💬 Temperature Sensor
I am not a programmer, but trying to learn by making small projects.
I am trying to build a arduino/ESP8266 with temp sensor so that at a particular set temp it sends a single to another arduino/ESP8266 with relay to turn on a cooler/heater. if there is a thread on this, please help me find it.@Mohammed-Zaman This seems to be possible, you may find more info wrt your topic using "node to node communication" as a keyword for searching the forum.
This might be a good starting point: https://forum.mysensors.org/topic/6386/almost-controller-less-mysensors-switch-light-network/8# -
Hi there, I'm new to Mysensors and I thought I'd start with a simple DS Temp sensor. However, I'm getting compile errors when I try compile it. Can someone please point me in the right direction?
Arduino: 1.6.11 (Windows 7), Board: "Arduino Nano, ATmega328" WARNING: Category 'Sensor' in library DallasTemperature is not valid. Setting to 'Uncategorized' In file included from C:\Users\Admin\Documents\Arduino\Projects\MS Temp sensor node\DallasTemperatureSensor\DallasTemperatureSensor.ino:37:0: C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()': C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:249:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private int16_t millisToWaitForConversion(uint8_t); ^ DallasTemperatureSensor:85: error: within this context int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution()); ^ Multiple libraries were found for "DallasTemperature.h" Used: C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature Not used: C:\Users\Admin\Documents\Arduino\libraries\Arduino-Temperature-Control-Library-master exit status 1 within this context This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.regarding error:
In the latest version of Miles Burton's the function is public and compiling fine.
https://github.com/milesburton/Arduino-Temperature-Control-LibraryYou can import the Lib as zip.
You have to remove \ archive the lib: ...\libraries\DallasTemperature -
regarding error:
You have to remove \ archive the lib: ...\libraries\DallasTemperature@sjoerd14 yes, thanks to MySensors user David Ducatel. The change is tracked in https://github.com/mysensors/MySensorsArduinoExamples/issues/20 and https://github.com/milesburton/Arduino-Temperature-Control-Library/pull/72 but we're still waiting for an official release of milesburton's library.
Hi, I have few in wall nodes mounted under the light switches. I have two relays and one DS18B20 in each node. When i'm turning light on, switching the relay, the DS18B20 readings jumping about 0.8 degrees celsius up. When I switch off the relay readings back to normal. Anyone have similar problems ? Sensors are away from from node board, relays etc. so it's not about the heat from atmega or relays.
It's probably a voltage drop from the psu when the relay is engaged and drawing current. That will cause the output voltage to dip slightly.
If it is only momentary you can add a beefy capacitor across the power supply, but if the readings change for the whole time the relay is on, you really need to replace the relay with something that uses less power (triac/mosfet??) - Or get a more stable power supply with good regulation.
A final thing might be more noise on the power line with the psu sending more current with the relay on. again a smoothing capacitor would help if this were the case.
You could also try looking into the wiring and see if the relay cables and the ds18b20 cables are far enough apart, some induction might be going on there between the cables. Also, make sure everything goes back to a single ground point. I can't imagine how an earth loop would cause what you describe, but it's always a good thing to do.....
Another thought to think about is matbe the magnetic field from the relap power cables are inducing into the sensor cables.
Hi
Can we talk about redundancy please? What if one or more sensor fail on a one-wire bus? Would it make the whole line unusable?
As part of a central heating MySensorization i would like to have groups of 3 sensors and have some sort of redundancy check.
Would i be allowed to run multiple one-wire busses on a single arduino?
Thanks a lot foryour help -
Hi
@ben999 you can have as many onewire buses as you have digital pins. Just add more of these:
#define ONE_WIRE_BUS 3 // Pin where dallase sensor is connected OneWire oneWire(ONE_WIRE_BUS);@mfalkvidd thanks a lot. Yes, that looks good to me. I will have a go.
The real big question now is about what happens when one or more sensor fails on the line.
I am not talking about removing a sensor, which doesn't produce any fault.
My concern is how does a DS18 ends its life under normal operation? Complete shortcut? -
My concern is how does a DS18 ends its life under normal operation? Complete shortcut?@ben999 I cannot remember WHERE I read it, but if a DS18B20 fails it will either send impossible results when addressed or fail to be addressed at all as it is digitally addressed. Only cable short circuits can pull the entire chain down, as I found out when two socket pins had crossed over (sensor crimped into telephone plugs).
@ben999 I don't think there are any guarantees on how it will fail. If there are, the datasheet should list them.
@mfalkvidd thank you for the idea. Had a look (boooooring reading for me :D ) but no mention to failiure
@zboblamont you're right. Seems that a faulty sensor return "85" (top of my head). And a "dead" sensor looses its bus address (next sensor on the chain takes its address and so on)
Thanks a lot gentlemen :)
@ben999 said in 💬 Temperature Sensor:
That's not exactly right. Each of the 1-wire devices uses a hardcoded, unique address that can not be changed.
So if you use the standard sketch with multiple DS18B20, in case of detached or replaced sensors you may get reported the measured temperatures comming from the same physical DS18B20 device under a different ChildID (after node reboot). To avoid effects like that, one has to take additional measures as described here . In short:- Use an array with the physical ID's to address them
- Store a hash-array (done automatically) to identify "known" physical ID's that have once been attached to the bus as well as the ChildID used for MySensors.
When I try to compile the sketch for an ESP8266 I get an error in DallasTemperature.h which results in an error in OneWire.h
OneWire.h:108:2: error: #error "Please define I/O register types here" #error "Please define I/O register types here"Is it possible to make the sensor run on an ESP?
Hi, I'm having a hard time getting this Temperatursensor to work with Home Assistant. When i start it it doesn't register with the HA. If I use the same hardware and switch out the sensor to a DHT sensor (new sketch of course) then it works out of the box, HA sees the sensor. I've tried changing the Dallas DS18B20, but nothing. If i look at the logs the gateway have no problem with the sensor. Is there something in the code for the sensor that doesn't add up to it being presented to HA in the right way? I'm quite the newbie when it comes to programming.
