  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 101.9k Views 36 Watching
  • rejoe2R
    rejoe2R
    rejoe2
    wrote on last edited by rejoe2
    #81
    If anyone is interested:
    The sketches in my repo have been updated yesterday for complete compability with the new structure and syntax. They compile fine and should work, but I didn't have the time to make functional tests also.
    If anyone is interested, I could also add a multibus example with several Sensors at each bus and different timings for each bus. One of my nodes is working on this concept for several days now (Heizung, RS485 version), so I'm pretty confident this will reliably work for longer periods. But it's rather special:grinning: .
    • skywatchS
      skywatchS
      skywatch
      @rejoe2
      Where do we find your repo then?
      • rejoe2R rejoe2
        There was a rather small note in the 2.0.0 changelog about the introduction of before().
        Btw: Another functional routine (preHwInit() (?)) may have been introduced also with 2.1.1 (?). But until now, all of my sketches and tests got along without this preHwInit() functionality. But imo the new structure is pretty good: before() is helpfull to initialise SPI devices on same bus as nRF24 and to collect relevant info like the number of DS18x20, setup() is now also good to send info you only need once (e.g. the Dallas-Chip-ID).
        The rest is - at least afaik - not really documented well, but most examples (if you use the updated ones) will work (apart from the DS18x20 example, where other - external - code changes made some parts tricky to use.
        I made some working sketches for the Dallas Sensors some time ago based on some ideas I found here in the MySensors forum; they mostly should still work (exept for the change of getConfig() to getControllerConfig()). If you are interested: here .
        Kind regards
        rejoe2R
        rejoe2R
        rejoe2
        @chaeron
        Thx for asking.
        Repo-link was mentioned above, @rejoe2 said in 💬 Temperature Sensor:
        Btw: the sketches have been updated and compile now also with MySensors 2.2.0-beta. But to be honest, I didn't test them with hardware until now. So feedback is appreciated :simple_smile:.
        • rejoe2R
          rejoe2R
          rejoe2
          Additionally: There is also a multibus version included that uses different timings for reading each of the buses.
          For using this sketch, I'm not sure wheter some changes in the DallasTemperature-lib also is required (it is based on an very recent example of the maintainer's guthub version; should be linked in the Arduino Library Manager; I myself applied some changes wrt. this in my local libs).
          I may aslo post this in case anyone's interested (and these mods are necessary).
          DickD 1 Reply Last reply
          • rejoe2R rejoe2
            DickD
            DickD
            Dick
            wrote on last edited by Dick
            #85
            @rejoe2 Any idea why the DallasTemperatureSimple from your GitHub not presenting in Domoticz?
               The MySensors Arduino library handles the wireless radio link and protocol
               between your home built sensors/actuators and HA controller of choice.
               The sensors forms a self healing radio network with optional repeaters. Each
               repeater and gateway builds a routing tables in EEPROM which keeps track of the
               network topology allowing messages to be routed to nodes.
               Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
               Copyright (C) 2013-2015 Sensnology AB
               Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
               Documentation: http://www.mysensors.org
               Support Forum: http://forum.mysensors.org
               This program is free software; you can redistribute it and/or
               modify it under the terms of the GNU General Public License
               version 2 as published by the Free Software Foundation.
               DESCRIPTION
               Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
               http://www.mysensors.org/build/temp
               Enhanced Version also sending the Dallas-ROM-ID, MySensors Version >=2.1.0
            #include <OneWire.h>
            uint8_t DS_First_Child_ID = 7; //First Child-ID to be used by Dallas Bus; set this to be higher than other Child-ID's who need EEPROM storage to avoid conflicts
            int numSensors = 0;
            bool receivedConfig = false;
            bool metric = true;
            DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
            int resolution = 12; // precision: 12 bits = 0.0625°C, 11 bits = 0.125°C, 10 bits = 0.25°C, 9 bits = 0.5°C
            int conversionTime = 0;
            MyMessage msgTemp(0, V_TEMP);
            MyMessage msgId(0, V_ID);
            char* charAddr = "Check for faults";
            #define SEND_ID
            void before()
              // 12 bits = 750 ms, 11 bits = 375ms, 10 bits = 187.5ms, 9 bits = 93.75ms
              conversionTime = 750 / (1 << (12 - resolution));
              sensors.begin();
            void presentation() {
              sendSketchInfo("Temperature Sensor", "1.2");
              for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                sensors.getAddress(tempDeviceAddress, i);
                charAddr = addrToChar(tempDeviceAddress);
                present(i + DS_First_Child_ID, S_TEMP, charAddr);
            #ifdef MY_DEBUG
                Serial.println(charAddr);
            #ifdef SEND_ID
                // 8 will assure a length of 16 of the sent ROM-ID
                send(msgId.setSensor(i + DS_First_Child_ID).set(tempDeviceAddress, 8));
                sensors.setResolution(tempDeviceAddress, resolution);
              sleep(conversionTime);
                float temperature = static_cast<float>(static_cast<int>((metric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
            #if COMPARE_TEMP == 1
            #else
                  send(msgTemp.setSensor(i + DS_First_Child_ID).set(temperature, 1));
                  wait(20);
                  lastTemperature[i] = temperature;
              sleep(SLEEP_TIME);
            char* addrToChar(uint8_t* data) {
              String strAddr = String(data[0], HEX); //Chip Version; should be higher than 16
              byte first ;
              int j = 0;
              for (uint8_t i = 1; i < 8; i++) {
                if (data[i] < 16) strAddr = strAddr + 0;
                strAddr = strAddr + String(data[i], HEX);
                strAddr.toUpperCase();
              for (int j = 0; j < 16; j++) {
                charAddr[j] = strAddr[j];
              return charAddr;
            gohanG 1 Reply Last reply
            • DickD Dick
                 DESCRIPTION
              int numSensors = 0;
              bool metric = true;
              #define SEND_ID
              void before()
                sensors.begin();
              #ifdef MY_DEBUG
              #ifdef SEND_ID
              #else
                    wait(20);
                sleep(SLEEP_TIME);
                byte first ;
                int j = 0;
                return charAddr;
              @Dick you are missing
              #define MY_NODE_ID x
              where x is the unique sensor ID you want to assign to node. If look in the gateway or node log you will see the node asking for an ID
                #87
                @gohan Domticz is capable of handing out node ids so using the default auto setting is perfectly fine.
