  3. AC IR code decrypting
42 Posts 8 Posters 24.3k Views 8 Watching
  • Nca78N Nca78
    From the temperature codes, the checksum is obviously a sum, you have to reverse the bits before you sum, the MSB is on the right in both data bits and checksum.
    16° 0000 checksum 0101
    17° 0001 checksum 0110 = 0101 + 0001
    18° 0010 checksum 0111 = 0101 + 0010
    19° 0011 checksum 1000 = 0101 + 0011
    20° 0100 checksum 1001 = 0101 + 0100
    27° 1101 checksum 0000 because 0101 + 1101 = 10000 and you keep only the last 4 bits
    Now we just need to understand what bits are included or not in the sum, it seems the fan speed is not, but we need more messages in different modes and with different settings to be able to know which bits are used or not in the calculation.
    I take your example code :
    100100000101000000000110000 19 ms space 0101001000000000000001000000000000001111
    Split in 4 bits words :
    1001
    0000
    0101
    0000
    0000
    0110
    000 19 ms space => I ignore this part as it's not matching the 4 bits words, and only 0s anyway
    0101
    0010
    0000
    0000
    0000
    0100
    0000
    0000
    0000
    1111
    Invert bit order and try to guess what words are included or not.
    If you make the sum of included words with binary calculator, it matches the checksum but we must validate with more parameters changed, try with horizontal/vertical swing if you have these on the remote control, then any other specific function.
    1001 => on + mode, included as it's the only one with LSB = 1 and we have LSB = 1 in checksum
    0000 => fan speed, not included as shown in your examples on fan speed
    1010 => temp 16°C + value, included as shown in your examples of temperature
    0000 => ??? cannot know because 0
    0110 => I think included else I don't have the right checksum
    1010 => I think not included else I don't have the right checksum
    0100 => I think included else I don't have the right checksum
    1111 => binary sum of all included words, only the 4 LSB bits are kept
    dpressleD
    dpressleD
    dpressle
    @Nca78 can you please explain why do you add 0101 to the checksum in the temperature example?
    Nca78N 1 Reply Last reply
    • dpressleD dpressle
      Nca78N
      Nca78N
      wrote on last edited by Nca78
      #22
      @dpressle
      I add it because it is the initial value of the checksum when temperature is 16°C = 0000
      I just wanted to show than an increase of 1 in temperature was producing an increase of 1 in checksum.
      I think your minus sign (= 19ms pause ?) is in wrong position as it is supposed to be after the 6 (and not 8 ) first words ?
      Please take some values by changing the horizontal and vertical swing so we can try to change the second part of the message. After that try some other functions if you have (anything like "eco"/"quiet"/"turbo" options for example) and also if you have it the timer.
      dpressleD 1 Reply Last reply
      • Nca78N Nca78
        @dpressle
        dpressleD
        dpressleD
        dpressle
        @Nca78 OK, i will generate more commands and see if it makes more sense, Thanks for your help.
        • P pjr
          Gree is the most largest manufacturer of AC devices and Tadiran outdoor unit looks quite a lot like Gree.. at least I'd try that first.
          e: Oh. Looks like Carrier also has some relation with Tadiran.
          ToniA
          @dpressle said:
          @ToniA can you elaborate?
          Yes, on my AC IR decoder sketch I have decoder modules for different heatpumps. Like this:
          https://github.com/ToniA/Raw-IR-decoder-for-Arduino/blob/master/MitsubishiElectric.cpp
          So, write a new one, and add a call to it into https://github.com/ToniA/Raw-IR-decoder-for-Arduino/blob/master/rawirdecode.ino#L315. First you need to write a condition to recognize the protocol (like, from the first bytes + length etc). Then just start adding functionality, like decoding the temperature, then operating mode etc.
          • T ToniA
            dpressleD
            dpressleD
            dpressle
            @ToniA i got you, but the problem is i still dont know the checksum value, working on it...
            • Nca78N
              Nca78N
              @dpressle could you please also post a picture of the back of your remote control ? I would like to confirm it's the one I quoted above, would be very interesting as it seems this RC/protocol is shared with a loooot of brands and models.
              It's a very interesting case for this reason but also because it's using a checksum based on 4 bits words and excluding some of the "data" bits (at least the fan speed), it's the first time I see this.
              • Nca78N Nca78
                dpressleD
                dpressleD
                dpressle
                @Nca78 yes it is YB1FA
                  A Former User
                  In case you are still interested, here is the full description of this code:
                  0_1469565492669_Gree.pdf
                  Nca78N dpressleD 2 Replies Last reply
                  • ? A Former User
                    Nca78N
                    Nca78N
                    @joker_mkd That's a fraction of a VERY interesting document you have posted here
                    I suppose the other 180 pages are not freely available ? :D
                    ? 1 Reply Last reply
                    • ? A Former User
                      dpressleD
                      dpressleD
                      dpressle
                      Thanks, this is great looks like exactly what i need, all the relevant information is there.
                      I will now write some code to implement this.
                      Thanks.
                      • Nca78N Nca78
                        A Former User
                        @Nca78 Unfortunately not. This is a part of the document which we use to define IR codes for our product called PebbleAIR . These codes are implemented in the Android and iOS app. It took me a lot of time, money and effort to decode all the different brands and remotes. I often browse the forums and if I see that someone is stuck or in a need, I share remote data from time to time. If you desperately need data for a certain brand od model feel free to PM me, and I might help you.
                        • ? A Former User
                          Nca78N
                          Nca78N
                          @joker_mkd I understand, it's very nice from you to share these pages already !
                          You have a nice product, I love the flashing function I will have to try that just for the fun of it :)
                          • ? A Former User
                            dpressleD
                            dpressleD
                            dpressle
                            wrote on last edited by dpressle
                            #33
                            @joker_mkd product looks great, did you ever thought of making these units smaller (so can be attached on an AC for example) and have some kind of API exposed so any Home Automation can use them? MySensors ZWave Wifi http etc...
                              A Former User
                              @dpressle We are in the process of making an API, because several companies have asked us for this. I was not involved in the process of hardware design, and I agree that the unit could have been made smaller, probably in the next revision.
                              • ? A Former User
                                dpressleD
                                dpressleD
                                dpressle
                                @joker_mkd Sounds wonderful, good luck, i will be watching you :wink:
                                • T
                                  ToniA
                                  This is what I have done as a hobby so far: https://www.openhardware.io/view/41/Heatpump-airconditioner-controller
                                  There's no Gree support in the HeatpumpIR library, though.
                                  • T ToniA
                                    dpressleD
                                    dpressleD
                                    dpressle
                                    @ToniA i know, i will try to add it to your library (if no one will beat me to it)
                                      Nca78N
                                      Nca78N
                                      Not me :p
                                      I'll implement it in my own library if I manage to make something valuable.
                                      • Nca78N Nca78
                                        Not me :p
                                        dpressleD
                                        dpressleD
                                        dpressle
                                        @Nca78 said:
                                        Not me :p
                                        Let me know if you get it done please!
                                        • frishrashF
                                          frishrashF
                                          frishrash
                                          Hi all,
                                          This post is great. I started writing a similar library myself for Electra AC, I might just add it on top of @ToniA's library.
                                          Quick question: can anyone recommend MySensors compatible controller that supports temperature/fan commands ?
                                          The only thing I came across so far is this modification for Vera UI7 thermostat: https://forum.mysensors.org/topic/3606/redesigned-vera-ui7-thermostat-with-heat-cool-setpoint-hvac-state-fan-status-energy-mode
                                          Thanks!
