  3. Vera
  4. UI5 Mysensors library 2.0 gateway issues
73 Posts 8 Posters 24.4k Views 8 Watching
    @dbemowsk
    This message appears when a none included node receives data.
    https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L466
    I can't see any presentation message from your node (84).. It should say "c=0" something.
    • dbemowskD
      dbemowskD
      #42
      @hek, thanks for the quick reply.
      You say "This message appears when a none included node receives data." but the only time I see those yellow lines is when I present the node.
      I see under the last discarded command:
      50	12/27/16 9:12:38.441	luup_log:10: Arduino: Log: TSP:MSG:READ 84-84-0 s=0,c=0,t=7,pt=0,l=0,sg=0: <0x73e23520>
      50	12/27/16 9:12:38.443	luup_log:10: Arduino: Presentation: 84;0;0;0;7; <0x73e23520>
      50	12/27/16 9:12:38.446	luup_log:10: Arduino: Log: TSP:MSG:READ 84-84-0 s=1,c=0,t=6,pt=0,l=0,sg=0: <0x73e23520>
      50	12/27/16 9:12:38.448	luup_log:10: Arduino: Presentation: 84;1;0;0;6; <0x73e23520>
      The two TSP:MSG:READ lines contain c=0. Is this what you were referring to?
        wrote on last edited by hek
        #43
        Yes, very strange. Presentation comes in. How could I miss that.
        I still run UI5 on my Vera. Wondering if they changed any behaviour in recent firmware updates?
        • dbemowskD
          dbemowskD
          I find it hard to believe that no one here has used UI7 and not seen this. It is a bit frustrating.
            What happens if you let vera hand out id?
            Clear eeprom and re-upload sketch. And try to include again.
            • dbemowskD
              dbemowskD
              That was one of my questions in the other thread. I was thinking that Vera wasn't handing out IDs, which is why I manually assigned it. I will try clearing eeprom and try again. I'll post the log results.
                Yes, the Vera plugin hands out ids.
                I can't really explain the weird behaviour you're seeing. Communication seems to work...
                • korttomaK
                  korttomaK
                  korttoma
                  Thanks @hek for chipping in an looking at the problem @dbemowsk is experiencing. This is really beyond my knowledge an I cannot understan why it is not working. I am running the latest UI7 firmware on my Veralite test device, am I cannot reproduce this issue. Including MySensor devices is no problem even if I use static node adress.
                  • Tomas
                  • dbemowskD
                    dbemowskD
                    So I cleared the eeprom and re-uploaded the humidity sensor sketch. Had to rebuild it from the example because the arduino IDE crashed and erased it. That has happened to me a couple times now since starting with the IDE. This is with debug turned on and viewing the serial monitor. To me it looks like it fails to get an ID from Vera. This is what I was seeing before which was why I manually assigned the ID.
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                    TSM:FPAR
                    TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    TSP:MSG:PAR OK (ID=0, dist=1)
                    TSM:FPAR:OK
                    TSM:ID
                    TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                    TSM:ID
                    TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0 l=0,sg=0,ft=0,st=ok:
                    TSM:ID
                    TSM:ID
                    !TSM:CHKID:FAIL (ID=255)
                    !TSM:FAILURE
                    TSM:PDT
                    This is the Vera log from start to stop inclusion with the node trying to get an ID. Here I see no c=0 or presentation entries.
                    50	12/27/16 12:24:41.287	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                    08	12/27/16 12:24:42.769	JobHandler_LuaUPnP::HandleActionRequest device: 10 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StartInclusion <0x73c23520>
                    08	12/27/16 12:24:42.770	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=10 <0x73c23520>
                    08	12/27/16 12:24:42.770	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x73c23520>
                    08	12/27/16 12:24:42.770	JobHandler_LuaUPnP::HandleActionRequest argument action=StartInclusion <0x73c23520>
                    50	12/27/16 12:24:42.772	luup_log:10: Arduino: Sending: 0;0;3;0;5;1 <0x779ea320>
                    04	12/27/16 12:24:42.774	 <0x779ea320>
                    50	12/27/16 12:24:43.305	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                    50	12/27/16 12:24:43.307	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                    50	12/27/16 12:24:45.325	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                    50	12/27/16 12:24:45.327	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                    50	12/27/16 12:24:51.308	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x73e23520>
                    50	12/27/16 12:24:51.310	luup_log:10: Arduino: Log: TSP:MSG:BC <0x73e23520>
                    50	12/27/16 12:24:51.314	luup_log:10: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x73e23520>
                    50	12/27/16 12:24:51.316	luup_log:10: Arduino: Log: TSP:CHKUPL:OK <0x73e23520>
                    50	12/27/16 12:24:51.319	luup_log:10: Arduino: Log: TSP:MSG:GWL OK <0x73e23520>
                    50	12/27/16 12:24:52.259	luup_log:10: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x73e23520>
                    50	12/27/16 12:24:53.331	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x73e23520>
                    50	12/27/16 12:24:53.332	luup_log:10: Arduino: Log: TSP:MSG:BC <0x73e23520>
                    50	12/27/16 12:24:53.334	luup_log:10: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x73e23520>
                    50	12/27/16 12:24:53.339	luup_log:10: Arduino: Log: TSP:CHKUPL:OK (FLDCTRL) <0x73e23520>
                    50	12/27/16 12:24:53.340	luup_log:10: Arduino: Log: TSP:MSG:GWL OK <0x73e23520>
                    50	12/27/16 12:24:54.252	luup_log:10: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x73e23520>
                    50	12/27/16 12:24:57.369	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                    50	12/27/16 12:24:57.370	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                    50	12/27/16 12:24:59.388	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                    50	12/27/16 12:24:59.390	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                    50	12/27/16 12:25:01.408	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x73e23520>
                    50	12/27/16 12:25:01.410	luup_log:10: Arduino: Sending: 255;255;3;0;4;255 <0x73e23520>
                    50	12/27/16 12:25:13.497	luup_log:10: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x73e23520>
                    50	12/27/16 12:25:13.499	luup_log:10: Arduino: Log: TSP:MSG:BC <0x73e23520>
                    50	12/27/16 12:25:13.503	luup_log:10: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x73e23520>
                    50	12/27/16 12:25:13.505	luup_log:10: Arduino: Log: TSP:CHKUPL:OK <0x73e23520>
                    50	12/27/16 12:25:13.507	luup_log:10: Arduino: Log: TSP:MSG:GWL OK <0x73e23520>
                    08	12/27/16 12:25:13.563	JobHandler_LuaUPnP::HandleActionRequest device: 10 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StopInclusion <0x74423520>
                    08	12/27/16 12:25:13.564	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=10 <0x74423520>
                    08	12/27/16 12:25:13.564	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x74423520>
                    08	12/27/16 12:25:13.564	JobHandler_LuaUPnP::HandleActionRequest argument action=StopInclusion <0x74423520>
                    50	12/27/16 12:25:13.565	luup_log:10: Arduino: Sending: 0;0;3;0;5;0 <0x779ea320>
                    04	12/27/16 12:25:13.567	 <0x779ea320>
                    I am not sure what to do next.
