButton = j;
                    // if version has changed, reset state of all relays
                    int versionChangeResetState = (MULTI_RELAY_VERSION == loadState(0) ) ? 0 : 1;
                      // if this relay has multiple buttons, load only first
                      if (relayMultiButtons[i].firstButton == -1 || relayMultiButtons[i].firstButton == i) {
                        #ifdef USE_EXPANDER
                          if ( myRelayButtons[i].relay & 0xff00 ) {
                            // EXPANDER
                            int expanderNo = (myRelayButtons[i].relay >> 8) - 1;
                            int expanderPin = myRelayButtons[i].relay & 0xff;
                            expander[expanderNo].pinMode(expanderPin, OUTPUT);
                          } else {
                            pinMode(myRelayButtons[i].relay, OUTPUT);
                        #ifdef USE_EXPANDER
                        uint8_t isTurnedOn = 0;
                        if (myRelayButtons[i].relayOptions & RELAY_STARTUP_ON) {
                          isTurnedOn = 1;
                        } else if (myRelayButtons[i].relayOptions & RELAY_STARTUP_OFF) {
                        } else {
                          isTurnedOn = loadRelayState(i, 1); // 1 - true, 0 - false
                          if (versionChangeResetState && isTurnedOn) {
                            saveRelayState(i, 0, 1);
                            isTurnedOn = 0;
                        changeRelayState(i, isTurnedOn);
                        myRelayState[i] = isTurnedOn;
                    if (versionChangeResetState) {
                      // version has changed, so store new version in eeporom
                      saveState(0, MULTI_RELAY_VERSION);
                  // executed AFTER mysensors has been initialised
                    for(int i = 0; i < numberOfRelayButtons; i++) {
                      if (myRelayButtons[i].button >= 0) {
                        // No Expander support for buttons (de-bouncing)
                        pinMode(myRelayButtons[i].button, INPUT_PULLUP); // HIGH state when button is not pushed
                    delay(5000);
                    // Send state to MySensor Gateway
                      // if this relay has multiple buttons, send only first
                        msgs[i] = MyMessage(myRelayButtons[i].sensorId, V_LIGHT);
                        uint8_t relayState;
                          relayState = 1;
                          relayState = 0;
                        } else {
                          relayState = loadRelayState(i);
                        send(msgs[i].set(relayState)); // send current state
                    // Setup buttons
                        // setup debouncer
                        myButtonDebouncer[i] = Bounce();
                        myButtonDebouncer[i].attach(myRelayButtons[i].button);
                        myButtonDebouncer[i].interval(50);
                      if (myRelayButtons[i].button >= 0 && myButtonDebouncer[i].update()) {
                        int buttonState = myButtonDebouncer[i].read();
                        #ifdef MY_DEBUG
                          Serial.print("# Button ");
                          Serial.print(i);
                          Serial.print(" changed to: ");
                          Serial.println(buttonState);
                        int relayNum = (relayMultiButtons[i].firstButton == -1) ? i : relayMultiButtons[i].firstButton;
                        if (myRelayButtons[i].buttonType == DING_DONG) {
                          if (buttonState == LOW) { // button pressed
                            changeRelayState(relayNum, 1);
                            send(msgs[relayNum].set(1));
                          } else { // button released
                            changeRelayState(relayNum, 0);
                            send(msgs[relayNum].set(0));
                        } else if (myRelayButtons[i].buttonType == BI_STABLE || buttonState == HIGH) {
                          // If button type is BI_STABLE, any change will toggle relay state
                          // For MONO_STABLE, button must be pushed and released (HIGH)
                          uint8_t isTurnedOn = ! loadRelayState(relayNum); // 1 - true, 0 - false
                          changeRelayState(relayNum, isTurnedOn);
                          send(msgs[relayNum].set(isTurnedOn));
                          saveRelayState(relayNum, isTurnedOn);
                  // MySensors - Presentation
                  // Your sensor must first present itself to the controller.
                  // The presentation is a hint to allow controller prepare for the sensor data that eventually will come.
