  3. About DS18B20 onewire.
dallasone wireonewireds18b20
48 Posts 5 Posters 19.1k Views 10 Watching
  • F flopp
    I have modify the sketch so now if sensor B is disconnected A will be A and C will be C, as soon as B is connected again it will send the values again.
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #include <OneWire.h>
    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
    unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
    byte D[3][8] = {
    { 0x28, 0xB1, 0x47, 0xB4, 0x04, 0x00, 0x00, 0x97 },
    { 0x28, 0xFF, 0x53, 0x78, 0x63, 0x15, 0x02, 0xC9 },
    { 0x28, 0xFF, 0xCD, 0x06, 0x52, 0x04, 0x00, 0x80 }
    int numSensors=0;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor", "1.1");
      //numSensors = sensors.getDeviceCount();
      for (int i=0; i<3 && i<MAX_ATTACHED_DS18B20; i++) {
         gw.present(i, S_TEMP);
    Serial.println(millis());
      gw.process();
      gw.sleep(conversionTime);
     //   float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
          float temperature = sensors.getTempC(D[i]);
        #if COMPARE_TEMP == 1
        #else
      //gw.sleep(SLEEP_TIME);
    first you need to use this sketch to get the correct addresses for all your DS18B20
    // OneWire DS18S20, DS18B20, DS1822 Temperature Example
    // http://www.pjrc.com/teensy/td_libs_OneWire.html
    // The DallasTemperature library can do all this work for you!
    // http://milesburton.com/Dallas_Temperature_Control_Library
    OneWire  ds(3);  // on pin 10 (a 4.7K resistor is necessary)
    int count=0;
    void setup(void) {
      Serial.begin(9600);
    void loop(void) {
      byte i;
      byte present = 0;
      byte type_s;
      byte data[12];
      byte addr[8];
      float celsius;
      if ( !ds.search(addr)) {
        //Serial.println("No more addresses.");
        Serial.println();
        ds.reset_search();
        delay(250);
        Serial.println(count);
        Serial.println();
        count=0;
        return;
      //Serial.print("ROM =");
      Serial.print("{");
      for( i = 0; i < 8; i++) {
      Serial.print(" 0x");
        //Serial.write(' ');
        //int a = (addr[i], DEC);
        //Serial.print(a);
        if (addr[i] <= 15){
          Serial.print("0");
        Serial.print(addr[i], HEX);
        if (i < 7){
          Serial.print(",");
        else
        Serial.print(" },");
      if (OneWire::crc8(addr, 7) != addr[7]) {
          Serial.println("CRC is not valid!");
          return;
      Serial.println();
      // the first ROM byte indicates which chip
      switch (addr[0]) {
        case 0x10:
          //Serial.println("  Chip = DS18S20");  // or old DS1820
          type_s = 1;
          break;
        case 0x28:
          //Serial.println("  Chip = DS18B20");
          type_s = 0;
          break;
        case 0x22:
          //Serial.println("  Chip = DS1822");
          type_s = 0;
          break;
        default:
          //Serial.println("Device is not a DS18x20 family device.");
          return;
      ds.reset();
      ds.select(addr);
      ds.write(0x44, 1);        // start conversion, with parasite power on at the end
      delay(1000);     // maybe 750ms is enough, maybe not
      // we might do a ds.depower() here, but the reset will take care of it.
      present = ds.reset();
      ds.select(addr);
      ds.write(0xBE);         // Read Scratchpad
      //Serial.print("  Data = ");
      //Serial.print(present, HEX);
      //Serial.print(" ");
      for ( i = 0; i < 9; i++) {           // we need 9 bytes
        data[i] = ds.read();
        //Serial.print(data[i], HEX);
      //Serial.print(" CRC=");
      //Serial.print(OneWire::crc8(data, 8), HEX);
      //Serial.println();
      // Convert the data to actual temperature
      // because the result is a 16 bit signed integer, it should
      // be stored to an "int16_t" type, which is always 16 bits
      // even when compiled on a 32 bit processor.
      int16_t raw = (data[1] << 8) | data[0];
      if (type_s) {
        raw = raw << 3; // 9 bit resolution default
        if (data[7] == 0x10) {
          // "count remain" gives full 12 bit resolution
          raw = (raw & 0xFFF0) + 12 - data[6];
      } else {
        byte cfg = (data[4] & 0x60);
        // at lower res, the low bits are undefined, so let's zero them
        if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
        else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
        else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
        //// default is 12 bit resolution, 750 ms conversion time
      celsius = (float)raw / 16.0;
      //Serial.print("  Temperature = ");
      //Serial.print(celsius);
      //Serial.println(" Celsius, ");
      count++;
    you will get the address like this format
    pepsonP
    pepsonP
    pepson
    @flopp
    Hi
    i try use your sketch but it is not working... I add in this to use serial gateway but also i get error why ?