                      #50
                      Hmm.. it looks like your Vera is sending out id 255.. (255;255;3;0;4;255) which usually means that all ids has been used up.
                      https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L299
                      The table of used ids is build during plugin startup.. here:
                      https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L686
                      I have no idea why this get filled up (or why the plugin thinks so..) when you don't have any child devices to your gateway.
                      dbemowskD 1 Reply Last reply
                        dbemowskD
                        dbemowskD
                        @hek Is there any way for me to debug what is happening with the availableIds[i] array? or at least finding where it is stored and clearing it? If not, maybe I'll try restoring my unit to default and try again. I am assuming that would clear the availableIds array. The only thing I currently have set up on the unit is my 1-Wire temp sensors, and there is only 7 of them. I can rebuild those easy enough.
                          Well, it iterates over all vera devices (luup.devices) and checks if anyone is has the current device as parent... which means it is a child device.
                          For each child device it adds it to the array. The problem here is that it shouldn't find any child devices.. thus the availableIds should all be filled with false.
                          Maybe you could add some debug logging in the section I pointed out to see what kind of devices it picks up?
                          • dbemowskD
                            dbemowskD
                            I am more than interested in trying, I just need a little guidance on how to do that.
                            In the nextAvailiableRadioId() function I could do the following before it searches for an ID, I am just not sure what code to use to find out what device is defined for that ID.
                            	for i=1,255 do
                            		if (availableIds[i] == false) then
                            			--add code to log what device is holding this spot
                            		end
                            	end
                              It might be more interesting if you'd add some logging in this area, which should appear in the log when you reload the luup engine:
                              https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L682-L687
                              v contains the device. See what it contains under "variable: devices" here:
                              http://wiki.micasaverde.com/index.php/Luup_Lua_extensions
                              • dbemowskD
                                dbemowskD
                                OK, so here is what I did:
                                	-- build an lookup table for child device ids (altid -> id)
                                	local lastDev = 0
                                	for k, v in pairs(luup.devices) do
                                		-- for debugging only remove for production run
                                		for k2, v2 in pairs(v) do
                                			if (k ~= lastDev) then
                                				luup.log("Device #" .. k .. ":" .. k2 .. "=" .. tostring(v2))
                                			else
                                				luup.log("           " .. k2 .. "=" .. tostring(v2))
                                			end
                                			lastDev = k
                                		end
                                		-- end debugging
                                		-- if I am the parent device
                                		if v.device_num_parent == ARDUINO_DEVICE then
                                			childIdLookupTable[v.id] = k
                                			local split = v.id:split(";")
                                			local radioId = tonumber(split[1])
                                			availableIds[radioId] = false;
                                		end
                                	end
                                I did this to show me every attribute of every device that the system sees. After the luup engine restarts, I get this in the logs:
                                50	12/27/16 15:58:48.117	luup_log:19: Initialising One Wire Server <0x76be5520>
                                50	12/27/16 15:58:48.221	luup_log:27: Arduino plugin: loading library L_Arduino ... <0x76be5520>
                                50	12/27/16 15:58:48.239	luup_log:27: Arduino plugin: library L_Arduino loaded <0x76be5520>
                                50	12/27/16 15:58:48.239	luup_log:27: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 27 <0x76be5520>
                                50	12/27/16 15:58:48.239	luup_log:27: Arduino: Trying for a serial connection <0x76be5520>
                                50	12/27/16 15:58:48.240	luup_log:27: Arduino: Serial port is connected <0x76be5520>
                                50	12/27/16 15:58:48.240	luup_log:27: Arduino: Baud is 115200 <0x76be5520>
                                50	12/27/16 15:58:48.240	luup_log:27: Device #1:mac= <0x76be5520>
                                50	12/27/16 15:58:48.241	luup_log:27:            category_num=19 <0x76be5520>
                                50	12/27/16 15:58:48.241	luup_log:27:            description=ZWave <0x76be5520>
                                50	12/27/16 15:58:48.241	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.242	luup_log:27:            id= <0x76be5520>
                                50	12/27/16 15:58:48.242	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.242	luup_log:27:            ip= <0x76be5520>
                                50	12/27/16 15:58:48.242	luup_log:27:            room_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.242	luup_log:27:            udn=uuid:4d494342-5342-5645-0001-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.243	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.243	luup_log:27:            invisible=true <0x76be5520>
                                50	12/27/16 15:58:48.243	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.243	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.243	luup_log:27:            device_num_parent=0 <0x76be5520>
                                50	12/27/16 15:58:48.243	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:ZWaveNetwork:1 <0x76be5520>
                                50	12/27/16 15:58:48.244	luup_log:27: Device #2:mac=000D6F000C5BC6E6 <0x76be5520>
                                50	12/27/16 15:58:48.244	luup_log:27:            category_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.244	luup_log:27:            description=Zigbee Network <0x76be5520>