                But yes, the debug log from node and gateway will help a lot in determining what the problem is.
                  DickD
                  DickD
                  Dick
                  @mfalkvidd I already tried a fixed node ID but that was not the solution so I checked the log of domoticz and this is the result:
                  2017-08-19 11:59:30.260 MySensors: Node: 48, Sketch Name: Temperature Sensor
                  2017-08-19 11:59:30.261 MySensors: Node: 48, Sketch Version: 1.2
                  2017-08-19 11:59:38.480 MySensors: Node: 48, Sketch Name: Temperature Sensor
                  2017-08-19 11:59:38.481 MySensors: Node: 48, Sketch Version: 1.2
                  So it see the node but it does not pop up as a new device.
                  The Arduino log shows this:
                  0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                  3 MCO:BGN:BFR
                  6 TSM:INIT
                  7 TSF:WUR:MS=0
                  14 TSM:INIT:TSP OK
                  16 TSF:SID:OK,ID=48
                  17 TSM:FPAR
                  59 TSF:MSG:SEND,48-48-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  360 TSF:MSG:READ,0-0-48,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  365 TSF:MSG:FPAR OK,ID=0,D=1
                  408 TSF:MSG:READ,20-20-48,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                  2066 TSM:FPAR:OK
                  2067 TSM:ID
                  2068 TSM:ID:OK
                  2070 TSM:UPL
                  2074 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  2086 TSF:MSG:READ,0-0-48,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  2092 TSF:MSG:PONG RECV,HP=1
                  2094 TSM:UPL:OK
                  2096 TSM:READY:ID=48,PAR=0,DIS=1
                  2101 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  2110 TSF:MSG:READ,0-0-48,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  2118 TSF:MSG:SEND,48-48-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                  2127 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  2143 TSF:MSG:READ,0-0-48,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  2152 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
                  2162 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                  2169 MCO:REG:REQ
                  2173 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  2183 TSF:MSG:READ,0-0-48,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  2188 MCO:PIM:NODE REG=1
                  2190 MCO:BGN:STP
                  2191 MCO:BGN:INIT OK,TSP=1
                  2196 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
                  2201 !MCO:SLP:REP
                  2952 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  2957 !MCO:SLP:REP
                  32960 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
                  mfalkviddM rejoe2R 2 Replies Last reply
                  • DickD Dick
                    3 MCO:BGN:BFR
                    6 TSM:INIT
                    7 TSF:WUR:MS=0
                    14 TSM:INIT:TSP OK
                    16 TSF:SID:OK,ID=48
                    17 TSM:FPAR
                    2066 TSM:FPAR:OK
                    2067 TSM:ID
                    2068 TSM:ID:OK
                    2070 TSM:UPL
                    2094 TSM:UPL:OK
                    2169 MCO:REG:REQ
                    2190 MCO:BGN:STP
                    2201 !MCO:SLP:REP
                    2957 !MCO:SLP:REP
                    @Dick that output doesn't seem to match the sketch you posted. The output says the node is a repeater, but I don't see any repeater activation in the sketch.
                    • DickD Dick
                      3 MCO:BGN:BFR
                      6 TSM:INIT
                      7 TSF:WUR:MS=0
                      14 TSM:INIT:TSP OK
                      16 TSF:SID:OK,ID=48
                      17 TSM:FPAR
                      2066 TSM:FPAR:OK
                      2067 TSM:ID
                      2068 TSM:ID:OK
                      2070 TSM:UPL
                      2094 TSM:UPL:OK
                      2169 MCO:REG:REQ
                      2190 MCO:BGN:STP
                      2201 !MCO:SLP:REP
                      2957 !MCO:SLP:REP
                      rejoe2R
                      rejoe2R
                      rejoe2
                      @mfalkvidd Thx for your observation, I didn't realise that. Did you try to use this sketch also?