    #define MY_GATEWAY_SERIAL
    byte D[3][8] = {
    { 0x28, 0xC6, 0xCA, 0xA0, 0x05, 0x00, 0x00, 0x30 }
    int numSensors=0;
      sensors.begin();
      gw.begin();
      gw.process();
        #else
    But when try compile i get error:
    dallas_with_address_ok:45:1: error: 'MySensor' does not name a type
    C:\Users\Piotrek\Desktop\Arduino\dallas_with_address_ok\dallas_with_address_ok.ino: In function 'void setup()':
    dallas_with_address_ok:61:3: error: 'gw' was not declared in this scope
       gw.begin();
    C:\Users\Piotrek\Desktop\Arduino\dallas_with_address_ok\dallas_with_address_ok.ino: In function 'void loop()':
    dallas_with_address_ok:81:3: error: 'gw' was not declared in this scope
       gw.process();
    exit status 1
    Please help me...
    • pepsonP pepson
      @flopp
      Hi
      byte D[3][8] = {
      int numSensors=0;
        sensors.begin();
        gw.begin();
        gw.process();
          #else
         gw.begin();
         gw.process();
      exit status 1
      Please help me...
      @pepson that sketch is for MySensors 1.x. It needs to be updated to work with 2.x. There is a guide, see if you can find it by searching (I’m on mobile now so I can’t search easily)
      pepsonP 1 Reply Last reply
      • pepsonP
        pepsonP
        pepson
        wrote on last edited by pepson
        #23
        I correct this sketch But for me dont read temp.....
        standard sketch from mysensors looks similary like this read with no problem.
        https://www.mysensors.org/build/temp
        byte D[3][8] = {
        { 0x28, 0xFB, 0x8F, 0x77, 0x91, 0x15, 0x02, 0x32 },
        { 0x28, 0xFF, 0x37, 0x77, 0x91, 0x18, 0x02, 0x16 }
        //MySensor gw;
        int numSensors=0;
        void before()
          sensors.begin();
        //  begin();
        void presentation() {
          sendSketchInfo("Temp. Sensor", "1.1");
             present(i, S_TEMP);
          //process();
            #else
          pepsonP
          pepsonP
          pepson
          @mfalkvidd
          Hi
          I am not programmer and i dont know how. Is any chance to you can help me convert it to working with MySensors 2.x ?
          This sketch looks similary as standard sketch from mysensors:
          Standard sketch works but i want use sketch with ID Dallas to write in my Home assistant to specify number child.... and when dallas destroy i replace ID in sketch write to arduino and in Home Assistant automaticaly replace it and show still correct temp to my room.
          • F
            F
            flopp
            wrote on last edited by flopp
            #25
            @pepson said in About DS18B20 onewire.:
            this should be how many DS18B20 you have attached
            • F
              F
              flopp
              byte D[3][8] = {
              D[3] means 3 attached DS18B20, but you only have address for 2
              • F
                F
                flopp
                I have a sketch where I have attached 40 pcs mixed both DS18B20 and DS18S20, works perfect, except that sometimes I recevied 0 as value for some of them. I am polling every minute, so I don't care if the value is 0 for a couple of minutes, it is not that very important
                • F flopp
                  pepsonP
                  pepsonP
                  pepson
                  @flopp
                  But for what is number 8 in this ?
                  byte D[3][8] = {
                  On what MySensors you use it ?
                  Previous sketch your in this thread i can not compile. I convert it as i show. You mean that sketch with 2 pcs dallas should look like this:
                  byte D[2][8] = {
                  { 0x28, 0xC5, 0xBF, 0x77, 0x91, 0x16, 0x02, 0x1D }
                  //MySensor gw;
                  int numSensors=0;
                  void before()
                    sensors.begin();
                  //  begin();
                       present(i, S_TEMP);
                    //process();
                      //float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(D[i]):sensors.getTempFByIndex(D[i])) * 10.)) / 10.;
                      //float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
                      #else
                    sleep(SLEEP_TIME);
                  And what command in sketch should be use:
                  1. float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(D[i]):sensors.getTempFByIndex(D[i])) * 10.)) / 10.;
                  2. float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
                  3. float temperature = sensors.getTempC(D[i]);
                  In original sketch from Mysensors he use this :
                  float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                  And please share me sketch which you use with MySensors 2.x and with how system controller you use it ? I want use with Home Assistant.