                                50	12/27/16 15:58:48.244	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.245	luup_log:27:            id= <0x76be5520>
                                50	12/27/16 15:58:48.245	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.245	luup_log:27:            ip= <0x76be5520>
                                50	12/27/16 15:58:48.245	luup_log:27:            room_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.245	luup_log:27:            udn=uuid:4d494342-5342-5645-0002-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.246	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                50	12/27/16 15:58:48.246	luup_log:27:            invisible=true <0x76be5520>
                                50	12/27/16 15:58:48.246	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.246	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.246	luup_log:27:            device_num_parent=0 <0x76be5520>
                                50	12/27/16 15:58:48.247	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:ZigbeeNetwork:1 <0x76be5520>
                                50	12/27/16 15:58:48.247	luup_log:27: Device #3:mac=B4:A5:EF:ED:58:1D <0x76be5520>
                                50	12/27/16 15:58:48.247	luup_log:27:            category_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.247	luup_log:27:            description=Bluetooth Network <0x76be5520>
                                50	12/27/16 15:58:48.247	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.247	luup_log:27:            id= <0x76be5520>
                                50	12/27/16 15:58:48.248	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.248	luup_log:27:            ip= <0x76be5520>
                                50	12/27/16 15:58:48.248	luup_log:27:            room_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.248	luup_log:27:            udn=uuid:4d494342-5342-5645-0003-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.249	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                50	12/27/16 15:58:48.249	luup_log:27:            invisible=true <0x76be5520>
                                50	12/27/16 15:58:48.249	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.249	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.249	luup_log:27:            device_num_parent=0 <0x76be5520>
                                50	12/27/16 15:58:48.249	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:BluetoothNetwork:1 <0x76be5520>
                                50	12/27/16 15:58:48.250	luup_log:27: Device #20:mac= <0x76be5520>
                                50	12/27/16 15:58:48.250	luup_log:27:            category_num=17 <0x76be5520>
                                50	12/27/16 15:58:48.250	luup_log:27:            description=Bar South Temp <0x76be5520>
                                50	12/27/16 15:58:48.250	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.250	luup_log:27:            id=FE0000047CE7AE28:Temperature <0x76be5520>
                                50	12/27/16 15:58:48.251	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.251	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                50	12/27/16 15:58:48.251	luup_log:27:            room_num=10 <0x76be5520>
                                50	12/27/16 15:58:48.251	luup_log:27:            udn=uuid:4d494342-5342-5645-0014-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.251	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.252	luup_log:27:            invisible=false <0x76be5520>
                                50	12/27/16 15:58:48.252	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.252	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.252	luup_log:27:            device_num_parent=19 <0x76be5520>
                                50	12/27/16 15:58:48.252	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                50	12/27/16 15:58:48.253	luup_log:27: Device #21:mac= <0x76be5520>
                                50	12/27/16 15:58:48.253	luup_log:27:            category_num=17 <0x76be5520>
                                50	12/27/16 15:58:48.253	luup_log:27:            description=Guest Bedroom Temp <0x76be5520>
                                50	12/27/16 15:58:48.253	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.253	luup_log:27:            id=9A02146426ECFF28:Temperature <0x76be5520>
                                50	12/27/16 15:58:48.254	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.254	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                50	12/27/16 15:58:48.254	luup_log:27:            room_num=9 <0x76be5520>
                                50	12/27/16 15:58:48.254	luup_log:27:            udn=uuid:4d494342-5342-5645-0015-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.254	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.255	luup_log:27:            invisible=false <0x76be5520>
                                50	12/27/16 15:58:48.255	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.255	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.255	luup_log:27:            device_num_parent=19 <0x76be5520>
                                50	12/27/16 15:58:48.255	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                50	12/27/16 15:58:48.256	luup_log:27: Device #22:mac= <0x76be5520>
                                50	12/27/16 15:58:48.256	luup_log:27:            category_num=17 <0x76be5520>
                                50	12/27/16 15:58:48.256	luup_log:27:            description=Office Temp <0x76be5520>
                                50	12/27/16 15:58:48.256	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.257	luup_log:27:            id=C80000047D69C028:Temperature <0x76be5520>
                                50	12/27/16 15:58:48.257	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.257	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                50	12/27/16 15:58:48.257	luup_log:27:            room_num=7 <0x76be5520>
                                50	12/27/16 15:58:48.257	luup_log:27:            udn=uuid:4d494342-5342-5645-0016-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.258	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.258	luup_log:27:            invisible=false <0x76be5520>
                                50	12/27/16 15:58:48.258	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.258	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.258	luup_log:27:            device_num_parent=19 <0x76be5520>
                                50	12/27/16 15:58:48.258	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                50	12/27/16 15:58:48.259	luup_log:27: Device #23:mac= <0x76be5520>
                                50	12/27/16 15:58:48.259	luup_log:27:            category_num=17 <0x76be5520>
                                50	12/27/16 15:58:48.259	luup_log:27:            description=Master Bedroom Temp <0x76be5520>