                      As FHEM is the controller sw I use, I am not able to really test this kind of behaviour, that more seemed to be related to domoticz (or other trouble wrt. to this individual MySensors-installation).
                      @Dick Imo, the node at least when trying to register behaves as necessary: it presents itself to the controller (but the chosen ID seems to be already bound to a different node). In FHEM - not for the node itself but for individual readings - it is necessary to reload the page to see updated readings, if it's the very first time they are sent from node's side (hope, you can follow my thoughts). Maybe domoticz shows a similar behaviour?
                      • rejoe2R rejoe2
                        @rejoe2 could you clarify which observation you are referring to?
                        rejoe2R 1 Reply Last reply
                          rejoe2R
                          rejoe2R
                          rejoe2
                          #92
                          @mfalkvidd I was reffering to this part of the serial output:
                          Imo, the only thing that is not standard is to also use a comment when presenting the individual temp-sensors:
                          FHEM doesn't care about that (just ignores this comment), but maybe other controllers don't like that at all. (I added this as it is a possible feature and may be helpful for others), but @Dick , you could try to delete the last argument.
                          • rejoe2R rejoe2
                            @rejoe2 the repeater feature is disabled by default, so Dick must have activated it by a define.
                            • rejoe2R
                              rejoe2R
                              rejoe2
                              @Dick Besides the inclusion mode, in FHEM one also has to activate a feature called "autocreate". Is there a comparable routine, and in case if: did you turn it on?
                              If you have a look in your domoticz log, there most likely appear further trials to register, or not?
                                DickD
                                DickD
                                Dick
                                @mfalkvidd For your info, I started the sketch cleareeprom to clear my Nano, loaded the script mentioned already and the log I posted is the same so the log must fit the sketch for the DallasTemperatureSimple. The repeater is activated or is it better to turn it off?
                                • DickD Dick
                                  #96
                                  @Dick the repeater feature is turned off by default so there is something very fishy going on.
                                  Have you modified any of the MySensors library files?
                                  • rejoe2R rejoe2
                                    DickD
                                    DickD
                                    Dick
                                    @rejoe2 What I see in the Log of Domoticz is that all the nodes are registered and are visible in Black the only blue one is only the Dalles node
                                    2017-08-19 12:44:48.339 MySensors: Node: 3, Sketch Name: Relay
                                    2017-08-19 12:44:48.340 MySensors: Node: 3, Sketch Version: 1.0
                                    2017-08-19 12:47:28.520 MySensors: Node: 48, Sketch Name: Temperature Sensor
                                    2017-08-19 12:47:28.530 MySensors: Node: 48, Sketch Version: 1.2
                                    2017-08-19 12:48:00.005 (GW Mysensors) Light/Switch (Voor Gor Pir)
                                    2017-08-19 12:48:39.405 MySensors: Node: 48, Sketch Name: Temperature Sensor
                                    2017-08-19 12:48:39.405 MySensors: Node: 48, Sketch Version: 1.2
                                    2017-08-19 12:49:36.059 MySensors: Node: 48, Sketch Name: Temperature Sensor
                                    2017-08-19 12:49:36.060 MySensors: Node: 48, Sketch Version: 1.2
                                    2017-08-19 12:51:47.939 MySensors: Node: 12, Sketch Name: Temperature Sensor
                                    2017-08-19 12:51:47.939 MySensors: Node: 12, Sketch Version: 1.2
                                    2017-08-19 12:51:54.329 MySensors: Node: 12, Sketch Name: Temperature Sensor
                                    2017-08-19 12:51:54.330 MySensors: Node: 12, Sketch Version: 1.2
                                    2017-08-19 12:54:56.992 (GW Mysensors) Light/Switch (Serre IRbui)
                                    2017-08-19 12:55:44.429 MySensors: Node: 12, Sketch Name: Temperature Sensor
                                    2017-08-19 12:55:44.440 MySensors: Node: 12, Sketch Version: 1.2
                                      DickD
                                      DickD
                                      Dick
                                      @mfalkvidd I changed the dalles lib with an older one, because in a disussion a wile ago it was advised to get it working. Now this modified Sketch is available I replaced the dalles lib again the latest one. For the rest nothing.
                                      • DickD Dick
                                        #99
                                        @Dick this part
                                        2201 !MCO:SLP:REP
                                        of the initial log you posted says that the node cannot sleep because it is a repeater.
                                        This part of the sketch:
                                        explains that if the node is a repeater, the sleep call must be replaced by wait. If it is not replaced, the temperature sensors will not be ready when getTemp... is called, so the node will not send any values. Domoticz only lists sensors that have sent a value.
                                        DickD 2 Replies Last reply
                                          @Dick this part
                                          2201 !MCO:SLP:REP
                                          DickD
                                          DickD
                                          Dick
                                          @mfalkvidd I chaned the Sleep into Wait but the same log in both Domoticz and on my Arduino. I thought it was an easy go but it appear not to be.
                                          rejoe2R mfalkviddM 2 Replies Last reply
