  3. Vs2015+Visual Micro + MySensors
5 Posts 3 Posters 2.0k Views 3 Watching
  • yoramY
    yoramY
    yoram
    I've tried to migrate from the arduino IDE to the VS2015 Community+Visual Micro support for Arduino.
    When attempting to compile a sketch with MyMessage and receive handler I get an error "BatteryPoweredWaterLeakSensor.ino:39:20: error: 'MyMessage' does not name a type"
    When excluding the define of MyMessage and the receive handler there is no problem and project compile with no errors:
    Compiling the same sketch with the Arduino IDE or when removing the MyMessage usage I get no errors.
    Any idea?
      Do the vanilla examples work? (like https://github.com/mysensors/MySensors/blob/master/examples/DimmableLight/DimmableLight.ino )
      You'll probably get the same error but it might be worth checking.
      • yoramY
        yoramY
        yoram
        OK,
        I was able to find the RCA.
        Apparently, the issue was related to the location of the #include and the const variables.
        The following code generates error
        const int SENSOR_ANALOG_PINS[] = { A0, A1 };
        #define CHILD_ID_SENSOR		0
        #define CHILD_ID_VOLTAGE	1
        MyMessage msgTripped(CHILD_ID_SENSOR, V_TRIPPED);
        MyMessage msgVoltage(CHILD_ID_VOLTAGE, V_VOLTAGE);
        The following code is GOOD. Hence, the const values has to be defined post the header include
          Strange. To my knowledge, that shouldn't matter. But great that you found a solution.
          • S
            SiLeX
            wrote on last edited by SiLeX
            I can absolutely confirm this with VS2015, Visual Micro and MySensors 2.1.1. This is clearly a kind of merging, that is done by Visual Micro.
            All includes have to be made BEFORE the first line of code is executed. The initialization of your SENSOR_ANALOG_PINS array is such a line of code.
            Just posting it to keep it visible and well-scored at search engines, as this is SOLVED and works fine. Thank you!
