  3. AC IR code decrypting
42 Posts 8 Posters 23.7k Views 8 Watching
  • dpressleD Offline
    dpressleD Offline
    dpressle
    HI All,
    I am trying to decode my AC ir codes, so far i have pretty good understanding of what every command is in the code, at list the ones who's interesting to me: mode, fan, temp and on/off.
    The problem is is that i could not figure the checksum function.
    Below is some examples of code i got. The last 4 digits seems to me like a checksum, the first 4 digits are the mode and one bit for power on or off, the second 4 bits are for fan speed the 3rd 4 bits are for temp which in the example below is the only thing that is changed:
    cold auto fan, temp:
    1001 0000 0000 000000000110000010100100000000000000100000000000000 1010
    1001 0000 1000 000000000110000010100100000000000000100000000000000 0110
    18
    1001 0000 0100 000000000110000010100100000000000000100000000000000 1110
    1001 0000 1100 000000000110000010100100000000000000100000000000000 0001
    20
    1001 0000 0010 000000000110000010100100000000000000100000000000000 1001
    21
    1001 0000 1010 000000000110000010100100000000000000100000000000000 0101
    22
    1001 0000 0110 000000000110000010100100000000000000100000000000000 1101
    23
    1001 0000 1110 000000000110000010100100000000000000100000000000000 0011
    24
    1001 0000 0001 000000000110000010100100000000000000100000000000000 1011
    25
    1001 0000 1001 000000000110000010100100000000000000100000000000000 0111
    26
    1001 0000 0101 000000000110000010100100000000000000100000000000000 1111
    27
    1001 0000 1101 000000000110000010100100000000000000100000000000000 0000
    28
    1001 0000 0011 000000000110000010100100000000000000100000000000000 1000
    29
    1001 0000 1011 000000000110000010100100000000000000100000000000000 0100
    30
    1001 0000 0111 000000000110000010100100000000000000100000000000000 1100
    Can some one please help? my eyes are red from looking at this for few days now :)
    Thanks.
    Y 1 Reply Last reply
    • N Offline
      N Offline
      what are the brand and model of your AC and and how do you get this data (processor/board, IR library used, ...) ? It seems you have something wrong as you don't have full bytes. When I try to split in bytes I have 3 bits alone at the end so you are missing data somewhere.
      Usually the checksum is just a xor. It doesn't seem to be the case for yours, but maybe it's because you are missing some data.
      dpressleD 1 Reply Last reply
      • dpressleD dpressle
        HI All,
        18
        20
        21
        22
        23
        24
        25
        26
        27
        28
        29
        30
        Thanks.
        Y Offline
        Y Offline
        @dpressle you probably just want to control your airco from mysensors, right?
        Just an idea, but you could also just replay the captured IR sequence, without worrying about the content.
        • siklosiS Offline
          siklosiS Offline
          siklosi
          Maybe this will work
          0_1469012872255_upload-7ea967fd-ad75-4816-b5fa-90a88126d92f
          • N Nca78
            dpressleD Offline
            dpressleD Offline
            dpressle
            @Nca78 Thanks for the answer.
            The brand of the AC is a local brand called "Tadiran" (not sure if its world distributed).
            I am capturing the IR code with following arduino code, please note you need this code because AC have very long IR code since every button push the whole state is sent i.e. fan speed temp mode etc.
            Now i know that the code i am capturing is good because i can successfully transmit it back using any IR library.
            I agree on the uneven bytes and could not figure this out as well, i also tried the XOR checksum and couldn't get it to match.
            The output i am getting from the code is of time delays which i later convert to binary i use the follow mapping to convert to bin:
            HDR_MARK 9000
            HDR_SPACE 4000
            BIT_MARK 620
            ONE_SPACE 1600
            ZERO_SPACE 540
            MSG_SPACE 19000
            Please note that there is a message space of around 19 ms that separates the message in to 2 parts, the second part does not change beside the last 4 digits which i think is the checksum. the long pause is right after the 3 digits, so for an example look at the code i got below for a certain operation, they all got the same checksum:
            cold, 26 C
            Fan:
            Auto
            100100000101000000000110000 0101001000000000000001000000000000001111
            Fan1
            100110000101000000000110000 0101001000000000000001000000000000001111
            Fan2
            100101000101000000000110000 0101001000000000000001000000000000001111
            Fan3
            100111000101000000000110000 0101001000000000000001000000000000001111
            I appreciate the help and hope we can resolve this as i am about to give up...
            #define IRpin_PIN PIND
            #define IRpin 2
            // for MEGA use these!