                  // Executed after "before()" and before "setup()" in: _begin (MySensorsCore.cpp) > gatewayTransportInit() > presentNode()
                    sendSketchInfo("Multi Relay", "1.2");
                    // Register every relay as separate sensor
                      // if this relay has multiple buttons, register only first
                        // void present(uint8_t childSensorId, uint8_t sensorType, const char *description, bool ack);
                        //   childSensorId - The unique child id you want to choose for the sensor connected to this Arduino. Range 0-254.
                        //   sensorType - The sensor type you want to create.
                        //   description An optional textual description of the attached sensor.
                        //   ack - Set this to true if you want destination node to send ack back to this node. Default is not to request any ack.
                        present(myRelayButtons[i].sensorId, S_BINARY, myRelayButtons[i].relayDescription);
                  // MySensors - Handling incoming messages
                  // Nodes that expects incoming data, such as an actuator or repeating nodes,
                  // must implement the receive() - function to handle the incoming messages.
                  // Do not sleep a node where you expect incoming data or you will lose messages.
                      uint8_t isTurnedOn = message.getBool(); // 1 - true, 0 - false
                      changeRelayState(message.sensor, isTurnedOn);
                      // Store state in eeprom if changed
                      if (loadRelayState(message.sensor) != isTurnedOn) {
                        saveRelayState(message.sensor, isTurnedOn);
                      send(msgs[message.sensor].set(isTurnedOn)); // support for OPTIMISTIC=FALSE (Home Asistant)
                      #ifdef MY_DEBUG
                        // Write some debug info
                        Serial.print("# Incoming change for sensor: " + message.sensor);
                        Serial.println(", New status: " + isTurnedOn);
                  uint8_t loadRelayState(int relayNum, uint8_t forceEeprom) {
                    uint8_t relayState;
                    if (forceEeprom) {
                      relayState = loadState(RELAY_STATE_STORAGE + relayNum);
                    } else {
                      relayState = myRelayState[relayNum];
                    #ifdef MY_DEBUG
                      Serial.print("# loadRelayState: ");
                      Serial.print(relayNum);
                      if (forceEeprom) {
                        Serial.print("(byte ");
                        Serial.print(RELAY_STATE_STORAGE + relayNum);
                        Serial.print(")");
                      Serial.print(" = ");
                      Serial.println(relayState);
                    return(relayState);
                  void saveRelayState(int relayNum, uint8_t state, uint8_t useEeprom) {
                    int mainRelayNum = (relayMultiButtons[relayNum].firstButton == -1) ? relayNum : relayMultiButtons[relayNum].firstButton;
                    myRelayState[mainRelayNum] = state;
                    if (useEeprom && (relayNum == mainRelayNum)) {
                      saveState(RELAY_STATE_STORAGE + mainRelayNum, state);
                    int nextButton = mainRelayNum;
                    // update all buttons
                    while ((nextButton = relayMultiButtons[nextButton].nextButton) != -1) {
                      myRelayState[nextButton] = state;
                  void saveRelayState(int relayNum, uint8_t state) {
                    uint8_t useEeprom = ((myRelayButtons[relayNum].relayOptions & RELAY_STARTUP_MASK) == 0);
                    saveRelayState(relayNum, state, useEeprom);
                  void changeRelayState(int relayNum, uint8_t relayState) {
                    uint8_t relayTrigger = myRelayButtons[relayNum].relayOptions & RELAY_TRIGGER_HIGH;
                    uint8_t digitalOutState = relayState ? relayTrigger : ! relayTrigger;
                    #ifdef USE_EXPANDER
                      if ( myRelayButtons[relayNum].relay & 0xff00 ) {
                        int expanderNo = (myRelayButtons[relayNum].relay >> 8) - 1;
                        int expanderPin = myRelayButtons[relayNum].relay & 0xff;
                        expander[expanderNo].digitalWrite(expanderPin, digitalOutState);
                      } else {
                      digitalWrite(myRelayButtons[relayNum].relay, digitalOutState);
                    #ifdef USE_EXPANDER
                  And in Home assistant show example decription: Ł2 - kinkiet [C10] or for second Salon 2 [A9] etc.
                  Please help me... because it will be good to identify sensors when add to Controller.