                  • F
                    F
                    flopp
                    #define MY_NODE_ID 14
                    #define ATTACHED_DS18B20 40
                    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                    byte D[ATTACHED_DS18B20][8] = {
                    { 0x10, 0x04, 0xB8, 0x3F, 0x02, 0x08, 0x00, 0xBD }, //KökTbx
                    { 0x10, 0xF4, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0xB1 }, //UppTbx
                    { 0x10, 0x92, 0x9F, 0x3E, 0x02, 0x08, 0x00, 0x98 }, //KökUt
                    { 0x10, 0x4E, 0xE4, 0x3E, 0x02, 0x08, 0x00, 0x3C }, //ToaUt
                    { 0x10, 0x1E, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x33 }, //EfterPump
                    { 0x10, 0x09, 0xA1, 0x3E, 0x02, 0x08, 0x00, 0xF7 }, //HallTbx
                    { 0x10, 0x59, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xFA }, //UppUt
                    { 0x10, 0x07, 0x1B, 0x3F, 0x02, 0x08, 0x00, 0x99 }, //ToaTbx
                    { 0x28, 0xFF, 0xB1, 0xAA, 0x63, 0x15, 0x03, 0xC8 }, //Kök
                    { 0x10, 0x80, 0xB6, 0x3F, 0x02, 0x08, 0x00, 0x29 }, //Panna komp
                    { 0x10, 0x3C, 0x9C, 0x3E, 0x02, 0x08, 0x00, 0x99 }, //Hall ut
                    { 0x10, 0x42, 0xE0, 0x3F, 0x02, 0x08, 0x00, 0xD1 }, //Tvätt
                    { 0x10, 0xCE, 0xE9, 0x3E, 0x02, 0x08, 0x00, 0x3A }, //T12
                    { 0x10, 0x99, 0xAC, 0x3F, 0x02, 0x08, 0x00, 0x25 }, //V mellan
                    { 0x10, 0x15, 0xDB, 0x3E, 0x02, 0x08, 0x00, 0x01 }, //Hallen
                    { 0x10, 0xF3, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0x34 }, //Panna El
                    { 0x10, 0xFB, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xC8 }, //Toa Nere
                    { 0x10, 0x97, 0x23, 0x3F, 0x02, 0x08, 0x00, 0x92 }, //Varmvatten
                    { 0x10, 0x0F, 0xE6, 0x3E, 0x02, 0x08, 0x00, 0xFD }, //Carport
                    { 0x10, 0xF3, 0xC6, 0x3F, 0x02, 0x08, 0x00, 0x85 }, //Förrådet
                    { 0x10, 0x9C, 0x3B, 0x52, 0x02, 0x08, 0x00, 0x25 }, //Mark 60
                    { 0x10, 0xF2, 0x24, 0x3F, 0x02, 0x08, 0x00, 0xEB }, //Vrum V
                    { 0x10, 0x6A, 0x5E, 0x52, 0x02, 0x08, 0x00, 0x26 }, //Mark 30
                    { 0x10, 0x76, 0xCE, 0x3F, 0x02, 0x08, 0x00, 0xBA }, //Plattan
                    { 0x10, 0x0E, 0x7B, 0x13, 0x02, 0x08, 0x00, 0x7C }, //Utetemp
                    { 0x10, 0xEE, 0xEB, 0x3E, 0x02, 0x08, 0x00, 0x0F }, //Uterum
                    { 0x28, 0x8C, 0x2D, 0xB4, 0x04, 0x00, 0x00, 0x9C }, //Kyl uppe
                    { 0x28, 0xFF, 0xB2, 0x74, 0x63, 0x15, 0x02, 0xCC }, //Kyl mitten
                    { 0x28, 0xFF, 0x08, 0x07, 0x52, 0x04, 0x00, 0xFF }, //Kyl nere
                    { 0x28, 0xFF, 0xE6, 0x06, 0x52, 0x04, 0x00, 0x08 }, //Frys uppe
                    { 0x28, 0xFF, 0xB4, 0x07, 0x55, 0x04, 0x00, 0xEB }, //Kyl bakom
                    { 0x10, 0x1C, 0xA8, 0x3F, 0x02, 0x08, 0x00, 0x3B }, //Lucas
                    { 0x10, 0x83, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x06 }, //Allrum
                    { 0x10, 0xA3, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x7E }, //Theo
                    { 0x10, 0x33, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x01 }, //Sovrum
                    { 0x28, 0xFF, 0xFB, 0x3D, 0xC3, 0x16, 0x03, 0x58 }, //Panna luft in(varm)
                    { 0x28, 0xFF, 0xD4, 0x1C, 0x00, 0x17, 0x03, 0x43 }, //Dränering
                    { 0x28, 0xFF, 0x97, 0x11, 0x01, 0x15, 0x04, 0xC0 } // Poolvatten
                    float lastTemperature[ATTACHED_DS18B20];
                    MyMessage heat(0,V_STATUS);
                      sensors.begin();
                      sendSketchInfo("OneWire Temp+Heating LED", "20180709");
                      for (int i=0; i<ATTACHED_DS18B20; i++) {
                         present(i, S_TEMP);
                      for (int i=ATTACHED_DS18B20; i<ATTACHED_DS18B20+5; i++) {
                         present(i, S_HEATER);
                      //Serial.println(sensors.getResolution(D[i]), DEC);
                        #else
                        if (temperature != -127.00 && temperature <= 85.00) {
                       for (int i=0; i<5;i++){
                        int value = analogRead(i);
                        /*Serial.print("Pin");
                        Serial.print(i);
                        Serial.print("=");
                        Serial.println(value);
                        int j=i+ATTACHED_DS18B20;
                        if (value>150) {
                          send(heat.setSensor(j).set(1));
                        else {
                          send(heat.setSensor(j).set(0));
                      sleep(SLEEP_TIME);
                    • pepsonP
                      pepsonP
                      pepson
                      And you dont use library onewire.h ?
                      F 1 Reply Last reply
                      • pepsonP pepson
                        F