            //#define IRpin_PIN PINE
            //#define IRpin 4
            // the maximum pulse we'll listen for - 65 milliseconds is a long time
            #define MAXPULSE 65000
            // what our timing resolution should be, larger is better
            // as its more 'precise' - but too large and you wont get
            // accurate timing
            #define RESOLUTION 20
            // we will store up to 300 pulse pairs (this is -a lot-)
            uint16_t pulses[300][2]; // pair is high and low pulse
            uint8_t currentpulse = 0; // index for pulses we're storing
            void setup(void) {
              Serial.begin(9600);
              Serial.println("Ready to decode IR!");
            void loop(void) {
              uint16_t highpulse, lowpulse; // temporary storage timing
              highpulse = lowpulse = 0; // start out with no pulse length
            // while (digitalRead(IRpin)) { // this is too slow!
                while (IRpin_PIN & (1 << IRpin)) {
                 // pin is still HIGH
                 // count off another few microseconds
                 highpulse++;
                 delayMicroseconds(RESOLUTION);
                 // If the pulse is too long, we 'timed out' - either nothing
                 // was received or the code is finished, so print what
                 // we've grabbed so far, and then reset
                 if ((highpulse >= MAXPULSE) && (currentpulse != 0)) {
                   printpulses();
                   currentpulse=0;
                   return;
              // we didn't time out so lets stash the reading
              pulses[currentpulse][0] = highpulse;
              // same as above
              while (! (IRpin_PIN & _BV(IRpin))) {
                 // pin is still LOW
                 lowpulse++;
                 if ((lowpulse >= MAXPULSE) && (currentpulse != 0)) {
                   printpulses();
                   currentpulse=0;
                   return;
              pulses[currentpulse][1] = lowpulse;
              // we read one high-low pulse successfully, continue!
              currentpulse++;
            void printpulses(void) {
              // IR Remote Results
              Serial.println("For IR Remote Arduino sketch: ");
              Serial.print("unsigned int raw[");
              Serial.print(currentpulse*2, DEC);
              Serial.print("] = {");
              for (uint8_t i = 0; i < currentpulse; i++) {
                if(i!=0){
                Serial.print(pulses[i][0] * RESOLUTION, DEC);
                Serial.print(", ");
                Serial.print(pulses[i][1] * RESOLUTION, DEC);
                Serial.print(", ");
              Serial.print("};");
              Serial.println("");
              Serial.print("irsend.sendRaw(raw,");
              Serial.print(",38);");
              Serial.println("");
              Serial.println("");
            • Y Yveaux
              dpressleD Offline
              dpressleD Offline
              dpressle
              @Yveaux Yes, but i want to be able to control each of the parameters separately and not have to record many operations
              • P Offline
                P Offline
                pjr
                Most likely its manufactured by GREE just like most of local branded stuff ;)
                • siklosiS siklosi
                  dpressleD Offline
                  dpressleD Offline
                  dpressle
                  @siklosi Thanks but this is for a different AC with different protocol.
                  The biggest problem with these AC companies is that each one creates its own protocol and makes our lives hard...
                  • P pjr
                    dpressleD Offline
                    dpressleD Offline
                    dpressle
                    @pjr Dont know this one, not sure your local is my local :wink:
                    • N Offline
                      N Offline
                      Can you please indicate in one of the messages where the 19ms "space" exactly is ?
                      Maybe the 3 extra bits are related to this space and they should be discarded before/after the space ?
                      Never heard about this brand, where do you live ?
                      • N Nca78
                        dpressleD Offline
                        dpressleD Offline
                        dpressle
                        @Nca78 The space is where the space is in the binary i wrote (its actually hard to see):
                        100100000101000000000110000 19 ms space 0101001000000000000001000000000000001111
                        I am from Israel.
                        Thanks.
                        • T Offline
                          T Offline
                          ToniA
                          Would these help:
                          https://github.com/ToniA/arduino-heatpumpir
                          https://github.com/ToniA/Raw-IR-decoder-for-Arduino
                          • dpressleD Offline
                            dpressleD Offline
                            dpressle
                            I can send the timings i get from the code before i convert to bin, since i am converting it with notepad++ i might be wrong.
                            • T ToniA
                              Would these help:
                              dpressleD Offline
                              dpressleD Offline
                              dpressle
                              @ToniA I love your library but non of your pre-defined AC's worked for mine.
                              I will defiantly use it once i crack the code of this AC and will pull it to your repository.
                              Thanks.
