  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 101.9k Views 36 Watching
    Have you tried another controller like mycontroller?
    cashew75C 1 Reply Last reply
      cashew75C
      cashew75C
      cashew75
      @gohan No I have not. I have a RF-Link also connected to the HA and it's working great. As I said, if I use the same hardware that I used to control the Dallas sensor and change the sensor to a DHT sensor the DHT sensor is accepted by HA and shows up as a sensor. That's why I was asking if there is something in the code for the Temperature sensor sketch that has to be changed to be able to present it to HA.
        pls post the code that is not working
          cashew75C
          cashew75C
          cashew75
          @gohan Thanks for the quick reply! Well I've use the standard sketch for this Temperatur sensor. This is the code i've got.
          //#define MY_DEBUG
          #include <OneWire.h>
          int numSensors=0;
          bool receivedConfig = false;
          bool metric = true;
          MyMessage msg(0,V_TEMP);
          void before()
            sensors.begin();
          void presentation() {
            sendSketchInfo("Temperature Sensor", "1.1");
               present(i, S_TEMP);
            sleep(conversionTime);
              float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
              #if COMPARE_TEMP == 1
              #else
                send(msg.setSensor(i).set(temperature,1));
            sleep(SLEEP_TIME);
          • pepsonP
            pepsonP
            pepson
            Anybody has sketch for sensors dallas DS18b20 with identify it with ID Dallas ?
            And i can change value 16 to more sensors ? Example 20 ?
            • A
              A
              APL2017
              Looking at code example it seems to be sufficient to set bool metric = false to get readings in Fahrenheit, but node still returns readings in C. Any idea why?
              • A APL2017
                @apl2017 if I'm looking at the same sketch as you are looking at, the metric variable is never used. getControllerConfig() is used to fetch the controller's metric setting instead.
                • R Rene046
                  I sofar got the sketch running and giving good data on serial and into domoticz
                  i only could use some help with how to sent my Temperature in Celsius to domoticz to
                  i tried to use:
                  send(msgTemp.set(insideThermometer ,2));
                  and
                  send(msgTemp.set(tempC,2));
                  both without luck, the first did transmit some data but wrong numbers
                  second did nothing think because with this i done i does not know what address the DS1820 is on.
                  Im learning every day something new....
                  Maybe someone could help,
                  G
                  G
                  gniazdoj
                  @Rene046
                  Hi guys
                  Hi
                  can you advice how to manage Domoticz to display 2 decimals under Temperature sensors page, when following line MsgTemp.set(temperature,2) I can see on arduino serial monitor, mysensors sent 20.75 value, the same value i can see under child item with Hardware tab but not on sensor where 20.75*C is rounded to 20.8. its fine for general log but i want to have stable temperature for heating system. I have added code to count average from last X records like 20 or 40 with 0.25 steps, this stabilize Heating system and protect it against on/off to frequently.
                  Additionally when i use JSON it will present proper value under sensor page, same with ESPEasy and 2 decimal configuration on ESP.
                  do you know how i can changed domoticz to force him to present 2 decimals?
                  Mysensors 2.3.1/2.3.2
                  Domoticz 4.10717
                  raspberry pi
                  Thank you
                  Jakub
                  K 1 Reply Last reply
                  • G gniazdoj
                    @Rene046
                    Hi guys
                    Hi
                    Domoticz 4.10717
                    raspberry pi
                    Thank you
                    Jakub
                    K
                    K
                    kimot
                    Domoticz globally or only with MySensors ?
                    My Domoticz is the same version like yours.
                    Temperatures from ESPeasy are with two decimals on Temperature sensors page, but on devices page only one decimal.
                    Exactly the opposite like you wrote.
                    G 1 Reply Last reply
                    • K kimot
                      G
                      G
                      gniazdoj
                      wrote on last edited by gniazdoj
                      #170
                      @kimot
                      Hi
                      Thank you for feedback.
                      I have this issue only with mysensors. it's exactly like you wrote. Hardware tab, present 2 decimals ( for mysensors and espeasy). Device tab, present 1 decimal ( for all sensors), Temperature tab shows 2 decimal for esp easy and JSON updates but 1 decimal for mysensor. Not sure why.
                      Temporary I managed to workaround by using script taking data from Hardware page - child and sending JSON update all started by crone updating dummy sensor.
                      like this:
                      TEMP=`curl -s "http://X.X.X.X:XX/json.htm?type=command&param=mysensorsgetchilds&idx=40&nodeid=0"| awk 'NR>1{print $5}'| sed 's/"//g;s/^.//;s/)//g; s/,//g;/^$/d;s/]//g;' | sed -n '3,2p'`
                      IDX=255
                      curl -s "http://X.X.X.X:XX/json.htm?type=command&param=udevice&idx=$IDX&nvalue=0&svalue=$TEMP"
                      but for sure this can be workaround by dzVents and JSON handling results but i'm not skilled enough for that :)
                      Thank you
                      Jakub
                      • G
                        G
                        garubi
                        The note before the example sketch states that you should use the "modified" library from MySensors examples.
                        But as of today, with MySensors 2.3.2 and Arduino 1.8.15 I used the standard DallasTemperature library (provided by the Arduino's Libraries manger) with no problems at all.
                        Using the "standard" Arduino libraries is a grate advantage, so I the custom library is no more used, it could be useful to update the guidelines in the page.
                        Stefano
