  3. Can not compile serial gateway on codebender or ide
14 Posts 2 Posters 2.9k Views 2 Watching
  • mugsM
    mugsM
    mugs
    I have tried to compile the serial gateway code before uploading to my nano and I keep getting errors. I have used code bender and the IDE. Used the libraries from 1.4 and 1.5 with no difference.
    The below text is the error from codebender.
    *Looks like your project uses header files or libraries that do not exist in our system, in your personal libraries or in your sketch. More info
    In file included from (sketch file) SerialGateway.ino:50:
    (personal library file) MySensors/MySensor.h:158:70: error: unknown type name 'MyHwDriver'
        MySensor(MyTransport &radio =*new MyTransportNRF24(), MyHw &hw=*new MyHwDriver()
    (sketch file) SerialGateway.ino:71:1: error: unknown type name 'MyHwATMega328'
    MyHwATMega328 hw;
    The below text is from Arduino IDE.
    *Arduino: 1.6.10 (Windows 10), Board: "Arduino Nano, ATmega168"
    In file included from X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:12:0:
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:39:28: error: 'DEFAULT_CE_PIN' was not declared in this scope
    MyGateway(uint8_t _cepin=DEFAULT_CE_PIN, uint8_t _cspin=DEFAULT_CS_PIN, uint8_t _inclusion_time = 1, int8_t _inclusion_pin=-1, int8_t _rx=-1, int8_t _tx=-1, int8_t _er=-1);
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:39:59: error: 'DEFAULT_CS_PIN' was not declared in this scope
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp: In constructor 'MyGateway::MyGateway(uint8_t, uint8_t, uint8_t, int8_t, int8_t, int8_t, int8_t)':
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:30:163: error: no matching function for call to 'MySensor::MySensor(uint8_t&, uint8_t&)'
    MyGateway::MyGateway(uint8_t _cepin, uint8_t _cspin, uint8_t _inclusion_time, int8_t _inclusion_pin, int8_t _rx, int8_t _tx, int8_t _er) : MySensor(_cepin, _cspin) {
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:30:163: note: candidates are:
    In file included from X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:15:0,
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:158:2: note: MySensor::MySensor(MyTransport&, MyHw&)
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:158:2: note: no known conversion for argument 1 from 'uint8_t {aka unsigned char}' to 'MyTransport&'
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:149:7: note: constexpr MySensor::MySensor(const MySensor&)
    class MySensor
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:149:7: note: candidate expects 1 argument, 2 provided
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:149:7: note: constexpr MySensor::MySensor(MySensor&&)
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp: In member function 'void MyGateway::begin(rf24_pa_dbm_e, uint8_t, rf24_datarate_e, void ()(char))':
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:44:20: error: 'setupRepeaterMode' was not declared in this scope
    setupRepeaterMode();
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:87:39: error: 'setupRadio' was not declared in this scope
    setupRadio(paLevel, channel, dataRate);
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:88:36: error: 'BASE_RADIO_ID' was not declared in this scope
    RF24::openReadingPipe(WRITE_PIPE, BASE_RADIO_ID);
    X:\Program Files\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:90:23: error: cannot call member function 'void RF24::startListening()' without object
    RF24::startListening();
    exit status 1
    Error compiling for board Arduino Nano.
    Invalid library found in X:\Program Files\Program Files (x86)\Arduino\libraries\libraries: X:\Program Files\Program Files (x86)\Arduino\libraries\libraries
    option enabled in File -> Preferences.
    Thanks in advance
    • F
      F
      flopp
      i think you have to correct how the text i shown here, now it looks very strange.
      When you edit you can see how it will look like on the right side(if you use a computer)
      Is you libraries installed on drive X?
      • mugsM
        mugsM
        mugs
        I had just copied the messages strait on to here, probably why it looks weird.
        I had the libraries in drive "x", They were added to the arduino libraries.
        • F
          F
          flopp
          is it installed as shown above?
          I have it installed at
          C:\Program Files (x86)
          • mugsM
            mugsM
            mugs
            Yeah thats how it was installed. I have removed it all and reinstalled it back on to C drive. Still getting errors.
            The example won't even compile directly on the codebender website
            https://codebender.cc/example/MySensor/SerialGateway#SerialGateway.ino
            • F
              F
              flopp
              Do you have an ATmega168 or ATmega328?
              You have selected ATmega168
              • mugsM
                mugsM
                mugs
                I am not sure :s.
                But would that even matter if I can't verify the code before attempting to upload?
                F 1 Reply Last reply
                • mugsM mugs
                  I am not sure :s.
                  F
                  F
                  flopp
                  @mugs
                  You need to know what ATmega you have.
