  3. Home Assistant
  4. another relay problem....
22 Posts 4 Posters 7.9k Views 4 Watching
  • G
    G
    Gefkuz
    Sorry to post another relay problem.
    I read lot of problems solved but not of thos issues resolved mine.
    I copy paste the sketch on HA website for relay sketch on my working arduino.
    I switch on the arduino and thiks is what I see on py log:
    INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1):
    62.255.244.49
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-16-0 s=1,c=1,t=0,pt=7,l=5,sg=
    0:23.7
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 18-18-0 s=255,c=3,t=15,pt=2,l=2
    ,sg=0:0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 18-18-0 s=255,c=0,t=17,pt=0,l=5
    ,sg=0:1.5.4
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 18-18-0 s=255,c=3,t=6,pt=1,l=1,
    sg=0:0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-18-18 s=255,c=3,t=6,pt=0,l=
    1,sg=0,st=ok:M
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 18-18-0 s=255,c=3,t=11,pt=0,l=5
    ,sg=0:Relay
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 18-18-0 s=255,c=3,t=12,pt=0,l=3
    ,sg=0:1.0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 18-18-0 s=1,c=0,t=3,pt=0,l=0,sg
    =0:
    WARNING:mysensors.mysensors:child_id 1 already exists in children, cannot add ch
    ild
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 18-18-0 s=1,c=1,t=2,pt=2,l=2,sg
    =0:0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 5-16-0 s=6,c=1,t=23,pt=7,l=5,sg
    =0:6.0
    INFO:homeassistant.components.http:Serving /api/camera_proxy/camera.london_road
    to 192.168.1.1 (auth: True)
    62.255.244.49
    62.255.244.49
    The relay is registered I think, but no line with "add sensor" and no existence in HA......
    Another thing.. in configuration.yaml, I want t make a persistent file for mysensor, but don't how to. What path can I write to have the persistent file in .homeasssistant folder
    mysensors:
     gateways:
     - device: 'COM5'
     persistence_file: 'mysensors.json'
     baud_rate: 115200
     debug: true
     persistence: true
     version: '1.5'
     optimistic: 'true'
    I'm on windows 10
    and last version of HA.
    and mysensor 1.5.2
    Please help :(
    Thanks in advance.
    TheoLT 1 Reply Last reply
    • G Gefkuz
      62.255.244.49
      0:23.7
      ,sg=0:0
      ,sg=0:1.5.4
      sg=0:0
      1,sg=0,st=ok:M
      ,sg=0:Relay
      ,sg=0:1.0
      =0:
      ild
      =0:0
      =0:6.0
      62.255.244.49
      62.255.244.49
      mysensors:
       gateways:
       - device: 'COM5'
       baud_rate: 115200
       debug: true
       persistence: true
       version: '1.5'
       optimistic: 'true'
      I'm on windows 10
      and mysensor 1.5.2
      Please help :(
      Thanks in advance.
      TheoLT
      TheoLT
      TheoL
      @Gefkuz I suggest you take this as a lead in solving your problem:
      ild
      K 1 Reply Last reply
      • TheoLT TheoL
        ild
        K
        K
        koen01
        ild
        Search for initial value sending for HASS and mysensors 2.0.0
        • G
          G
          Gefkuz
          wrote on last edited by Gefkuz
          The message "already exist" is not displayed at the first power up.
          And in my log, We can see the first value sended :
          =0:0
          Are we ok with this value sended???
          • G
            G
            Gefkuz
            Is it necessary to migrate to mysensors 2.0?
            • G Gefkuz
              TheoLT
              TheoLT
              TheoL
              @Gefkuz It's hard to tell. I tried to look up the sketch on the HA site. But wasn't able to find it during lunch break. Would you mind posting a linl?
              • G
                G
                Gefkuz
                here is a link to the sketch i'm using :
                https://home-assistant.io/components/switch.mysensors/#example-sketch
                I'm using the first one. Simple switch sketch.
                • G Gefkuz
                  TheoLT
                  TheoLT
                  TheoL
                  @Gefkuz I'm not sure who's responsible of generating the warning
                  ild
                  I find it hard to believe that the gateway is generating this warning. But maybe @Hek or @tekka can tell us more about this. I haven't seen this warning before.
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    Hi!
