  3. AC IR code decrypting
42 Posts 8 Posters 25.1k Views 8 Watching
  • Nca78N
    Can you please indicate in one of the messages where the 19ms "space" exactly is ?
    Maybe the 3 extra bits are related to this space and they should be discarded before/after the space ?
    Never heard about this brand, where do you live ?
    dpressleD 1 Reply Last reply
    • Nca78N Nca78
      dpressleD
      dpressleD
      dpressle
      @Nca78 The space is where the space is in the binary i wrote (its actually hard to see):
      100100000101000000000110000 19 ms space 0101001000000000000001000000000000001111
      I am from Israel.
      • T
        ToniA
        Would these help:
        https://github.com/ToniA/arduino-heatpumpir
        https://github.com/ToniA/Raw-IR-decoder-for-Arduino
        • dpressleD
          dpressleD
          dpressle
          I can send the timings i get from the code before i convert to bin, since i am converting it with notepad++ i might be wrong.
          • T ToniA
            Would these help:
            dpressleD
            dpressleD
            dpressle
            @ToniA I love your library but non of your pre-defined AC's worked for mine.
            I will defiantly use it once i crack the code of this AC and will pull it to your repository.
            • T
              ToniA
              How about writing a new decode module into Raw-IR-decoder-for-Arduino? I find it very useful in trying to figure out how a certain A/C protocol works.
              • P
                P
                pjr
                wrote on last edited by pjr
                Gree is the most largest manufacturer of AC devices and Tadiran outdoor unit looks quite a lot like Gree.. at least I'd try that first.
                e: Oh. Looks like Carrier also has some relation with Tadiran.
                • T ToniA
                  dpressleD
                  dpressleD
                  dpressle
                  @ToniA can you elaborate?
                  Nca78N 1 Reply Last reply
                  • dpressleD dpressle
                    From wikipedia :
                    "Tadiran Appliances (also known as Tadiran Air Conditioners), was acquired by the Carrier Corporation, the world’s largest manufacturer and distributor of heating, ventilating and air conditioning (HVAC) systems, itself a subsidiary of United Technologies Corporation (UTC) of the USA and a constitute of Dow Jones Industrial Average. Carrier initially acquired 26%of the company in 1997 and took full ownership of it in 2004.[2]"
                    So looking for Carrier AC infrared should probably help.
                    Is the reference of your remote control (on the sticker at the back) YB1FA ? As it seems to be shared by gree/carrier/tadiran/ferroli/condor
                    • Nca78N
                      wrote on last edited by Nca78
                      From the temperature codes, the checksum is obviously a sum, you have to reverse the bits before you sum, the MSB is on the right in both data bits and checksum.
                      16° 0000 checksum 0101
                      17° 0001 checksum 0110 = 0101 + 0001
                      18° 0010 checksum 0111 = 0101 + 0010
                      19° 0011 checksum 1000 = 0101 + 0011
                      20° 0100 checksum 1001 = 0101 + 0100
                      27° 1101 checksum 0000 because 0101 + 1101 = 10000 and you keep only the last 4 bits
                      Now we just need to understand what bits are included or not in the sum, it seems the fan speed is not, but we need more messages in different modes and with different settings to be able to know which bits are used or not in the calculation.
                      I take your example code :
                      Split in 4 bits words :
                      1001
                      0000
                      0101
                      0000
                      0000
                      0110
                      000 19 ms space => I ignore this part as it's not matching the 4 bits words, and only 0s anyway
                      0101
                      0010
                      0000
                      0000
                      0000
                      0100
                      0000
                      0000
                      0000
                      1111
                      Invert bit order and try to guess what words are included or not.
                      If you make the sum of included words with binary calculator, it matches the checksum but we must validate with more parameters changed, try with horizontal/vertical swing if you have these on the remote control, then any other specific function.