                                50	12/27/16 15:58:48.259	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.259	luup_log:27:            id=5602146472A5FF28:Temperature <0x76be5520>
                                50	12/27/16 15:58:48.260	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.260	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                50	12/27/16 15:58:48.260	luup_log:27:            room_num=8 <0x76be5520>
                                50	12/27/16 15:58:48.260	luup_log:27:            udn=uuid:4d494342-5342-5645-0017-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.260	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.261	luup_log:27:            invisible=false <0x76be5520>
                                50	12/27/16 15:58:48.261	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.261	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.261	luup_log:27:            device_num_parent=19 <0x76be5520>
                                50	12/27/16 15:58:48.261	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                50	12/27/16 15:58:48.262	luup_log:27: Device #24:mac= <0x76be5520>
                                50	12/27/16 15:58:48.262	luup_log:27:            category_num=17 <0x76be5520>
                                50	12/27/16 15:58:48.262	luup_log:27:            description=Kitchen Hall Temp <0x76be5520>
                                50	12/27/16 15:58:48.262	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.262	luup_log:27:            id=9E000003A827AF28:Temperature <0x76be5520>
                                50	12/27/16 15:58:48.263	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.263	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                50	12/27/16 15:58:48.263	luup_log:27:            room_num=3 <0x76be5520>
                                50	12/27/16 15:58:48.263	luup_log:27:            udn=uuid:4d494342-5342-5645-0018-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.263	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.264	luup_log:27:            invisible=false <0x76be5520>
                                50	12/27/16 15:58:48.264	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.264	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.264	luup_log:27:            device_num_parent=19 <0x76be5520>
                                50	12/27/16 15:58:48.264	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                50	12/27/16 15:58:48.265	luup_log:27: Device #25:mac= <0x76be5520>
                                50	12/27/16 15:58:48.265	luup_log:27:            category_num=17 <0x76be5520>
                                50	12/27/16 15:58:48.265	luup_log:27:            description=Bar North Temp <0x76be5520>
                                50	12/27/16 15:58:48.265	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.265	luup_log:27:            id=7A000003A7472828:Temperature <0x76be5520>
                                50	12/27/16 15:58:48.266	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.266	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                50	12/27/16 15:58:48.266	luup_log:27:            room_num=10 <0x76be5520>
                                50	12/27/16 15:58:48.266	luup_log:27:            udn=uuid:4d494342-5342-5645-0019-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.266	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.267	luup_log:27:            invisible=false <0x76be5520>
                                50	12/27/16 15:58:48.267	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.267	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.267	luup_log:27:            device_num_parent=19 <0x76be5520>
                                50	12/27/16 15:58:48.267	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                50	12/27/16 15:58:48.268	luup_log:27: Device #26:mac= <0x76be5520>
                                50	12/27/16 15:58:48.268	luup_log:27:            category_num=17 <0x76be5520>
                                50	12/27/16 15:58:48.268	luup_log:27:            description=Outside Temp <0x76be5520>
                                50	12/27/16 15:58:48.268	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.268	luup_log:27:            id=F60000047DA93228:Temperature <0x76be5520>
                                50	12/27/16 15:58:48.269	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.269	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                50	12/27/16 15:58:48.269	luup_log:27:            room_num=13 <0x76be5520>
                                50	12/27/16 15:58:48.269	luup_log:27:            udn=uuid:4d494342-5342-5645-001a-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.269	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.269	luup_log:27:            invisible=false <0x76be5520>
                                50	12/27/16 15:58:48.270	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.270	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.270	luup_log:27:            device_num_parent=19 <0x76be5520>
                                50	12/27/16 15:58:48.270	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:TemperatureSensor:1 <0x76be5520>
                                50	12/27/16 15:58:48.270	luup_log:27: Device #27:mac= <0x76be5520>
                                50	12/27/16 15:58:48.271	luup_log:27:            category_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.271	luup_log:27:            description=MySensors Plugin <0x76be5520>
                                50	12/27/16 15:58:48.271	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.271	luup_log:27:            id= <0x76be5520>
                                50	12/27/16 15:58:48.271	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.272	luup_log:27:            ip= <0x76be5520>
                                50	12/27/16 15:58:48.272	luup_log:27:            room_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.272	luup_log:27:            udn=uuid:4d494342-5342-5645-001b-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.272	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                50	12/27/16 15:58:48.272	luup_log:27:            invisible=false <0x76be5520>
                                50	12/27/16 15:58:48.273	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.273	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.273	luup_log:27:            device_num_parent=0 <0x76be5520>
                                50	12/27/16 15:58:48.273	luup_log:27:            device_type=urn:schemas-arduino-cc:device:arduino:1 <0x76be5520>
                                50	12/27/16 15:58:48.273	luup_log:27: Device #5:mac= <0x76be5520>
                                50	12/27/16 15:58:48.274	luup_log:27:            category_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.274	luup_log:27:            description=Serial_Portlist_2144272085 <0x76be5520>