                    Everything in the log looks OK, except the node already has the child registered. But you said that doesn't happen when you start the arduino the first time after restart of hass? In that case it should be fine. Otherwise it could be an indication that there are already children loaded from persistence, which could conflict with the new settings.
                    It's not necessary to upgrade to mysensors 2.0.0. That's not fully supported either.
                    Try setting persistence to false, restart hass and start your arduino node again. If that doesn't work I'd like to see the log from the start of hass with all lines regarding mysensors.
                    • TheoLT TheoL
                      ild
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      That would be me.:smile:
                      • G
                        G
                        Gefkuz
                        No more result with persistent file to none (#) and persistent to false.
                        Deleting mysensor1.picle file.
                        Restarting homeassistant.
                        modify the switch to nodeid 56.
                        launch the switch.
                        And same things.....
                        For information, my temperatures sensors (mysensors) working perfectly.
                        • G
                          G
                          Gefkuz
                          I don't have some log file... can you tell me where it is in the folders?
                          • martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            You said you're using mysensors 1.5.2, but the log indicates that atleast the node in question is 1.5.4. Is the gateway also on 1.5.4? There was a bug in 1.5.2-1.5.3 regarding payloads.
                            • G Gefkuz
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @Gefkuz
                              The log is usually in the same directory as the configuration.
                              I prefer to just start hass manually and look/copy the output at the console.
                              • G
                                G
                                Gefkuz
                                i check it now
                                  TheoLT
                                  TheoLT
                                  TheoL
                                  @martinhjelmare I already had a gut feeling that the gateway doesn't generate message's like this. Because it was designed to be a gateway with as less logic in it as possible ;-) Glad you cleared that one.
                                  • G
                                    G
                                    Gefkuz
                                    I reprogram the gateway with same pc than the switch, then the same mysensor library.
                                    I launch homeassistant without persistent file mysensor.
                                    And same problem... :( :(
                                    Microsoft Windows [version 6.3.9600]
                                    (c) 2013 Microsoft Corporation. Tous droits réservés.
                                    C:\Users\Fabien>py -m homeassistant
                                    Config directory: C:\Users\Fabien\AppData\Roaming\.homeassistant
                                    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas
                                    sistant, service=turn_off>
                                    sistant, service=turn_on>
                                    sistant, service=toggle>
                                    sistant, service=reload_core_config>
                                    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=persis
                                    tent_notification, service=create>
                                    INFO:homeassistant.bootstrap:Home Assistant core initialized
                                    INFO:homeassistant.loader:Loaded script from homeassistant.components.script
                                    INFO:homeassistant.loader:Loaded group from homeassistant.components.group
                                    INFO:homeassistant.loader:Loaded input_select from homeassistant.components.inpu
                                    t_select
                                    INFO:homeassistant.loader:Loaded media_player from homeassistant.components.medi
                                    a_player
                                    INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                    INFO:homeassistant.loader:Loaded weblink from homeassistant.components.weblink
                                    INFO:homeassistant.loader:Loaded automation from homeassistant.components.automa
                                    tion
                                    INFO:homeassistant.loader:Loaded shell_command from homeassistant.components.she
                                    ll_command
                                    INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
                                    INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysenso
                                    rs
                                    INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                    INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                    INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                    INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                    INFO:homeassistant.loader:Loaded input_slider from homeassistant.components.inpu
                                    t_slider
                                    INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recor
                                    der>
                                    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=input_
                                    select, service=select_option>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, en
                                    tity_id=input_select.station, new_state=<state input_select.station=BBC Radio Be
                                    rkshire; options=['BBC Radio Berkshire', 'BBC Radio Two', 'Heart'], friendly_nam
                                    e=Station, icon=mdi:radio-tower @ 2016-08-17T21:07:10.881326+02:00>>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=input
                                    _select>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                    ERROR:homeassistant.bootstrap:Invalid config for [media_player]: required key no
                                    t provided @ data['platform']. Got None
                                    tity_id=weblink.freebox, new_state=<state weblink.freebox=http://192.168.1.1; fr
                                    iendly_name=FreeBox, icon=mdi:router-wireless @ 2016-08-17T21:07:11.146946+02:00
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=webli
                                    nk>
                                    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=shell_
                                    command, service=battery>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=shell
                                    _command>
                                    INFO:homeassistant.loader:Loaded camera.generic from homeassistant.components.ca
                                    mera.generic
                                    tity_id=camera.london_road, new_state=<state camera.london_road=idle; entity_pic
                                    ture=/api/camera_proxy/camera.london_road?token=60691888, access_token=60691888,
                                     friendly_name=London Road @ 2016-08-17T21:07:11.240702+02:00>>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camer
                                    a>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysen
                                    sors>
                                    ERROR:homeassistant.bootstrap:Invalid config for [switch]: required key not prov
                                    INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                    INFO:homeassistant.loader:Loaded binary_sensor from homeassistant.components.bin
                                    ary_sensor
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=senso
                                    r>
                                    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=load
                                    _platform.sensor, platform=mysensors, discovered=>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=binar
                                    y_sensor>
                                    _platform.binary_sensor, platform=mysensors, discovered=>
                                    INFO:homeassistant.loader:Loaded light from homeassistant.components.light
                                    INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.