                  Yes it matters because they have different memory size.
                  I tried to compile Serial GW with Atmega168, not possible because sketch is too big.
                  Try with ATmega328 instead
                  • mugsM
                    mugsM
                    mugs
                    It is the 328 I have.
                    • mugsM
                      mugsM
                      mugs
                      Just tried again and the errors are slightly different. Sorry about the formatting.
                      Arduino: 1.6.10 (Windows 10), Board: "Arduino Nano, ATmega328"
                      WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
                      Build options changed, rebuilding all
                      In file included from C:\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:28:0,
                                   from C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:15,
                                   from C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:12:
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyTransportNRF24.h:38:30: error: 'RF24_CE_PIN' was not declared in this scope
                      MyTransportNRF24(uint8_t ce=RF24_CE_PIN, uint8_t cs=RF24_CS_PIN, uint8_t paLevel=RF24_PA_LEVEL);
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyTransportNRF24.h:38:54: error: 'RF24_CS_PIN' was not declared in this scope
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyTransportNRF24.h:38:83: error: 'RF24_PA_LEVEL' was not declared in this scope
                      In file included from C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:15:0,
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:158:53: error: call to 'MyTransportNRF24::MyTransportNRF24(uint8_t, uint8_t, uint8_t)' uses the default argument for parameter 1, which is not yet defined
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:158:53: error: call to 'MyTransportNRF24::MyTransportNRF24(uint8_t, uint8_t, uint8_t)' uses the default argument for parameter 2, which is not yet defined
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:158:53: error: call to 'MyTransportNRF24::MyTransportNRF24(uint8_t, uint8_t, uint8_t)' uses the default argument for parameter 3, which is not yet defined
                      In file included from C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:12:0:
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:39:28: error: 'DEFAULT_CE_PIN' was not declared in this scope
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:39:59: error: 'DEFAULT_CS_PIN' was not declared in this scope
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:42:36: error: 'RF24_PA_LEVEL_GW' was not declared in this scope
                      void begin(rf24_pa_dbm_e paLevel=RF24_PA_LEVEL_GW, uint8_t channel=RF24_CHANNEL, rf24_datarate_e dataRate=RF24_DATARATE, void (*dataCallback)(char *)=NULL);
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:42:70: error: 'RF24_CHANNEL' was not declared in this scope
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.h:42:109: error: 'RF24_DATARATE' was not declared in this scope
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp: In constructor 'MyGateway::MyGateway(uint8_t, uint8_t, uint8_t, int8_t, int8_t, int8_t, int8_t)':
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:30:163: error: no matching function for call to 'MySensor::MySensor(uint8_t&, uint8_t&)'
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:30:163: note: candidates are:
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:158:2: note: MySensor::MySensor(MyTransport&, MyHw&)
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:158:2: note: no known conversion for argument 1 from 'uint8_t {aka unsigned char}' to 'MyTransport&'
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:149:7: note: constexpr MySensor::MySensor(const MySensor&)
                      class MySensor
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:149:7: note: candidate expects 1 argument, 2 provided
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MySensor.h:149:7: note: constexpr MySensor::MySensor(MySensor&&)
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp: In member function 'void MyGateway::begin(rf24_pa_dbm_e, uint8_t, rf24_datarate_e, void ()(char))':
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:40:15: error: 'BAUD_RATE' was not declared in this scope
                      Serial.begin(BAUD_RATE);
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:44:20: error: 'setupRepeaterMode' was not declared in this scope
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:87:39: error: 'setupRadio' was not declared in this scope
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:88:36: error: 'BASE_RADIO_ID' was not declared in this scope
                      C:\Program Files (x86)\Arduino\libraries\MySensors\MyGateway.cpp:90:23: error: cannot call member function 'void RF24::startListening()' without object
                      exit status 1
                      • F
                        F
                        flopp
                        This is normal, I also get this.
                        I am using Arduino 1.6.8, Arduino Board 1.6.12, MySensors 1.5.1, Windows 10
                        I can Compile Serial GW, Nano 328 with no problem.
                        Maybe you can try to install IDE 1.6.8
                        • F
                          F
                          flopp
                          wrote on last edited by flopp
                          Check here
                          https://forum.mysensors.org/topic/4570/mysensors-ethernet-gw-w5100-problem/5
                          Problem with 1.6.9 and 1.6.10 but they were using MySensors 2.0
                          • mugsM
                            mugsM
                            mugs
                            I have the exact versions as you now . Verified and uploaded perfectly.
                            Thanks for your help
                            • mugsM mugs
                              F
                              F
                              flopp
                              @mugs
                              Nice, no problem.
