  2. Announcements
  • M marceloaqno
    @TommiP What I think is happening is that you are running two instances of the gateway.
    If you need to get the debug logs, first stop the mysgw service:
    sudo systemctl stop mysgw.service
    TommiP
    @marceloaqno
    Ok, now I understand what happened, thanks.
    • R
      R
      romeo01
      Re: 💬 Building a Raspberry Pi Gateway
      Silly questions, I'm a little bit confuse.
      I have a serial Gateway running with arduino nano + nrf24 and a raspberry pi with domoticz on board. The link between domoticz & Gateway is done via USB <=> serial port (/dev/ttyUSB0). This setup runs like a charm.
      Now, I would like to access to my Gateway via the network because I would like to use "Over The Air " functionnality with MYSController.
      Can I install MySensors Gateway on the raspberry and keep the arduino + nrf24 connected via usb ?? For the moment, I can not use GPIO port.
      If for some reason you can't use the GPIO pins of the Raspberry Pi, you could connect the radio to a arduino with the GatewaySerial sketch and feed the pi through a serial port:
      ./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200
      [SECTION] Detecting target machine.
      [OK] machine detected: SoC=BCM2836, Type=RPi3, CPU=armv7l.
      [SECTION] Detecting SPI driver.
      [OK] SPI driver detected:BCM.
      [SECTION] Detecting init system.
      [OK] init system detected: systemd.
      [SECTION] Saving configuration.
      [SECTION] Cleaning previous builds.
      [OK] Finished.
      make
      ./bin/mysgw -d
      mysgw: Starting gateway...
      mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: !TSM:INIT:TSP FAIL
      mysgw: TSM:FAIL:CNT=1
      mysgw: TSM:FAIL:PDT
      mysgw: TSM:FAIL:RE-INIT
      mysgw: TSM:INIT
      mysgw: TSM:FAIL:CNT=2
      mysgw: TSM:FAIL:PDT
      Where is my mistake ??
      Again, Can I install MySensors Gateway on the raspberry and keep the arduino + nrf24 connected via usb or I must connected the nrf24 directly with GPIO on the Rasp ??
      Thanks in advance for your reply.
      Romeo
      gohanG 1 Reply Last reply
      • R romeo01
        [OK] Finished.
        make
        ./bin/mysgw -d
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:FAIL:PDT
        mysgw: TSM:INIT
        mysgw: TSM:FAIL:PDT
        Romeo
        @romeo01 I think that connecting nrf24 directly to arduino and compile mysgw as ethernet gateway is the cleanest solution (I have it as MQTT and it is working fine, but ethernet is the same). Keep in mind that you'd better use one of those adapters 5v-3.3v for nrf24 chips + capacitor because the 3v output of raspberry isn't very suited for the task.
        • R
          R
          romeo01
          Thanks gohan for fast answer.
          Arduino nano + nrf24 are already connected together. Hardware is already built.
          How access to the gatway installed on the raspberry via the network and use my arduino + nrf24 connected via usb/serial to the raspberry ??
          Sorry but I do not understand what you mean
          ...compile mysgw as ethernet gateway is the cleanest solution...
          If I configure on this way
          ./configure --my-gateway=ethernet --my-port=5003
          I could access to my Gateway via network an the Gateway will use the arduino + nrf24l via usb/serial ??
          That's why I say I'm confuse.
          --my-gateway=serial
          What is this option ? The link between gateway and nrf24 or the way to access to the Gateway ??
          • R
            R
            romeo01
            In summary,
            Is the Gateway (software) installed on the raspberry, is able to manage the nrf24 connected on arduino via USB/Serial port ??
              no, I don't think so. If you want to manage nodes over network you need to make an ethernet gateway (could be a UNO with w5100 shield, an esp8266 or mysgw compiled on raspberry)
              • R
                R
                romeo01
                nrf24 connected to a arduino nano and plugged to the raspberry over the usb/serial cable is not considered as a serial device ?
                --my-gateway=serial
                That's exactly what I need, but how to do ??
                Serial port /dev/ttyUSB0 is ok, because I use this with domoticz and it'running good.
                My initial question is how to use my old gatway (arduino + nrf24) with the gateway compiled on the raspberry over the usb/serial cable ?
                  The serial gateway on the raspberry does what your nano is doing and you can't have gateways talking to each other. Maybe you could look at mycontroller and see if can manage nodes the way you want.