                                    sensor.mysensors
                                    INFO:homeassistant.loader:Loaded binary_sensor.mysensors from homeassistant.comp
                                    onents.binary_sensor.mysensors
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=front
                                    end>
                                    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light,
                                     service=turn_on>
                                     service=turn_off>
                                     service=toggle>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light
                                    _platform.light, platform=mysensors, discovered=>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=histo
                                    ry>
                                    slider, service=select_value>
                                    tity_id=input_slider.volume, new_state=<state input_slider.volume=50; max=100, s
                                    tep=1, min=0, friendly_name=Volume, icon=mdi:volume-high @ 2016-08-17T21:07:13.0
                                    53199+02:00>>
                                    INFO:homeassistant.loader:Loaded light.mysensors from homeassistant.components.l
                                    ight.mysensors
                                    _slider>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=group
                                    tity_id=script.battery, new_state=<state script.battery=off; friendly_name=batte
                                    ry, icon=mdi:refresh @ 2016-08-17T21:07:13.178206+02:00>>
                                    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=script
                                    , service=battery>
                                    , service=turn_on>
                                    , service=turn_off>
                                    , service=toggle>
                                    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=scrip
                                    t>
                                    ERROR:homeassistant.bootstrap:Invalid config for [automation]: required key not
                                    provided @ data['action']. Got None
                                    required key not provided @ data['trigger']. Got None
                                    INFO:homeassistant.core:Starting Home Assistant (17 threads)
                                    INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                    INFO:homeassistant.core:Timer:starting
                                    INFO:mysensors.mysensors:Trying to connect to COM4
                                    INFO:mysensors.mysensors:COM4 is open...
                                    INFO:mysensors.mysensors:Connected to COM4
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, dist
                                    ance=0
                                    sistant, service=stop>
                                    sistant, service=restart>
                                    INFO:homeassistant.components.http:Serving /api/stream to 192.168.1.1 (auth: Tru
                                    e)
                                    INFO:homeassistant.components.http:Serving /api/bootstrap to 192.168.1.1 (auth:
                                    True)
                                    62.255.244.49
                                    62.255.244.49
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=1,c=1,t=0,pt=7,l=5,sg
                                    =0:28.4
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-16-0 s=1,c=1,t=0,pt=7,l=5,sg=
                                    0:29.8
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-16-0 s=0,c=1,t=1,pt=7,l=5,sg=
                                    0:37.6
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=3,t=15,pt=2,l=2
                                    ,sg=0:0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=0,t=17,pt=0,l=5
                                    ,sg=0:1.5.4
                                    INFO:homeassistant.components.mysensors:No sketch_name: node 55
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=3,t=6,pt=1,l=1,
                                    sg=0:0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-55-55 s=255,c=3,t=6,pt=0,l=
                                    1,sg=0,st=ok:M
                                    62.255.244.49
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=3,t=11,pt=0,l=5
                                    ,sg=0:Relay
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=3,t=12,pt=0,l=3
                                    ,sg=0:1.0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=4,c=0,t=3,pt=0,l=0,sg
                                    =0:
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=4,c=1,t=2,pt=0,l=3,sg
                                    =0:0.0
                                    62.255.244.49
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=0,t=18,pt=0,l=5
                                    ,sg=0:1.5.1
                                    INFO:homeassistant.components.mysensors:No sketch_name: node 16
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=3,t=6,pt=1,l=1,
                                    sg=0:0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-16-16 s=255,c=3,t=6,pt=0,l=
                                    1,sg=0,st=ok:M
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=3,c=1,t=18,pt=7,l=5,sg=
                                    0:73094056.0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-16-0 s=0,c=1,t=1,pt=7,l=5,sg=
                                    0:51.8
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=4,c=1,t=18,pt=7,l=5,sg=