                                50	12/27/16 15:58:48.274	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.274	luup_log:27:            id=50009936 <0x76be5520>
                                50	12/27/16 15:58:48.274	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.275	luup_log:27:            ip=127.0.0.1 <0x76be5520>
                                50	12/27/16 15:58:48.275	luup_log:27:            room_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.275	luup_log:27:            udn=uuid:4d494342-5342-5645-0005-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.275	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                50	12/27/16 15:58:48.275	luup_log:27:            invisible=true <0x76be5520>
                                50	12/27/16 15:58:48.276	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.276	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.276	luup_log:27:            device_num_parent=0 <0x76be5520>
                                50	12/27/16 15:58:48.276	luup_log:27:            device_type=urn:micasaverde-org:device:SerialPortRoot:1 <0x76be5520>
                                50	12/27/16 15:58:48.276	luup_log:27: Device #4:mac= <0x76be5520>
                                50	12/27/16 15:58:48.277	luup_log:27:            category_num=14 <0x76be5520>
                                50	12/27/16 15:58:48.277	luup_log:27:            description=_Scene Controller <0x76be5520>
                                50	12/27/16 15:58:48.277	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.277	luup_log:27:            id=1 <0x76be5520>
                                50	12/27/16 15:58:48.277	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.278	luup_log:27:            ip= <0x76be5520>
                                50	12/27/16 15:58:48.278	luup_log:27:            room_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.278	luup_log:27:            udn=uuid:4d494342-5342-5645-0004-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.278	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.278	luup_log:27:            invisible=true <0x76be5520>
                                50	12/27/16 15:58:48.278	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.279	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.279	luup_log:27:            device_num_parent=1 <0x76be5520>
                                50	12/27/16 15:58:48.279	luup_log:27:            device_type=urn:schemas-micasaverde-com:device:SceneController:1 <0x76be5520>
                                50	12/27/16 15:58:48.279	luup_log:27: Device #6:mac= <0x76be5520>
                                50	12/27/16 15:58:48.279	luup_log:27:            category_num=13 <0x76be5520>
                                50	12/27/16 15:58:48.280	luup_log:27:            description=pl2303 <0x76be5520>
                                50	12/27/16 15:58:48.280	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.280	luup_log:27:            id=usb-xhci-hcd-1.1 <0x76be5520>
                                50	12/27/16 15:58:48.280	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.280	luup_log:27:            ip=127.0.0.1 <0x76be5520>
                                50	12/27/16 15:58:48.281	luup_log:27:            room_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.281	luup_log:27:            udn=uuid:4d494342-5342-5645-0006-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.281	luup_log:27:            subcategory_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.281	luup_log:27:            invisible=true <0x76be5520>
                                50	12/27/16 15:58:48.281	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.282	luup_log:27:            embedded=true <0x76be5520>
                                50	12/27/16 15:58:48.282	luup_log:27:            device_num_parent=5 <0x76be5520>
                                50	12/27/16 15:58:48.282	luup_log:27:            device_type=urn:micasaverde-org:device:SerialPort:1 <0x76be5520>
                                50	12/27/16 15:58:48.282	luup_log:27: Device #19:mac= <0x76be5520>
                                50	12/27/16 15:58:48.282	luup_log:27:            category_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.283	luup_log:27:            description=OWServer <0x76be5520>
                                50	12/27/16 15:58:48.283	luup_log:27:            user= <0x76be5520>
                                50	12/27/16 15:58:48.283	luup_log:27:            id= <0x76be5520>
                                50	12/27/16 15:58:48.283	luup_log:27:            pass= <0x76be5520>
                                50	12/27/16 15:58:48.283	luup_log:27:            ip=192.168.1.11 <0x76be5520>
                                50	12/27/16 15:58:48.284	luup_log:27:            room_num=0 <0x76be5520>
                                50	12/27/16 15:58:48.284	luup_log:27:            udn=uuid:4d494342-5342-5645-0013-000002fb1750 <0x76be5520>
                                50	12/27/16 15:58:48.284	luup_log:27:            subcategory_num=-1 <0x76be5520>
                                50	12/27/16 15:58:48.284	luup_log:27:            invisible=false <0x76be5520>
                                50	12/27/16 15:58:48.284	luup_log:27:            hidden=false <0x76be5520>
                                50	12/27/16 15:58:48.285	luup_log:27:            embedded=false <0x76be5520>
                                50	12/27/16 15:58:48.285	luup_log:27:            device_num_parent=0 <0x76be5520>
                                50	12/27/16 15:58:48.285	luup_log:27:            device_type=urn:cd-jackson-com:device:OWServer:1 <0x76be5520>
                                50	12/27/16 15:58:48.286	luup_log:27: Arduino: Sending: 0;0;3;0;2;Get Version <0x76be5520>
                                50	12/27/16 15:58:49.066	luup_log:27: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x739e5520>
                                50	12/27/16 15:58:49.067	luup_log:27: Arduino: Sending: 255;255;3;0;4;1 <0x739e5520>
                                50	12/27/16 15:58:50.547	luup_log:27: Arduino: Log: TSP:SANCHK:OK <0x739e5520>
                                50	12/27/16 15:58:51.085	luup_log:27: Arduino: Log: TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: <0x739e5520>
                                50	12/27/16 15:58:51.086	luup_log:27: Arduino: Sending: 255;255;3;0;4;2 <0x739e5520>
                                The highest device # it shows is 27 which doesn't even come close to hitting the 254 mark. I am baffled.
                                • dbemowskD
                                  dbemowskD
                                  Out of curiosity, what is the difference between log() and luup.log()?
                                    log is a local function defined a bit higher up in the file.
                                    Ok, what does the availableIds contain after the device loop?
