  2. Announcements
  3. ๐Ÿ’ฌ Relay
๐Ÿ’ฌ Relay
139 Posts 47 Posters 79.5k Views 45 Watching
  • Boots33B Boots33
    @Samuel235 Have a look at this thread for some ideas.
    Samuel235
    @Boots33 - Thanks dude, I have had a quick skim read just but will bookmark it when i get my gateway working. These issues right now are driving me insane, and spending the day to try and find the problem. Thank you for linking me to that post!
    MySensors 2.1.1
    • R
      R
      Rene046
      I just tried this sketch, works on latest version, but i cant seen any relais in Domoticz, only see the node relais, did i miss something
      HenryWhiteH 1 Reply Last reply
      • R Rene046
        HenryWhiteH
        HenryWhiteH
        HenryWhite
        @Rene046 you could try my sketch: https://forum.mysensors.org/topic/6638/multiple-relays-motion-sketch-fully-customizable-optional-timer-manual-override
        R 1 Reply Last reply
        • HenryWhiteH HenryWhite
          R
          R
          Rene046
          @HenryWhite
          thx
          • S
            sineverba
            wrote on last edited by sineverba
            #45
            Hi to all!
            I would edit the secure relay sketch so in loop the node sends to the gateway, let's say every hours, his state (on or off).
            1. I avoid delay otherwise Arduino cannot receive the comands from gateway, so I will use the millis sketch, modified from the official Arduino website.
            My doubt is... How can I get the current state of the relay?
            Relevant part of sketch is in loop and before setup()
            /* TIME variables */
            unsigned long previousMillis = 0;        // will store last time state is sent
            // constants won't change:
            const long interval = 10000;           // interval at which to send state (milliseconds === seconds x 1000). For test we try every 10 seconds
            And the main loop
              // check to see if it's time to send state; that is, if the difference
              // between the current time and last time you sent state is bigger than
              // the interval at which you want to send the state.
              if (currentMillis - previousMillis >= interval) {
                // save the last time you blinked the LED
                previousMillis = currentMillis;
                // send the state here!
                // test
                Serial.println("This is the moment where I need to send state");
                //send(?????????); // Send current state. Probabily will update also the log?
            The base sketch is >>> https://github.com/mysensors/MySensors/blob/master/examples/SecureActuator/SecureActuator.ino
            And the millis example is >>> https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
            Thank you to all!
            S 1 Reply Last reply
            • S sineverba
              Hi to all!
              And the main loop
                  // test
              Thank you to all!
              sineverba
              #46
              @sineverba
              Edit:
              I did edit the pre-setup configuration
              int val = 0;  // the value of digital pin
              MyMessage msg(CHILD_ID,V_LIGHT);
              And I did edit the loop:
                  // test
                  val = digitalRead(LOCK_1);
                  Serial.print("Il valore del relay รจ ");
                  Serial.println(val);
                  send(msg.set(val),true); // Send new state and request ack back.
              I got the update in Domoticz in Hardware > Configuration > Children of nodes
              And I did test also every 3 seconds, all ok.
              But I don't have the refresh in "main page":
              I did test removing current to Arduino when Relay was ON. With Arduino off, I did change the state in domoticz to OFF.
              Because Arduino save previous state in EEPROM, after full start the relay did go ON, in Domoticz got "1" in children (all right, because digitalRead was 1) but main panel shows OFF.
              I did expect a graphical change...
              Thank you (and hope that all is clear) :)
              • S
                sineverba
                Hi to all!
                To achieve my goal (node that sends relay state after power failure to sync with domoticz), I'm editing the button script.
                I have added this line
                state = digitalRead(RELAY_PIN);
                send(msg.set(state?false:true), true); // Send new state and request ack back
                in setup, so I thought it send only one time at startup the current state after power failure.
                But..... the relay shutdown/shuton (or viceversa) twice, in fast sequence....
                Thank you very much!
                S Boots33B 2 Replies Last reply
                • S sineverba
                  Hi to all!
                  sineverba
                  @sineverba
                  Bingo!
