  2. Announcements
  3. 💬 Security & Signing
137 Posts 20 Posters 47.5k Views 19 Watching
  • AnticimexA Anticimex
    @damian Hm, I don't find your debug prints you used earlier.
    But in general, I would say that the message object might be overwritten by the library, so if you need to use parts of it, make a copy of the parts you use first and then reference the copy to make sure a new incoming message does not overwrite it.
    Eg, in receive():
      if (message.type==V_STATUS) {
          bool value = message.getBool();
          uint8_t sensor = message.sensor;
          if (firstRun) {
            relayState[sensor] = value;
            } else {
            controllerState[sensor] =  value;
            Serial.print("\nRelay State: ");
            Serial.println(relayState[sensor]);
            Serial.print("Switching to: ");
            Serial.println(controllerState[sensor]);
            if (controllerState[sensor] != relayState[sensor]) {
              relayState[sensor] = controllerState[sensor];
              wait(waitDelay);
              send(msg[sensor].set(relayState[sensor]), false);
            Serial.print("Relay state after if: ");
            digitalWrite(RELAY_PIN+sensor, relayState[sensor] ? RELAY_ON : RELAY_OFF);
    And I believe the cause for your problem is that you do
    send(msg[message.sensor].set(relayState[message.sensor]), false);
    after
            Serial.println(controllerState[message.sensor]);
    but before
            Serial.println(relayState[message.sensor]);
    so message might be changed between since the send() will request a nonce from the GW which then overwrites the buffer referenced by message.
    D
    D
    Damian
    wrote on last edited by Damian
    #121
    @anticimex Thank you, I'll test it and let you know if it helped. PS. debug prints sent before was created in cito, this is my original script. But you find it well, it was instead of:
    and
    So basically the sections that you've mentioned as a possibly buggy.
      Eg, in receive():
            if (firstRun) {
              } else {
                wait(waitDelay);
      after
      but before
      D
      D
      Damian
      #122
      @anticimex Yep, remodelling receive() function by adding variables and assigning values respectively message.sensor and message.getBool at the beginning got the job done. Now it works like a charm. Moreover, the whitelisting feature also works now - I had to do something wrong previously. Thank you once again for your help.
      AnticimexA 1 Reply Last reply
      • D Damian
        AnticimexA
        AnticimexA
        Anticimex
        @damian great to hear! Happy secure home automating :)
        • alowhumA
          alowhumA
          alowhum
          This page is not up to date, and this is causing some confusion:
          https://github.com/tsathishkumar/MySController-rs/issues/15
          • alowhumA alowhum
            AnticimexA
            AnticimexA
            Anticimex
            @alowhum but that is not part of the core library, right? So this thread is perhaps not the best place for discussing 3rd party tools.
            • alowhumA
              alowhumA
              alowhum
              #126
              "This thread contains comments for the article "Security & Signing" posted on MySensors.org."
              @Anticimex This thread is the thread attached to a page on MySensors.org about security.
              I pointed to that (awesome) tool on Github as an example that the page has caused some confusion about whether or not MySensors supports encryption.
              AnticimexA 3 Replies Last reply
              • alowhumA alowhum
                AnticimexA
                AnticimexA
                Anticimex
                @alowhum ok, thanks. Well we do. So please notify that author.
                • alowhumA alowhum
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alowhum as for the link back to mysensors documentation, that documentation is about message signing which is not to be confused with encryption. And on the top of the article is links to the latest documentation which should reflect the latest status on both signing and encryption.
                  • alowhumA alowhum
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @alowhum @hek we should perhaps retire that article or reduce it to a reference to the "actual" documentation instead to reduce the risk of confusion?
                      wrote on last edited by hek
                      #130
                      Yes, maybe we could add a more prominent link in the article to the auto generated documentation. Right now the link easily missed in the ingress.... and it does not link directly to the overview documentation here:
                      https://www.mysensors.org/apidocs/group__MySigninggrpPub.html
                      I don't think we should scrap the page entirely as it contains the none API technical parts as a good overview.
                      • alowhumA
                        alowhumA
                        alowhum
                        @hek said in 💬 Security & Signing:
                        That link still only refers to details about signing, and not encryption. So a user wanting to learn about security might still come away with the idea that only signing is supported.
                        • alowhumA alowhum
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @alowhum yes, it should link here: https://www.mysensors.org/apidocs/group__SecuritySettingGrpPub.html
                          alowhumA 1 Reply Last reply
                            alowhumA
                            alowhumA
                            alowhum
                            @anticimex Great!
                            • YoshuY
                              YoshuY
                              Yoshu
                              Hi All not sure if this should be under gateway or security sections but just wondering If it is possible to run 2 seperate gateways for mysensors netwok
                              • a fully secured network with signing required both node and gateway for all nodes required to send and or receive signed data.
                                -A second unsecured network for gerneral sensor data and equipment not requiring any security
                              • YoshuY Yoshu
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @Yoshu it is possible. When you have two gateways, the networks will be completely isolated so you can run one of them secured while the other is not.
                                You might need to distinguish the nodes on in your controller by giving them static unique ID:s unless your controller ties the identifiers to each gateway or it might be difficult to determine which mysensors network a node belong to.
                                L 1 Reply Last reply
                                  L
                                  L
                                  lood29
                                  @Anticimex more important is to set different network id or you'll have lot of collisions and lost packets
                                  • L lood29
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @lood29 That is correct, assuming the same radio technology is used. Typically, you set up a separate gateway because you want to run a sensor network on a different radio family due to longer distances or similar.