                                    for i=1,MAX_RADIO_ID do
                                    log(availableIds[i]);
                                    end
                                    • dbemowskD
                                      dbemowskD
                                      So here is the code now:
                                      	local lastDev = 0
                                      			else
                                      			end
                                      			lastDev = k
                                      		end
                                      		-- end debugging
                                      		end
                                      	end
                                      	for i=1, MAX_RADIO_ID do
                                      		log("id #" .. i .. ": " .. (availableIds[i] and "TRUE" or "FALSE"));
                                      	end
                                      Just doing:
                                      crashed the script because the log method apparently couldn't handle boolean values. So I had it print the ID number and used a ternary operator to display true or false. I think that use of a ternary is correct for lua. Anyways, here is the log:
                                      50	12/27/16 19:45:33.285	luup_log:27: Device #19:mac= <0x77383520>
                                      50	12/27/16 19:45:33.285	luup_log:27:            category_num=0 <0x77383520>
                                      50	12/27/16 19:45:33.285	luup_log:27:            description=OWServer <0x77383520>
                                      50	12/27/16 19:45:33.285	luup_log:27:            user= <0x77383520>
                                      50	12/27/16 19:45:33.286	luup_log:27:            id= <0x77383520>
                                      50	12/27/16 19:45:33.286	luup_log:27:            pass= <0x77383520>
                                      50	12/27/16 19:45:33.286	luup_log:27:            ip=192.168.1.11 <0x77383520>
                                      50	12/27/16 19:45:33.286	luup_log:27:            room_num=0 <0x77383520>
                                      50	12/27/16 19:45:33.286	luup_log:27:            udn=uuid:4d494342-5342-5645-0013-000002fb1750 <0x77383520>
                                      50	12/27/16 19:45:33.286	luup_log:27:            subcategory_num=-1 <0x77383520>
                                      50	12/27/16 19:45:33.287	luup_log:27:            invisible=false <0x77383520>
                                      50	12/27/16 19:45:33.287	luup_log:27:            hidden=false <0x77383520>
                                      50	12/27/16 19:45:33.287	luup_log:27:            embedded=false <0x77383520>
                                      50	12/27/16 19:45:33.287	luup_log:27:            device_num_parent=0 <0x77383520>
                                      50	12/27/16 19:45:33.287	luup_log:27:            device_type=urn:cd-jackson-com:device:OWServer:1 <0x77383520>
                                      50	12/27/16 19:45:33.288	luup_log:27: Arduino: id #1: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.288	luup_log:27: Arduino: id #2: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.288	luup_log:27: Arduino: id #3: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.288	luup_log:27: Arduino: id #4: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.289	luup_log:27: Arduino: id #5: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.289	luup_log:27: Arduino: id #6: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.289	luup_log:27: Arduino: id #7: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.289	luup_log:27: Arduino: id #8: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.289	luup_log:27: Arduino: id #9: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.290	luup_log:27: Arduino: id #10: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.290	luup_log:27: Arduino: id #11: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.290	luup_log:27: Arduino: id #12: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.290	luup_log:27: Arduino: id #13: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.291	luup_log:27: Arduino: id #14: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.291	luup_log:27: Arduino: id #15: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.291	luup_log:27: Arduino: id #16: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.291	luup_log:27: Arduino: id #17: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.292	luup_log:27: Arduino: id #18: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.292	luup_log:27: Arduino: id #19: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.292	luup_log:27: Arduino: id #20: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.292	luup_log:27: Arduino: id #21: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.292	luup_log:27: Arduino: id #22: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.293	luup_log:27: Arduino: id #23: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.293	luup_log:27: Arduino: id #24: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.293	luup_log:27: Arduino: id #25: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.293	luup_log:27: Arduino: id #26: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.294	luup_log:27: Arduino: id #27: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.294	luup_log:27: Arduino: id #28: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.294	luup_log:27: Arduino: id #29: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.294	luup_log:27: Arduino: id #30: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.294	luup_log:27: Arduino: id #31: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.295	luup_log:27: Arduino: id #32: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.295	luup_log:27: Arduino: id #33: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.295	luup_log:27: Arduino: id #34: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.295	luup_log:27: Arduino: id #35: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.295	luup_log:27: Arduino: id #36: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.296	luup_log:27: Arduino: id #37: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.296	luup_log:27: Arduino: id #38: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.296	luup_log:27: Arduino: id #39: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.296	luup_log:27: Arduino: id #40: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.296	luup_log:27: Arduino: id #41: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.297	luup_log:27: Arduino: id #42: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.297	luup_log:27: Arduino: id #43: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.297	luup_log:27: Arduino: id #44: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.297	luup_log:27: Arduino: id #45: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.297	luup_log:27: Arduino: id #46: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.298	luup_log:27: Arduino: id #47: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.298	luup_log:27: Arduino: id #48: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.298	luup_log:27: Arduino: id #49: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.298	luup_log:27: Arduino: id #50: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.298	luup_log:27: Arduino: id #51: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.299	luup_log:27: Arduino: id #52: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.299	luup_log:27: Arduino: id #53: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.299	luup_log:27: Arduino: id #54: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.299	luup_log:27: Arduino: id #55: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.299	luup_log:27: Arduino: id #56: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.300	luup_log:27: Arduino: id #57: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.300	luup_log:27: Arduino: id #58: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.300	luup_log:27: Arduino: id #59: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.300	luup_log:27: Arduino: id #60: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.301	luup_log:27: Arduino: id #61: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.301	luup_log:27: Arduino: id #62: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.301	luup_log:27: Arduino: id #63: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.301	luup_log:27: Arduino: id #64: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.302	luup_log:27: Arduino: id #65: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.302	luup_log:27: Arduino: id #66: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.302	luup_log:27: Arduino: id #67: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.302	luup_log:27: Arduino: id #68: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.302	luup_log:27: Arduino: id #69: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.303	luup_log:27: Arduino: id #70: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.303	luup_log:27: Arduino: id #71: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.303	luup_log:27: Arduino: id #72: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.303	luup_log:27: Arduino: id #73: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.303	luup_log:27: Arduino: id #74: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.304	luup_log:27: Arduino: id #75: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.304	luup_log:27: Arduino: id #76: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.304	luup_log:27: Arduino: id #77: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.304	luup_log:27: Arduino: id #78: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.304	luup_log:27: Arduino: id #79: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.304	luup_log:27: Arduino: id #80: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.305	luup_log:27: Arduino: id #81: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.305	luup_log:27: Arduino: id #82: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.305	luup_log:27: Arduino: id #83: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.305	luup_log:27: Arduino: id #84: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.306	luup_log:27: Arduino: id #85: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.306	luup_log:27: Arduino: id #86: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.306	luup_log:27: Arduino: id #87: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.306	luup_log:27: Arduino: id #88: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.306	luup_log:27: Arduino: id #89: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.307	luup_log:27: Arduino: id #90: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.307	luup_log:27: Arduino: id #91: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.307	luup_log:27: Arduino: id #92: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.307	luup_log:27: Arduino: id #93: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.307	luup_log:27: Arduino: id #94: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.308	luup_log:27: Arduino: id #95: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.308	luup_log:27: Arduino: id #96: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.308	luup_log:27: Arduino: id #97: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.308	luup_log:27: Arduino: id #98: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.308	luup_log:27: Arduino: id #99: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.309	luup_log:27: Arduino: id #100: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.309	luup_log:27: Arduino: id #101: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.309	luup_log:27: Arduino: id #102: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.309	luup_log:27: Arduino: id #103: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.309	luup_log:27: Arduino: id #104: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.310	luup_log:27: Arduino: id #105: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.310	luup_log:27: Arduino: id #106: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.310	luup_log:27: Arduino: id #107: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.310	luup_log:27: Arduino: id #108: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.310	luup_log:27: Arduino: id #109: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.311	luup_log:27: Arduino: id #110: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.311	luup_log:27: Arduino: id #111: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.311	luup_log:27: Arduino: id #112: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.311	luup_log:27: Arduino: id #113: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.312	luup_log:27: Arduino: id #114: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.312	luup_log:27: Arduino: id #115: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.312	luup_log:27: Arduino: id #116: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.312	luup_log:27: Arduino: id #117: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.313	luup_log:27: Arduino: id #118: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.313	luup_log:27: Arduino: id #119: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.313	luup_log:27: Arduino: id #120: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.313	luup_log:27: Arduino: id #121: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.313	luup_log:27: Arduino: id #122: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.314	luup_log:27: Arduino: id #123: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.314	luup_log:27: Arduino: id #124: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.314	luup_log:27: Arduino: id #125: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.314	luup_log:27: Arduino: id #126: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.314	luup_log:27: Arduino: id #127: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.315	luup_log:27: Arduino: id #128: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.315	luup_log:27: Arduino: id #129: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.315	luup_log:27: Arduino: id #130: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.315	luup_log:27: Arduino: id #131: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.315	luup_log:27: Arduino: id #132: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.316	luup_log:27: Arduino: id #133: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.316	luup_log:27: Arduino: id #134: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.316	luup_log:27: Arduino: id #135: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.316	luup_log:27: Arduino: id #136: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.316	luup_log:27: Arduino: id #137: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.317	luup_log:27: Arduino: id #138: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.317	luup_log:27: Arduino: id #139: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.317	luup_log:27: Arduino: id #140: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.317	luup_log:27: Arduino: id #141: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.318	luup_log:27: Arduino: id #142: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.318	luup_log:27: Arduino: id #143: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.318	luup_log:27: Arduino: id #144: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.318	luup_log:27: Arduino: id #145: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.318	luup_log:27: Arduino: id #146: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.318	luup_log:27: Arduino: id #147: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.319	luup_log:27: Arduino: id #148: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.319	luup_log:27: Arduino: id #149: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.319	luup_log:27: Arduino: id #150: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.319	luup_log:27: Arduino: id #151: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.319	luup_log:27: Arduino: id #152: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.320	luup_log:27: Arduino: id #153: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.320	luup_log:27: Arduino: id #154: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.320	luup_log:27: Arduino: id #155: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.320	luup_log:27: Arduino: id #156: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.320	luup_log:27: Arduino: id #157: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.321	luup_log:27: Arduino: id #158: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.321	luup_log:27: Arduino: id #159: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.321	luup_log:27: Arduino: id #160: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.321	luup_log:27: Arduino: id #161: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.322	luup_log:27: Arduino: id #162: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.322	luup_log:27: Arduino: id #163: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.322	luup_log:27: Arduino: id #164: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.322	luup_log:27: Arduino: id #165: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.323	luup_log:27: Arduino: id #166: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.323	luup_log:27: Arduino: id #167: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.323	luup_log:27: Arduino: id #168: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.323	luup_log:27: Arduino: id #169: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.323	luup_log:27: Arduino: id #170: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.324	luup_log:27: Arduino: id #171: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.324	luup_log:27: Arduino: id #172: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.324	luup_log:27: Arduino: id #173: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.324	luup_log:27: Arduino: id #174: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.324	luup_log:27: Arduino: id #175: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.325	luup_log:27: Arduino: id #176: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.325	luup_log:27: Arduino: id #177: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.325	luup_log:27: Arduino: id #178: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.325	luup_log:27: Arduino: id #179: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.326	luup_log:27: Arduino: id #180: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.326	luup_log:27: Arduino: id #181: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.326	luup_log:27: Arduino: id #182: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.326	luup_log:27: Arduino: id #183: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.326	luup_log:27: Arduino: id #184: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.327	luup_log:27: Arduino: id #185: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.327	luup_log:27: Arduino: id #186: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.327	luup_log:27: Arduino: id #187: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.327	luup_log:27: Arduino: id #188: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.327	luup_log:27: Arduino: id #189: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.328	luup_log:27: