  3. Reuse old alarm system
6 Posts 3 Posters 2.0k Views 3 Watching
  • Skye TurnerS Offline
    Skye Turner
    I just bought a home, that has an alarm system, that is not being used. There is a sensor on every door and window, coming to a centralized location. I would like to set up a Arduino Mega to capture these 10 sensors.
    Ideas?
    AWIA 1 Reply Last reply
    • Skye TurnerS Skye Turner
      Ideas?
      AWIA Offline
      AWIA Offline
      AWI
      @Skye-Turner So you have a wired alarm system where all the wires come together in one place?
      Skye TurnerS 1 Reply Last reply
      • D Offline
        drock1985
        You may be able to integrate your old system into an existing Home Automation controller (ex. OpenHab). What brand and model do you have?
        My Projects
        2 Door Chime Sensor
        Washing Machine Monitor
        • AWIA AWI
          Skye Turner
          @AWI Yes they all come to where the old control board was
          • D drock1985
            Skye Turner
            @drock1985 There is no system board and am hoping to use HA as my system
            • D Offline
              drock1985
              @Skye-Turner
              Ok thanks, was hoping there was still a system board there; was hoping it would be as easy as this for you.
              As for ideas, you could use an Arduino Uno, Nano, or Mega and have all your sensors connect via external pull-up resistors to deliver a good clean signal. You can just use the example ReedSwitch sketch and just modify it for how ever many binary/reed switches you want to have.
              Also now that MySensors is on V2.0, you can use whatever method you choose to communicate to HA (NRF/RFM, Ethernet (Gateway and NODE on same Arduino), etc. I think even Wifi with the ESP8266 is an option.
              How do you intend on communicating your sensors with HA? Do you have an existing MySensors network?
              My Projects
              2 Door Chime Sensor
              11.9k
              113.3k
