  3. Home Assistant
  4. Reconnect MySensors Ethernet Gateway when it is back
2 Posts 1 Posters 1.4k Views 1 Watching
  • afenoA
    afenoA
    afeno
    I noticed that HA is not trying to reconnect the MySensors Ethernet gateway when it is temporary disconnected from the network.
    Maybe this is not happening very often when using the Ethernet gateway. But with the new MySensors ESP8266 Wifi gateway it might happen from time to time. And it is a pity to have to restart HA to get it connected again.
    Is this the normal behaviour or something is failing in my setup? I have to restart HA every time that the Gateway is temporary disconnected from the LAN.
    Any suggestion? Can this be improved? Any Idea?
    Thank you.
    • afenoA
      afenoA
      afeno
      If you want more information about this known issue, please follow this thread on the HA forum:
      https://community.home-assistant.io/t/reconnect-mysensors-ethernet-gateway-when-it-is-back/3724
