  3. Unique ID-value DS18B20 Temperature sensors
14 Posts 6 Posters 10.8k Views 7 Watching
  • FotoFieberF
    FotoFieberF
    FotoFieber
    There are several examples on the internet and I have cut and pasted my solution for a similar problem with 4 sensors (serial gateway with dallas sensors):
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    // Dallas
    #include <OneWire.h>
    DeviceAddress Probe01 = { 0x28, 0xFF, 0x2E, 0x3E, 0x66, 0x14, 0x01, 0xB2 };
    DeviceAddress Probe02 = { 0x28, 0xFF, 0xB9, 0x40, 0x66, 0x14, 0x01, 0xE9 };
    DeviceAddress Probe03 = { 0x28, 0xFF, 0x47, 0x64, 0x66, 0x14, 0x02, 0x71 };
    DeviceAddress Probe04 = { 0x28, 0xFF, 0x3F, 0x48, 0x66, 0x14, 0x01, 0xA2 };
    #define TEMPERATURE_PRECISION 12
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    int numSensors = 0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0, V_TEMP);
    void before()
      sensors.begin();
      sendSketchInfo("Temperature Sensor on Gateway Mega2560", "1.2");
      //Serial.print("Numsensors ");
      //Serial.println(numSensors);
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        present(i, S_TEMP);
      DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
      for (int i = 0; i < numSensors; i++)
        // Search the wire for address
        if (sensors.getAddress(tempDeviceAddress, i))
          Serial.print("Found device ");
          Serial.print(i, DEC);
          Serial.print(" with address: ");
          printAddress(tempDeviceAddress);
          Serial.println();
          Serial.print("Setting resolution to ");
          Serial.println(TEMPERATURE_PRECISION, DEC);
          // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
          sensors.setResolution(tempDeviceAddress, TEMPERATURE_PRECISION);
          Serial.print("Resolution actually set to: ");
          Serial.print(sensors.getResolution(tempDeviceAddress), DEC);
          Serial.println();
          Serial.print("Found ghost device at ");
          Serial.print(" but could not detect address. Check power and cabling");
      //Serial.println("Readung Temperatures....");
      //Serial.println("Fetched");
      wait(conversionTime);
        float temperature;
        switch (i)  {
          case 0:
            temperature = sensors.getTempC(Probe01);
          case 1:
            temperature = sensors.getTempC(Probe02);
          case 2:
            temperature = sensors.getTempC(Probe03);
          case 3:
            temperature = sensors.getTempC(Probe04);
          default:
            temperature = sensors.getTempCByIndex(Probe04);
        //Serial.println(temperature);
    #if COMPARE_TEMP == 1
          send(msg.setSensor(i).set(temperature, 1));
          lastTemperature[i] = temperature;
      wait(SLEEP_TIME);
    // function to print a device address
    void printAddress(DeviceAddress deviceAddress)
      for (uint8_t i = 0; i < 8; i++)
        if (deviceAddress[i] < 16) Serial.print("0");
        Serial.print(deviceAddress[i], HEX);
    With this I monitor my heat pump boiler.
    • F
      F
      flopp
      I solved it like this
      https://forum.mysensors.org/topic/4143/about-ds18b20-onewire/2
      B 1 Reply Last reply
      • F flopp
        B
        B
        boozz
        @FotoFieber and @flopp
        Thank you both for pointing me in the right direction. As far as I can see from here this contains the solutions for my problem. I'm very happy with this info.
        :+1:
        BR,
        Boozz
        chrilleC 1 Reply Last reply
        • B boozz
          :+1:
          BR,
          Boozz
          chrilleC
          chrilleC
          chrille
          I have been thinking about another solution for this. As present() supports an optional description, it should be possible to send the 1-wire address in the description. Then the controller can handle things and there's no need to hardcode anything in the sketch - it would also mean that there's no need to update the sketch if a 1-wire device gets replaced.
            The idea was to use V_ID for sensor identifiers when available, like on the DS18B20.
            https://www.mysensors.org/download/serial_api_20#set,-req
              chrilleC
              chrilleC
              chrille
              Too bad this isn't supported for domoticz :(
              "Error: MySensors: Unknown/Invalid sensor type (42)"
              • Jan
              F 1 Reply Last reply
              • chrilleC chrille
                • Jan
                F
                F
                flopp
                wrote on last edited by flopp
                • Jan
                I have not tried it my self but it should be possible to use. What version of Domoticz do you use?
                See here which type of identifier that is implemented, seems that it was implemented 18 oct 2015
                https://github.com/domoticz/domoticz/blob/master/hardware/MySensorsBase.cpp
                • F flopp
                  • Jan
                  chrilleC
                  chrilleC
                  chrille
                  I'm using 3.5637 (quite recent beta)
                  It would be interesting to hear if someone actually used the V_ID feature (with domoticz, or other controllers), that would share their sketch - just to see if I'm missing something obvious
                  • Jan
                  • F
                    F
                    flopp
                    I have now test V_ID, not working in Domoticz. I also get
                    • F
                      F
                      flopp
                      @chrille
                      What version of MySensors are you using?
                      I am using 1.5.1
                      • F
                        F
                        flopp
                        I started a thread at Domoticz forum
                        https://www.domoticz.com/forum/viewtopic.php?f=42&t=13373&p=96694#p96669
                        • F flopp
                          @chrille
                          I am using 1.5.1
                          chrilleC
                          chrilleC
                          chrille
                          @flopp said:
                          @chrille
                          I am using 1.5.1
                          I am using 2.0.1
                          • Jan
                          • L
                            L
                            LeoDesigner
                            Check this solution too:
                            https://forum.mysensors.org/topic/2184/enhanced-dallas-temperature-example-with-permanent-sensor-index
