  3. Unique ID-value DS18B20 Temperature sensors
14 Posts 6 Posters 10.4k Views 7 Watching
  • B Offline
    B Offline
    boozz
    Hi all,
    For a project (water supply line in a protective tube buried in the ground) I need to monitor the temperature during winter time. This tube has a lengt of 25 mtrs. in length and every 2 mtrs. i would like to install a DS18B20 sensor.
    Reading out the temperatures is simple using the sketch for the temperatur sensor, but what happens if one of the installed sensors dies in the future. I personally guess the array is updated once the sensor is being reset and my original info (which sensor at what position) is lost.
    Is it possible to fill an extra array with the Unique ID-value of the sensors at initialisation? Has anyone some experience with this or done it before?
    Any other suggestions are welcome as well of course!
    BR,
    Boozz
    • F Offline
      F Offline
      FotoFieber
      There are several examples on the internet and I have cut and pasted my solution for a similar problem with 4 sensors (serial gateway with dallas sensors):
      // Enable serial gateway
      #define MY_GATEWAY_SERIAL
      #if F_CPU == 8000000L
      #define MY_BAUD_RATE 38400
      // Flash leds on rx/tx/err
      // Set blinking period
      // Enable inclusion mode
      // Dallas
      #include <OneWire.h>
      DeviceAddress Probe01 = { 0x28, 0xFF, 0x2E, 0x3E, 0x66, 0x14, 0x01, 0xB2 };
      DeviceAddress Probe02 = { 0x28, 0xFF, 0xB9, 0x40, 0x66, 0x14, 0x01, 0xE9 };
      DeviceAddress Probe03 = { 0x28, 0xFF, 0x47, 0x64, 0x66, 0x14, 0x02, 0x71 };
      DeviceAddress Probe04 = { 0x28, 0xFF, 0x3F, 0x48, 0x66, 0x14, 0x01, 0xA2 };
      #define TEMPERATURE_PRECISION 12
      unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
      int numSensors = 0;
      bool receivedConfig = false;
      bool metric = true;
      MyMessage msg(0, V_TEMP);
      void before()
        sensors.begin();
        sendSketchInfo("Temperature Sensor on Gateway Mega2560", "1.2");
        //Serial.print("Numsensors ");
        //Serial.println(numSensors);
        for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
          present(i, S_TEMP);
        DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
        for (int i = 0; i < numSensors; i++)
          // Search the wire for address
          if (sensors.getAddress(tempDeviceAddress, i))
            Serial.print("Found device ");
            Serial.print(i, DEC);
            Serial.print(" with address: ");
            printAddress(tempDeviceAddress);
            Serial.println();
            Serial.print("Setting resolution to ");
            Serial.println(TEMPERATURE_PRECISION, DEC);
            // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
            sensors.setResolution(tempDeviceAddress, TEMPERATURE_PRECISION);
            Serial.print("Resolution actually set to: ");
            Serial.print(sensors.getResolution(tempDeviceAddress), DEC);
            Serial.println();
            Serial.print("Found ghost device at ");
            Serial.print(" but could not detect address. Check power and cabling");
        //Serial.println("Readung Temperatures....");
        //Serial.println("Fetched");
        wait(conversionTime);
          float temperature;
          switch (i)  {
            case 0:
              temperature = sensors.getTempC(Probe01);
            case 1:
              temperature = sensors.getTempC(Probe02);
            case 2:
              temperature = sensors.getTempC(Probe03);
            case 3:
              temperature = sensors.getTempC(Probe04);
            default:
              temperature = sensors.getTempCByIndex(Probe04);
          //Serial.println(temperature);
      #if COMPARE_TEMP == 1
            send(msg.setSensor(i).set(temperature, 1));
            lastTemperature[i] = temperature;
        wait(SLEEP_TIME);
      // function to print a device address
      void printAddress(DeviceAddress deviceAddress)
        for (uint8_t i = 0; i < 8; i++)
          if (deviceAddress[i] < 16) Serial.print("0");
          Serial.print(deviceAddress[i], HEX);
      With this I monitor my heat pump boiler.
      • F Offline
        F Offline
        flopp
        I solved it like this
        https://forum.mysensors.org/topic/4143/about-ds18b20-onewire/2
        B 1 Reply Last reply
        • F flopp
          B Offline
          B Offline
          boozz
          @FotoFieber and @flopp
          Thank you both for pointing me in the right direction. As far as I can see from here this contains the solutions for my problem. I'm very happy with this info.
          :+1:
          BR,
          Boozz
          chrilleC 1 Reply Last reply
          • B boozz
            :+1:
            BR,
            Boozz
            chrilleC Offline
            chrilleC Offline
            chrille
            I have been thinking about another solution for this. As present() supports an optional description, it should be possible to send the 1-wire address in the description. Then the controller can handle things and there's no need to hardcode anything in the sketch - it would also mean that there's no need to update the sketch if a 1-wire device gets replaced.
            • H Offline
              H Offline
              The idea was to use V_ID for sensor identifiers when available, like on the DS18B20.
              https://www.mysensors.org/download/serial_api_20#set,-req
              • H hek
                chrilleC Offline
                chrilleC Offline
                chrille
                Too bad this isn't supported for domoticz :(
                "Error: MySensors: Unknown/Invalid sensor type (42)"
                • Jan
                F 1 Reply Last reply
                • chrilleC chrille
                  • Jan
                  F Offline
                  F Offline
                  flopp
                  wrote on last edited by flopp
                  • Jan
                  I have not tried it my self but it should be possible to use. What version of Domoticz do you use?
                  See here which type of identifier that is implemented, seems that it was implemented 18 oct 2015
                  https://github.com/domoticz/domoticz/blob/master/hardware/MySensorsBase.cpp
                  • F flopp
                    • Jan
                    chrilleC Offline
                    chrilleC Offline
                    chrille
                    I'm using 3.5637 (quite recent beta)
                    It would be interesting to hear if someone actually used the V_ID feature (with domoticz, or other controllers), that would share their sketch - just to see if I'm missing something obvious
                    • Jan
                    • F Offline
                      F Offline
                      flopp
                      I have now test V_ID, not working in Domoticz. I also get
                      • F Offline
                        F Offline
                        flopp
                        @chrille
                        What version of MySensors are you using?
                        I am using 1.5.1
                        • F Offline
                          F Offline
                          flopp
                          I started a thread at Domoticz forum
                          https://www.domoticz.com/forum/viewtopic.php?f=42&t=13373&p=96694#p96669
                          • F flopp
                            @chrille
                            I am using 1.5.1
                            chrilleC Offline
                            chrilleC Offline
                            chrille
                            @flopp said:
                            @chrille
                            I am using 1.5.1
                            I am using 2.0.1
                            • Jan
                            • L Offline
                              L Offline
                              LeoDesigner
                              Check this solution too:
                              https://forum.mysensors.org/topic/2184/enhanced-dallas-temperature-example-with-permanent-sensor-index
                              12.1k