                  If I did understand well, the actuator sketch DOESN'T directly acts the relay, but sends to the gateway and expect from the gw itself the "new state" (in effect, you short GND & PIN 4, arduino sends new state to the gateway and gateway resend the new state).
                  So, 'cause I would to update the state on controller, I did this simple edit on setup:
                   state = loadState(CHILD_ID);
                   Serial.print("Lo stato ultimo era ");
                   Serial.println(state);
                   if ( state == 1) {
                     state = 0;
                   } else {
                     state = 1;
                  Basically, If relay was OFF on a power failure, and someone on Domoticz try to start the relay, the state in Domoticz will be "on".
                  When power returns, the arduino read the state (in my example OFF == 0), convert in 1 and send to the gateway the 1. The gateway // Domoticz will be answer with 0.
                  So, relay doesn't nothing and Domoticz state is update.
                  But.... why I need to invert the logic? :D
                  • S sineverba
                    Hi to all!
                    Boots33B
                    Boots33B
                    Boots33
                    @sineverba said in ๐Ÿ’ฌ Relay:
                    Have a look at the sketch I used for my Synchronising Light switch you may be able to use some of that code perhaps.
                    • Boots33B Boots33
                      sineverba
                      @Boots33
                      Never seen the request function.
                      You are hero-member for a reason...
                      Thank you very much! :) :)
                      Boots33B 1 Reply Last reply
                      • S sineverba
                        @Boots33
                        Boots33B
                        Boots33B
                        Boots33
                        You can find request and other useful info on the API page.
                        Hope you are enjoying your MySensors journey :)
                        • fhenrycoF
                          fhenrycoF
                          fhenryco
                          since the relay has leds and is therefore power consuming, i was wondering if someone has written a sketch for a low power usage of the relay (as for the sensors) allowing the arduino (and the relay) to sleep all the time and wake up every 5 minutes for instance just to check if the controller has changed the desired state of the switch.
                          Of course then the relay could be as late as 5minute, but this is not an issue for my application ...
                          thanks for any suggestion
                          • fhenrycoF fhenryco
                            @fhenryco can't the relay node use power from whatever it is controlling?
                            For sleeping nodes, the smartsleep feature can be useful. Search for that keyword in the forum and look at https://www.mysensors.org/download/sensor_api_20#sleeping
                            fhenrycoF 1 Reply Last reply
                            • fhenrycoF
                              fhenrycoF
                              fhenryco
                              thanks , indeed it's because the relay is controlling a 12V battery power to solenoid valve , that low power consumption is needed. BTW the 12V is obtained from a 4S lipo (16.5V max voltage) and a 12 regulator and i dont know if its better to feed the arduino from a 5V regulator fed by the same Lipo , or use an additional set of AA batteries ... i remember that it's better to have an as low as possible drop in voltage to save power...
                                Boots33B
                                Boots33B
                                Boots33
                                @fhenryco If you are trying to keep your power use down then you could also consider using either a Latching Relay or even a MOSFET.
                                gohanG 1 Reply Last reply
                                  fhenrycoF
                                  fhenrycoF
                                  fhenryco
                                  @mfalkvidd smartsleep was not supported by domoticz at the begining of the year ... but there was a domoticz upgrade in july ... do you know if it's now supported ?
                                  • Boots33B Boots33
                                    @Boots33 said in ๐Ÿ’ฌ Relay:
                                    Agreed, if you want to save power you need to use a latching relay. Also another regulator would be fine to power the arduino.
                                      fhenrycoF
                                      fhenrycoF
                                      fhenryco
                                      @gohan can you explain the benefit (for a low power app) of a relay switching on electrical pulse rather something else ?
                                      i mean, even the regular relay has both an open by default circuit output and close by default circuit ouput so it could remain on the desired state even when not powered up ...
                                        I am referring that when relay is on it is drawing power to stay on, while a latching relay it only draws power during the switch on and only during the switch off.
                                          fhenrycoF
                                          fhenrycoF
                                          fhenryco
                                          @gohan not sure this is going to be an easy way: need find arduino code for latch relay, dont know if domoticz is supporting this device ?, ...
                                          With your input, this post could be even better ๐Ÿ’—