                        F
                        flopp
                        I think it will be included in DallasTemperature.h.
                        Doesn’t my sketch work for you?
                        pepsonP 2 Replies Last reply
                        • F flopp
                          pepsonP
                          pepsonP
                          pepson
                          #32
                          @flopp
                          Probably tommorow I test your sketch and send you an info...
                          And what you mean in sketch write Heat?
                          And is any chance to modify this sketch and add value name "Description" to each sensor Dallas to send info to controller like Home Assistant to user can easily identify sensors in controller? What is what....
                          • F flopp
                            pepsonP
                            pepsonP
                            pepson
                            #33
                            @flopp
                            Hi
                            Tell me... is any chance to add in sketch position to write description for sensor and to send this description to Home Assistant....? It is ok write in other sketch for relay and it works perfect:
                            https://github.com/lkankowski/arduino-multi-relay/blob/master/arduino-multi-relay.ino
                            It show in Home Assisnatn this information in description example: Ł2 - kinkiet [C10]
                            • pepsonP pepson
                              @flopp
                              Hi
                              @pepson yes. Just change the present call, just like in your sketch.
                              Example: change
                              to
                              present(i, S_HEATER, "Description goes here");
                                Example: change
                                to
                                pepsonP
                                pepsonP
                                pepson
                                @mfalkvidd
                                OK but also must add defined description to all address. But how add also description?
                                rejoe2R 1 Reply Last reply
                                • pepsonP pepson
                                  @mfalkvidd
                                  rejoe2R
                                  rejoe2R
                                  rejoe2
                                  @mfalkvidd
                                  Don't know, if that really works, because I never tested it since my controller sw supports comments: https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/DallasTemperatureSimple/DallasTemperatureSimple.ino
                                  • rejoe2R rejoe2
                                    @mfalkvidd
                                    pepsonP
                                    pepsonP
                                    pepson
                                    @rejoe2
                                    But where in sketch you define address and description ?
                                    • pepsonP pepson
                                      @rejoe2
                                      rejoe2R
                                      rejoe2R
                                      rejoe2
                                      @pepson That's not necessary: The sketch reads the bus to get all the necessary info and will just send whatever is found.
                                      If you want a "hardcoded version", you'd have to addopt the sketch for something in between these variants: if you use an array for the 1-wire addresses like https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/Dallas_Addresses_Array_Solution/Dallas_Addresses_Array_Solution.ino does, just built the comment char-array based on that info.
                                      • rejoe2R rejoe2
                                        pepsonP
                                        pepsonP
                                        pepson
                                        @rejoe2 said in About DS18B20 onewire.:
                                        Ok i know how add to present description , but still dont know how add description to each sensors.... as in sketch for relay as i show as example.
                                        • pepsonP pepson
                                          rejoe2R
                                          rejoe2R
                                          rejoe2
                                          @pepson I'd suggest you make a test with the "simple" variant of the sketches. Then we could lateron discuss how to deal with an array containing the hardcoded addresses.
                                          Pls. make also a test with the hardcoded version. Afai remember, it will print the needed array to serial, as long as #define PRINT_ARRAY isn't commented.
