  3. Unique ID-value DS18B20 Temperature sensors
14 Posts 6 Posters 10.8k Views 7 Watching
  • B
    B
    boozz
    Hi all,
    For a project (water supply line in a protective tube buried in the ground) I need to monitor the temperature during winter time. This tube has a lengt of 25 mtrs. in length and every 2 mtrs. i would like to install a DS18B20 sensor.
    Reading out the temperatures is simple using the sketch for the temperatur sensor, but what happens if one of the installed sensors dies in the future. I personally guess the array is updated once the sensor is being reset and my original info (which sensor at what position) is lost.
    Is it possible to fill an extra array with the Unique ID-value of the sensors at initialisation? Has anyone some experience with this or done it before?
    Any other suggestions are welcome as well of course!
    Thanks!
    BR,
    Boozz
    • FotoFieberF
      FotoFieberF
      FotoFieber
      There are several examples on the internet and I have cut and pasted my solution for a similar problem with 4 sensors (serial gateway with dallas sensors):
      // Enable serial gateway
      #define MY_GATEWAY_SERIAL
      // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
      #if F_CPU == 8000000L
      #define MY_BAUD_RATE 38400
      // Flash leds on rx/tx/err
      #define MY_LEDS_BLINKING_FEATURE
      // Set blinking period
      // Enable inclusion mode
      // Dallas
      #include <OneWire.h>
      DeviceAddress Probe01 = { 0x28, 0xFF, 0x2E, 0x3E, 0x66, 0x14, 0x01, 0xB2 };
      DeviceAddress Probe02 = { 0x28, 0xFF, 0xB9, 0x40, 0x66, 0x14, 0x01, 0xE9 };
      DeviceAddress Probe03 = { 0x28, 0xFF, 0x47, 0x64, 0x66, 0x14, 0x02, 0x71 };
      DeviceAddress Probe04 = { 0x28, 0xFF, 0x3F, 0x48, 0x66, 0x14, 0x01, 0xA2 };
      #define TEMPERATURE_PRECISION 12
      unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
      int numSensors = 0;
      bool receivedConfig = false;
      bool metric = true;
      MyMessage msg(0, V_TEMP);
      void before()
        sensors.begin();
      void presentation() {
        sendSketchInfo("Temperature Sensor on Gateway Mega2560", "1.2");
        //Serial.print("Numsensors ");
        //Serial.println(numSensors);
        for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
          present(i, S_TEMP);
        DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
        for (int i = 0; i < numSensors; i++)
          // Search the wire for address
          if (sensors.getAddress(tempDeviceAddress, i))
            Serial.print("Found device ");
            Serial.print(i, DEC);
            Serial.print(" with address: ");
            printAddress(tempDeviceAddress);
            Serial.println();
            Serial.print("Setting resolution to ");
            Serial.println(TEMPERATURE_PRECISION, DEC);
            // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
            sensors.setResolution(tempDeviceAddress, TEMPERATURE_PRECISION);
            Serial.print("Resolution actually set to: ");
            Serial.print(sensors.getResolution(tempDeviceAddress), DEC);
            Serial.println();
          } else {
            Serial.print("Found ghost device at ");
            Serial.print(" but could not detect address. Check power and cabling");
        //Serial.println("Readung Temperatures....");
        //Serial.println("Fetched");
        wait(conversionTime);
          float temperature;
          switch (i)  {
            case 0:
              temperature = sensors.getTempC(Probe01);
              break;
            case 1:
              temperature = sensors.getTempC(Probe02);
              break;
            case 2:
              temperature = sensors.getTempC(Probe03);
              break;
            case 3:
              temperature = sensors.getTempC(Probe04);
              break;
            default:
              temperature = sensors.getTempCByIndex(Probe04);
              break;
          //Serial.println(temperature);
      #if COMPARE_TEMP == 1
      #else
            send(msg.setSensor(i).set(temperature, 1));
            lastTemperature[i] = temperature;
        wait(SLEEP_TIME);
      // function to print a device address
      void printAddress(DeviceAddress deviceAddress)
        for (uint8_t i = 0; i < 8; i++)
          if (deviceAddress[i] < 16) Serial.print("0");
          Serial.print(deviceAddress[i], HEX);
      With this I monitor my heat pump boiler.
      • F
        F
        flopp
        I solved it like this
        https://forum.mysensors.org/topic/4143/about-ds18b20-onewire/2
        B 1 Reply Last reply
        • F flopp
          B
          B
          boozz
          @FotoFieber and @flopp
          Thank you both for pointing me in the right direction. As far as I can see from here this contains the solutions for my problem. I'm very happy with this info.
          :+1:
          BR,
          Boozz
          chrilleC 1 Reply Last reply
          • B boozz
            :+1:
            BR,
            Boozz
            chrilleC
            chrilleC
            chrille
            I have been thinking about another solution for this. As present() supports an optional description, it should be possible to send the 1-wire address in the description. Then the controller can handle things and there's no need to hardcode anything in the sketch - it would also mean that there's no need to update the sketch if a 1-wire device gets replaced.
              The idea was to use V_ID for sensor identifiers when available, like on the DS18B20.
              https://www.mysensors.org/download/serial_api_20#set,-req
                chrilleC
                chrilleC
                chrille
                Too bad this isn't supported for domoticz :(
                "Error: MySensors: Unknown/Invalid sensor type (42)"
                • Jan
                F 1 Reply Last reply
                • chrilleC chrille
                  • Jan
                  F
                  F
                  flopp
                  wrote on last edited by flopp
                  • Jan
                  I have not tried it my self but it should be possible to use. What version of Domoticz do you use?
                  See here which type of identifier that is implemented, seems that it was implemented 18 oct 2015
                  https://github.com/domoticz/domoticz/blob/master/hardware/MySensorsBase.cpp
                  • F flopp
                    • Jan
                    chrilleC
                    chrilleC
                    chrille
                    I'm using 3.5637 (quite recent beta)
                    It would be interesting to hear if someone actually used the V_ID feature (with domoticz, or other controllers), that would share their sketch - just to see if I'm missing something obvious
                    • Jan
                    • F
                      F
                      flopp
                      I have now test V_ID, not working in Domoticz. I also get
                      • F
                        F
                        flopp
                        @chrille
                        What version of MySensors are you using?
                        I am using 1.5.1
                        • F
                          F
                          flopp
                          I started a thread at Domoticz forum
                          https://www.domoticz.com/forum/viewtopic.php?f=42&t=13373&p=96694#p96669
                          • F flopp
                            @chrille
                            I am using 1.5.1
                            chrilleC
                            chrilleC
                            chrille
                            @flopp said:
                            @chrille
                            I am using 1.5.1
                            I am using 2.0.1
                            • Jan
                            • L
                              L
                              LeoDesigner
                              Check this solution too:
                              https://forum.mysensors.org/topic/2184/enhanced-dallas-temperature-example-with-permanent-sensor-index