                                    0:49055452.0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=5,c=1,t=39,pt=7,l=5,sg=
                                    0:0.0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=6,c=1,t=39,pt=7,l=5,sg=
                                    0:0.0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0
                                    :86.9
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=7,c=1,t=39,pt=7,l=5,sg=
                                    0:5.0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=2,c=1,t=2,pt=7,l=5,sg=0
                                    :0.0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=3,t=11,pt=0,l=1
                                    1,sg=0:Sonde Salon
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=3,t=12,pt=0,l=3
                                    ,sg=0:1.0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=0,c=0,t=7,pt=0,l=8,sg
                                    =0:Humidite
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=1,c=0,t=6,pt=0,l=11,s
                                    g=0:Temperature
                                    62.255.244.49
                                    =0:28.6
                                    INFO:homeassistant.components.mysensors:Adding new devices: <Entity Sonde Salon
                                    16 1: None>
                                    tity_id=sensor.sonde_salon_16_1, new_state=<state sensor.sonde_salon_16_1=unavai
                                    lable; friendly_name=Sonde Salon 16 1 @ 2016-08-17T21:07:48.412571+02:00>>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state s
                                    ensor.sonde_salon_16_1=unavailable; friendly_name=Sonde Salon 16 1 @ 2016-08-17T
                                    21:07:48.412571+02:00>, entity_id=sensor.sonde_salon_16_1, new_state=<state sens
                                    or.sonde_salon_16_1=28.6; node_id=16, unit_of_measurement=°C, child_id=1, batter
                                    y_level=0, device=COM4, V_TEMP=28.6, friendly_name=Sonde Salon 16 1 @ 2016-08-17
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=0,c=1,t=1,pt=7,l=5,sg
                                    =0:1.0
                                    16 0: None>
                                    tity_id=sensor.sonde_salon_16_0, new_state=<state sensor.sonde_salon_16_0=unavai
                                    lable; friendly_name=Sonde Salon 16 0 @ 2016-08-17T21:07:50.412569+02:00>>
                                    ensor.sonde_salon_16_0=unavailable; friendly_name=Sonde Salon 16 0 @ 2016-08-17T
                                    21:07:50.412569+02:00>, entity_id=sensor.sonde_salon_16_0, new_state=<state sens
                                    or.sonde_salon_16_0=1.0; node_id=16, friendly_name=Sonde Salon 16 0, child_id=0,
                                     battery_level=0, V_HUM=1.0, device=COM4, unit_of_measurement=% @ 2016-08-17T21:
                                    07:50.443821+02:00>>
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=3,t=1,pt=0,l=0,
                                    sg=0:
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-16-16 s=255,c=3,t=1,pt=0,l=
                                    10,sg=0,st=ok:14714608
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 5-16-0 s=1,c=1,t=0,pt=7,l=5,sg=
                                    0:29.6
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 5-16-0 s=0,c=1,t=1,pt=7,l=5,sg=
                                    0:27.1
                                    really, I don't know what's happen.
                                    • martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      I think I've found it. The switch platform errors on loading:
                                      ERROR:homeassistant.bootstrap:Invalid config for [switch]: required key not provided @ data['platform']. Got None
                                      The S_TYPE is 3 and V_TYPE is 2 of your child which maps to the switch platform in home assistant. The mysensors component will try to load the switch platform via discovery but if something else tries to config the same platform and fails, mysensors will also be affected in that platform.
                                      Can you provide relevant excerpt from your config, mysensors and switch entries?
                                      • G
                                        G
                                        Gefkuz
                                        Haha, I think we ahve something.
                                        My mysensor config is
                                        mysensors:
                                         gateways:
                                         - device: 'COM4'
                                        # persistence_file: 'mysensors.json'
                                         baud_rate: 115200
                                         debug: true
                                         persistence: false
                                         version: '1.5'
                                         optimistic: 'true'
                                        and switch file is empty.... I don't see anything about that in homeassistant website...
                                        What can I do?
                                        • G
                                          G
                                          Gefkuz
                                          I make some tests.
                                          I switch v_type and s_type values in my sketch.
                                          And when I write S_BINARY or S_LIGHT........ no add sensor appeared....