Arduino: id #190: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.328	luup_log:27: Arduino: id #191: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.328	luup_log:27: Arduino: id #192: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.328	luup_log:27: Arduino: id #193: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.328	luup_log:27: Arduino: id #194: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.329	luup_log:27: Arduino: id #195: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.329	luup_log:27: Arduino: id #196: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.329	luup_log:27: Arduino: id #197: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.329	luup_log:27: Arduino: id #198: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.329	luup_log:27: Arduino: id #199: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.330	luup_log:27: Arduino: id #200: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.330	luup_log:27: Arduino: id #201: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.330	luup_log:27: Arduino: id #202: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.330	luup_log:27: Arduino: id #203: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.330	luup_log:27: Arduino: id #204: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.331	luup_log:27: Arduino: id #205: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.331	luup_log:27: Arduino: id #206: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.331	luup_log:27: Arduino: id #207: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.331	luup_log:27: Arduino: id #208: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.331	luup_log:27: Arduino: id #209: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.332	luup_log:27: Arduino: id #210: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.332	luup_log:27: Arduino: id #211: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.332	luup_log:27: Arduino: id #212: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.332	luup_log:27: Arduino: id #213: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.333	luup_log:27: Arduino: id #214: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.333	luup_log:27: Arduino: id #215: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.333	luup_log:27: Arduino: id #216: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.333	luup_log:27: Arduino: id #217: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.333	luup_log:27: Arduino: id #218: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.334	luup_log:27: Arduino: id #219: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.334	luup_log:27: Arduino: id #220: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.334	luup_log:27: Arduino: id #221: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.334	luup_log:27: Arduino: id #222: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.334	luup_log:27: Arduino: id #223: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.335	luup_log:27: Arduino: id #224: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.335	luup_log:27: Arduino: id #225: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.335	luup_log:27: Arduino: id #226: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.335	luup_log:27: Arduino: id #227: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.335	luup_log:27: Arduino: id #228: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.336	luup_log:27: Arduino: id #229: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.336	luup_log:27: Arduino: id #230: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.336	luup_log:27: Arduino: id #231: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.336	luup_log:27: Arduino: id #232: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.336	luup_log:27: Arduino: id #233: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.337	luup_log:27: Arduino: id #234: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.337	luup_log:27: Arduino: id #235: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.337	luup_log:27: Arduino: id #236: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.337	luup_log:27: Arduino: id #237: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.338	luup_log:27: Arduino: id #238: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.338	luup_log:27: Arduino: id #239: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.338	luup_log:27: Arduino: id #240: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.338	luup_log:27: Arduino: id #241: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.338	luup_log:27: Arduino: id #242: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.338	luup_log:27: Arduino: id #243: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.339	luup_log:27: Arduino: id #244: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.339	luup_log:27: Arduino: id #245: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.339	luup_log:27: Arduino: id #246: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.339	luup_log:27: Arduino: id #247: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.339	luup_log:27: Arduino: id #248: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.340	luup_log:27: Arduino: id #249: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.340	luup_log:27: Arduino: id #250: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.340	luup_log:27: Arduino: id #251: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.340	luup_log:27: Arduino: id #252: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.340	luup_log:27: Arduino: id #253: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.341	luup_log:27: Arduino: id #254: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.341	luup_log:27: Arduino: id #255: TRUE <0x77383520>
                                      50	12/27/16 19:45:33.342	luup_log:27: Arduino: Sending: 0;0;3;0;2;Get Version <0x77383520>
                                      50	12/27/16 19:45:36.719	luup_log:27: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x74183520>
                                      50	12/27/16 19:45:36.721	luup_log:27: Arduino: Log: TSP:MSG:BC <0x74183520>
                                      50	12/27/16 19:45:36.724	luup_log:27: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x74183520>
                                      50	12/27/16 19:45:36.727	luup_log:27: Arduino: Log: TSP:CHKUPL:OK <0x74183520>
                                      50	12/27/16 19:45:36.729	luup_log:27: Arduino: Log: TSP:MSG:GWL OK <0x74183520>
                                      50	12/27/16 19:45:37.738	luup_log:27: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x74183520>
                                      • dbemowskD
                                        dbemowskD
                                        OK, here is another code change I did for testing. I added some logging to the nextAvailableRadioId() method which when I ran it brought up some questions in my head. Here is the code:
                                        local function nextAvailiableRadioId()
                                        	for i=1,255 do
                                        		if (availableIds[i] == true) then
                                        			availableIds[i] = false
                                        			log("Setting next available radio ID to " .. i)
                                        			return i
                                        		end
                                        	end
                                        	log("No available IDs")
                                        	return 255
                                        end
                                        I started the luup engine with the node powered off (battery disconnected). I waited a bit for the engine to initialize and then plugged in the battery. Below is the log as I see it with some annotations:
                                        0_1482904200466_upload-76e2a0fe-d517-45bf-b92e-f325cd17c7d3
                                        If any of the annotations in the screen shot are incorrect, please correct me. Now for my questions:
                                        • Shouldn't the nextAvailiableRadioId() method only be called when in inclusion mode? Clearly there were a few requests which tried to assign out IDs prior to my starting inclusion.
                                        • It appears that the node is not responding to the node ID response. What should I see in the serial monitor from the debug information in the node debug log to tell if it receives the response and if it responds back?
                                        • If a node doesn't respond back that it accepted that node ID, should the plugin mark that ID as unavailable? Clearly that is what is happening. Is there even a way to tell if the node responds back saying that it got the ID?
                                        • Is the availableIds[] array of 255 items only for the MySensors plugin, or is it global to all the plugins?
                                          I think the main part in this test is that the node is not accepting the ID given to it by Vera. When I ran Domoticz, I had no trouble with ID assignments. The next part though is to see what happens once the node parent ID is accepted and presentation starts. I am wondering if I am going to run into the same issues I ran into when I statically set the node ID.
                                          nextAvailiableRadioId will be called if an id request comes in (even if inclusion mode is off). The array is not global. It's one array per gatewateway.
                                          I wonder why https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L299-L307 does not return the first available id in your setup.
