  2. Announcements
  • LaMB95L
    LaMB95L
    LaMB95
    ran sudo ./bin/mysgw -d
    I keep getting mysgw: accept: Bad File Descriptor.
    Any possible cause ?
      This thread contains comments for the article "Building a Raspberry Pi Gateway" posted on MySensors.org.
      marceltrapmanM
      marceltrapmanM
      marceltrapman
      I am trying to get the raspi ethernet gateway running but on both my pi 3 (also running openHAB) and the pi B (pretty basic install).
      Unfortunately I get the same error on both.
      Any ideas what could be going on here?
      I am running the latest gateway and the latest raspbian.
      mysgw: Starting gateway...
      mysgw: Protocol version - 2.1.0
      mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:INIT:TSP OK
      mysgw: TSM:INIT:GW MODE
      mysgw: MCO:REG:NOT NEEDED
      mysgw: connect: Connection refused
      mysgw: failed to connect
      mysgw: Eth: connect
      mysgw: Eth: connect
      Fulltime Servoy Developer
      LaMB95L M 2 Replies Last reply
      • marceltrapmanM marceltrapman
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: Eth: connect
        mysgw: Eth: connect
        LaMB95L
        LaMB95L
        LaMB95
        @marceltrapman
        I am using a Rasp Pi 3 as well.
        I can't even proceed further in the tutorial cause of this error cause nothing works after it.
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: Eth: connect
          mysgw: Eth: connect
          marceloaqno
          Code Contributor
          @marceltrapman @LaMB95
          Could you post the complete ./configure command used to configure the gateway?
          marceltrapmanM LaMB95L 2 Replies Last reply
          • M marceloaqno
            marceltrapmanM
            marceltrapmanM
            marceltrapman
            @marceloaqno Sure, forgot it :)
            sudo ./configure \
                --my-gateway=ethernet \
                --my-controller-ip-address=192.168.1.xx \
                --my-port=5003 \
                --my-transport=nrf24
            M 1 Reply Last reply
              sudo ./configure \
                  --my-port=5003 \
              marceloaqno
              Code Contributor
              @marceltrapman Are you sure it's not a problem with your controller?
              Have you tried connecting to your controller using telnet?
              telnet 192.168.1.x 5003
              marceltrapmanM 2 Replies Last reply
              • M marceloaqno
                LaMB95L
                LaMB95L
                LaMB95
                wrote on last edited by LaMB95
                #287
                Is this what you meant?
                • M marceloaqno
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  @marceloaqno not sure no.
                  So, I downloaded telnet on the same raspi that I want to use as the gateway and the issue seems to be that port 5003 is not available.
                  Funny but how do I solve this.
                  It can't be an issue with the firewall because it allows all traffic on the internal network.
                  • M marceloaqno
                    marceltrapmanM
                    marceltrapmanM
                    marceltrapman
                    @marceloaqno and the same from the controller to the gateway gives the same error on that port :(
                      marceloaqno
                      Code Contributor
                      @Reza Yes, you can use rs485 in the RPi.
                      ./configure --my-transport=rs485 --my-rs485-serial-port=<YOUR_SERIAL_PORT>
                      For more options, run:
                      ./configure -h
                      R 1 Reply Last reply
                      • LaMB95L LaMB95
                        marceloaqno
                        Code Contributor
                        @LaMB95 No, I meant the options you used when you ran ./configure
                        LaMB95L 1 Reply Last reply
                        • tianaT tiana
                          Is it possible to use the second ISP on my raspberypi 3 to connect NRF24L01+ and what will be the wiring diagram, also what have to change in mygsw library
                          marceloaqno
                          Code Contributor
                          @tiana
                          "The Broadcom SoC has three independant SPI interfaces, however only one of these is brought out to the GPIO connector, and that one SPI interface has 2 Chip enable lines."
                          More info here: https://www.raspberrypi.org/forums/viewtopic.php?f=44&t=22608
                            marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            wrote on last edited by marceltrapman
                            #293
                            @marceloaqno from the docs I assume it is the gateway that has to open up port 5003 but I guess it does not because it can't connect to the ethernet (for some reason) or am I wrong?
                            marceltrapmanM M 2 Replies Last reply
                            • M marceloaqno
                              ./configure -h
                              R
                              R
                              Reza
                              @marceloaqno
                              i means that without arduino and usb port, similar to raspberry gateway ( raspberry +nrf24)
                              i means connect rs485 module to GPIO raspberry pi :) with domoticz
                              • M marceloaqno
                                LaMB95L
                                LaMB95L
                                LaMB95
                                #295
                                I m sorry I m new to using a raspberry pi and its for a project.
                                But if this is not what you asked for could you be a little more specific :$1_1484506047866_Screen Shot 2017-01-15 at 10.46.49 PM.png 0_1484506047866_Screen Shot 2017-01-15 at 10.46.35 PM.png
                                • E
                                  E
                                  ericvdb
                                  use sudo ;)
                                    marceltrapmanM
                                    marceltrapmanM
                                    marceltrapman
                                    Oh and one other thing, when I set the gateway up for MQTT it works.
                                      marceloaqno
                                      Code Contributor
                                      @marceltrapman
                                      If you use the --my-controller-ip-address= option, the gateway will act as a client and attempt to conect to the supplied ip and port. If you want the gateway to open port 5003, omit this option.
                                      • R Reza
                                        @marceloaqno
                                        marceloaqno
                                        Code Contributor
                                        @Reza You could connect the rs485 to the RPi UART and use the option --my-rs485-serial-port=/dev/ttyAMA0, but you need to turning off the UART functioning as a serial console.
                                        Or, to make things easier:
                                        rs485 <==> TTL/USB <==> RPi
                                        • M marceloaqno
                                          R
                                          R
                                          Reza
                                          @marceloaqno
                                          i am beginner and i can not turning off the UART functioning. . . also on some board usb port after power off/on lost and i should disconnect/connect cable... i test your steps serial gateway with raspberry and GPIO with virtual usb serial . and i see this problem solve and after power off/on gateway is connect .
                                          i suggest that you add this commands to page of rs485 gateway step by step and update this .
                                          (https://www.mysensors.org/build/rs485)
                                          I thank you for hard working and trying
                                          b0rmannB 1 Reply Last reply