                      1001 => on + mode, included as it's the only one with LSB = 1 and we have LSB = 1 in checksum
                      0000 => fan speed, not included as shown in your examples on fan speed
                      1010 => temp 16°C + value, included as shown in your examples of temperature
                      0000 => ??? cannot know because 0
                      0110 => I think included else I don't have the right checksum
                      1010 => I think not included else I don't have the right checksum
                      0100 => I think included else I don't have the right checksum
                      1111 => binary sum of all included words, only the 4 LSB bits are kept
                      dpressleD 2 Replies Last reply
                      • Nca78N Nca78
                        1001
                        0000
                        0101
                        0000
                        0000
                        0110
                        0101
                        0010
                        0000
                        0000
                        0000
                        0100
                        0000
                        0000
                        0000
                        1111
                        dpressleD
                        dpressleD
                        dpressle
                        @Nca78 I think you are on to something, thanks a lot. I will investigate it further, but in the mean time here is some more data that i took:
                        mode fan temp
                        cold auto 26
                        1001 0000 0101 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1111
                        cold auto 25
                        1001 0000 1001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 0111
                        cold auto 24
                        1001 0000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
                        cold fan1 24
                        1001 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
                        cold fan2 24
                        1001 0100 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
                        cold fan3 24
                        1001 1100 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
                        dry fan1 24
                        0101 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 0111
                        air fan1 24
                        1101 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1111
                        heat fan1 24
                        0011 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 0000
                        OFF cold auto 26
                        1000 0000 0101 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1110
                        • Nca78N Nca78
                          1001
                          0000
                          0101
                          0000
                          0000
                          0110
                          0101
                          0010
                          0000
                          0000
                          0000
                          0100
                          0000
                          0000
                          0000
                          1111
                          dpressleD
                          dpressleD
                          dpressle
                          @Nca78 can you please explain why do you add 0101 to the checksum in the temperature example?
                            #22
                            @dpressle
                            I add it because it is the initial value of the checksum when temperature is 16°C = 0000
                            I just wanted to show than an increase of 1 in temperature was producing an increase of 1 in checksum.
                            I think your minus sign (= 19ms pause ?) is in wrong position as it is supposed to be after the 6 (and not 8 ) first words ?
                            Please take some values by changing the horizontal and vertical swing so we can try to change the second part of the message. After that try some other functions if you have (anything like "eco"/"quiet"/"turbo" options for example) and also if you have it the timer.
                            • Nca78N Nca78
                              @dpressle
                              dpressleD
                              dpressleD
                              dpressle
                              @Nca78 OK, i will generate more commands and see if it makes more sense, Thanks for your help.
                              • P pjr
                                ToniA
                                Yes, on my AC IR decoder sketch I have decoder modules for different heatpumps. Like this:
                                https://github.com/ToniA/Raw-IR-decoder-for-Arduino/blob/master/MitsubishiElectric.cpp
                                So, write a new one, and add a call to it into https://github.com/ToniA/Raw-IR-decoder-for-Arduino/blob/master/rawirdecode.ino#L315. First you need to write a condition to recognize the protocol (like, from the first bytes + length etc). Then just start adding functionality, like decoding the temperature, then operating mode etc.
                                • T ToniA
                                  dpressleD
                                  dpressleD
                                  dpressle
                                  @ToniA i got you, but the problem is i still dont know the checksum value, working on it...
                                  • Nca78N
                                    @dpressle could you please also post a picture of the back of your remote control ? I would like to confirm it's the one I quoted above, would be very interesting as it seems this RC/protocol is shared with a loooot of brands and models.
                                    It's a very interesting case for this reason but also because it's using a checksum based on 4 bits words and excluding some of the "data" bits (at least the fan speed), it's the first time I see this.
                                    • Nca78N Nca78
                                      dpressleD
                                      dpressleD
                                      dpressle
                                      @Nca78 yes it is YB1FA
                                        A Former User
                                        In case you are still interested, here is the full description of this code:
                                        0_1469565492669_Gree.pdf
                                        Nca78N dpressleD 2 Replies Last reply
                                        • ? A Former User
                                          @joker_mkd That's a fraction of a VERY interesting document you have posted here
                                          I suppose the other 180 pages are not freely available ? :D
                                          ? 1 Reply Last reply