                              • T Offline
                                T Offline
                                ToniA
                                How about writing a new decode module into Raw-IR-decoder-for-Arduino? I find it very useful in trying to figure out how a certain A/C protocol works.
                                • P Offline
                                  P Offline
                                  pjr
                                  wrote on last edited by pjr
                                  Gree is the most largest manufacturer of AC devices and Tadiran outdoor unit looks quite a lot like Gree.. at least I'd try that first.
                                  e: Oh. Looks like Carrier also has some relation with Tadiran.
                                  T 1 Reply Last reply
                                  • T ToniA
                                    dpressleD Offline
                                    dpressleD Offline
                                    dpressle
                                    @ToniA can you elaborate?
                                    N 1 Reply Last reply
                                      N Offline
                                      N Offline
                                      From wikipedia :
                                      "Tadiran Appliances (also known as Tadiran Air Conditioners), was acquired by the Carrier Corporation, the world’s largest manufacturer and distributor of heating, ventilating and air conditioning (HVAC) systems, itself a subsidiary of United Technologies Corporation (UTC) of the USA and a constitute of Dow Jones Industrial Average. Carrier initially acquired 26%of the company in 1997 and took full ownership of it in 2004.[2]"
                                      So looking for Carrier AC infrared should probably help.
                                      Is the reference of your remote control (on the sticker at the back) YB1FA ? As it seems to be shared by gree/carrier/tadiran/ferroli/condor
                                      • N Offline
                                        N Offline
                                        wrote on last edited by Nca78
                                        From the temperature codes, the checksum is obviously a sum, you have to reverse the bits before you sum, the MSB is on the right in both data bits and checksum.
                                        16° 0000 checksum 0101
                                        17° 0001 checksum 0110 = 0101 + 0001
                                        18° 0010 checksum 0111 = 0101 + 0010
                                        19° 0011 checksum 1000 = 0101 + 0011
                                        20° 0100 checksum 1001 = 0101 + 0100
                                        27° 1101 checksum 0000 because 0101 + 1101 = 10000 and you keep only the last 4 bits
                                        Now we just need to understand what bits are included or not in the sum, it seems the fan speed is not, but we need more messages in different modes and with different settings to be able to know which bits are used or not in the calculation.
                                        I take your example code :
                                        Split in 4 bits words :
                                        1001
                                        0000
                                        0101
                                        0000
                                        0000
                                        0110
                                        000 19 ms space => I ignore this part as it's not matching the 4 bits words, and only 0s anyway
                                        0101
                                        0010
                                        0000
                                        0000
                                        0000
                                        0100
                                        0000
                                        0000
                                        0000
                                        1111
                                        Invert bit order and try to guess what words are included or not.
                                        If you make the sum of included words with binary calculator, it matches the checksum but we must validate with more parameters changed, try with horizontal/vertical swing if you have these on the remote control, then any other specific function.
                                        1001 => on + mode, included as it's the only one with LSB = 1 and we have LSB = 1 in checksum
                                        0000 => fan speed, not included as shown in your examples on fan speed
                                        1010 => temp 16°C + value, included as shown in your examples of temperature
                                        0000 => ??? cannot know because 0
                                        0110 => I think included else I don't have the right checksum
                                        1010 => I think not included else I don't have the right checksum
                                        0100 => I think included else I don't have the right checksum
                                        1111 => binary sum of all included words, only the 4 LSB bits are kept
                                        dpressleD 2 Replies Last reply
                                        • N Nca78
                                          1001
                                          0000
                                          0101
                                          0000
                                          0000
                                          0110
                                          0101
                                          0010
                                          0000
                                          0000
                                          0000
                                          0100
                                          0000
                                          0000
                                          0000
                                          1111
                                          dpressleD Offline
                                          dpressleD Offline
                                          dpressle
                                          @Nca78 I think you are on to something, thanks a lot. I will investigate it further, but in the mean time here is some more data that i took:
                                          mode fan temp
                                          cold auto 26
                                          1001 0000 0101 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1111
                                          cold auto 25
                                          1001 0000 1001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 0111
                                          cold auto 24
                                          1001 0000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
                                          cold fan1 24
                                          1001 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
                                          cold fan2 24
                                          1001 0100 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
                                          cold fan3 24
                                          1001 1100 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
                                          dry fan1 24
                                          0101 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 0111
                                          air fan1 24
                                          1101 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1111
                                          heat fan1 24
                                          0011 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 0000
                                          OFF cold auto 26
                                          1000 0000 0101 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1110
                                          12.2k
