  3. Ceech board upgrade
Ceech board upgrade
4 Posts 2 Posters 2.2k Views 3 Watching
  • C
    C
    ceech
    The board will receive a new design with TP4056 battery charger.
    Charge current and battery voltage will be reported on ADC6 and ADC7.
    Mosfet will be available for external load regulation. It is connected to D3.
    There are three sockets for:
    bluetooth
    NRF24l01+ and
    I2C modules.
      A Former User
      Are we able to use the Rfm69 module with nrf24l01 adapter? Is the IRQ PIN connected to D2?
      C 1 Reply Last reply
      • ? A Former User
        C
        C
        ceech
        @kenci It can be used with Rfm69. And yes, IRQ pin is connected to D2.
        • C
          C
          ceech
          wrote on last edited by ceech
          New boards are ready and are being tested. Here is one connected to a Bluetooth module charging a battery:
          This is the code used in battery voltage and charge current monitoring:
          float readVcc()
            signed long resultVcc;
            float resultVccFloat;
            delay(10);                           // Wait for Vref to settle
            ADCSRA |= _BV(ADSC);                 // Convert
            while (bit_is_set(ADCSRA,ADSC));
            resultVcc = ADCL;
            resultVcc |= ADCH<<8;
            resultVcc = 1126400L / resultVcc;    // Back-calculate AVcc in mV
            resultVccFloat = (float) resultVcc / 1000.0; // Convert to Float
            return resultVccFloat;
          const int current = A6;
          const int lipo = A7;
          float vout = 0.0;
          float vin = 0.0;
          int value = 0;
            Serial.begin(9600);
            float napetost = readVcc();
            float tok = ((analogRead(current) * napetost / 1024 ) * 1200) / 3; // convert the ADC value of charge current to miliamps
            float baterija = ( analogRead(lipo) * napetost / 1024 ) * 2; // measuring battery voltage
            Serial.print("Vcc = ");
            Serial.print(napetost);
            Serial.println("V");
            delay(400);
            Serial.print("Charge current = ");
            Serial.print(tok);
            Serial.println("mA");
            delay(400);
            Serial.print("Battery voltage = ");
            Serial.print(baterija);
            delay(400);
            Serial.println("----------------------------");
            delay(2000);
          Improving accuracy:
          To do so, simply measure your Vcc with a voltmeter and with our readVcc() function. Then, replace the constant 1107035L with a new constant:
          scale_constant = internal1.1Ref * 1024 * 1000
          where
          internal1.1Ref = 1,1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
          Example:
          For instance, I measure 3,43V from my FTDI, the calculated value of Vref is 1,081V.
          So (1,081 x 1000 x 1024) = 1107034,95 or 1107035L rounded up.
          Use smoothing example from IDE to smooth the data from ADC.
          Charge current is limited to 400mA and can be easily changed to another value by changing just one resistor.