                  R 1 Reply Last reply
                  • dirkcD
                    dirkcD
                    dirkc
                    wrote on last edited by dirkc
                    #409
                    When talking about this Raspberry Pi Gateway, I suppose, that its just connecting the NFR24L01+ to the Raspberry Pi GPIO and run
                    ./bin/mysgw -d
                    right? On my Pi it does not work this way, maybe the NFR24L01+ is not ok. Instead I am running an external esp-wifi-gateway, but a direct gateway seems the better solution to me.
                    So did I get it right, that I can use a NFR24L01+ connected to the Raspberry PI GPIO without any external gateway? If so, what are the parameters for building the mysgw daemon? I tried this one:
                    ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev0.0
                    update: as in https://www.mysensors.org/view/180#wiring
                    22 – CE
                    24 – CSN/CS
                    23 – SCK
                    19 – MOSI
                    21 – MISO
                    SPI is activated:
                    $ls /dev/spidev*
                    /dev/spidev0.0  /dev/spidev0.1
                    And this is the result, when building it with the settings mentioned above. (Raspberry Pi 3, jessie 4.9.13-v7+)
                    $ sudo ./bin/mysgw -d
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=3
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=4
                    mysgw: TSM:FAIL:PDT
                    And can someone show how to bind this gateway into FHEM? As said, today I am running an esp-wifi-gateay.
                    Thanks in advance for any support...
                    Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
                    M gohanG 2 Replies Last reply
                      R
                      R
                      romeo01
                      @gohan
                      With the serial Gateway on the raspberry; how is connected the nfr24 ??
                      If usb/serial port is no possible, which serial port to use ?
                      M 1 Reply Last reply
                        @keldandorin just add a capacitor between vcc and gnd on the radio module as I suggested above.
                        keldandorinK
                        keldandorinK
                        keldandorin
                        @gohan Been trying to find my old post to tell you all how it got with my rpi and nodes that did not register. I bougt some voltage regulators LM350. used the 5v output insted of 3.3 V but still no luck to get node to register. when messauring volatage when GW send awnser it drops way below 3.3v. I think voltage output from rpi just is to bad. So I bought a nodemcu for GW instead and it works like a sharm :)
                        • R romeo01
                          @gohan
                          marceloaqno
                          Code Contributor
                          @romeo01 You have to connect the nrf24 to the GPIO if you want to use it with the RPi, the information on the wiki was wrong, sorry about that.
                          gohanG R 2 Replies Last reply
                          • M marceloaqno
                            @marceloaqno he said he can't connect nrf24 chip on the rpi, so that's why he is struggling
                            • dirkcD dirkc
                              ./bin/mysgw -d
                              22 – CE
                              24 – CSN/CS
                              23 – SCK
                              19 – MOSI
                              21 – MISO
                              SPI is activated:
                              $ls /dev/spidev*
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: TSM:FAIL:PDT
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:PDT
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:PDT
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:PDT
                              marceloaqno
                              Code Contributor
                              @dirkc Try to connect your module to the SPI0 (https://www.mysensors.org/view/180#wiring).
                              You only need to enable the SPIDEV if you want to use the SPI1.
                              • dirkcD dirkc
                                ./bin/mysgw -d
                                22 – CE
                                24 – CSN/CS
                                23 – SCK
                                19 – MOSI
                                21 – MISO
                                SPI is activated:
                                $ls /dev/spidev*
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:PDT
                                @dirkc I don't know where you got those pin numbers but they don't look like the ones on the guide. In addition you don't have to use spi driver. The PA version of nrf24 are quite a pain to get them working, so I suggest you first test with regular modules and then upgrade to PA
                                • dirkcD
                                  dirkcD
                                  dirkc
                                  @gohan, @marceloaqno : sorry, I corrected the "typo", the NRF was already connected as shown in https://www.mysensors.org/view/180#wiring. I double checked that again.
                                  What is the correct setup for ./configure ?
                                  • M marceloaqno
                                    R
                                    R
                                    romeo01
                                    @marceloaqno
                                    Thanks marceloagno, the answer is clear.
                                    Keep up the great work !
                                    • dirkcD dirkc
                                      marceloaqno
                                      Code Contributor
                                      @dirkc The default settings for ./configure is to use the nrf24 module connected in the same way as shown in the guide and as an ethernet gateway.
                                      dirkcD 1 Reply Last reply
                                      • L
                                        L
                                        lshield
                                        wrote on last edited by lshield
                                        #419
                                        I'm having issues with the LED setup as shown on the page. The LEDs are just constantly on even though everything looks like it's setup just like the picture. I'm new at this so I could be doing something stupid.
                                        • M marceloaqno
                                          dirkcD
                                          dirkcD
                                          dirkc
                                          @marceloaqno ok, thanks, I will change the radio.
