  2. Announcements
  3. 💬 FOTA (Wireless Programming)
wirelessupdateover the airsensebenderfotafirmware over the airwireless programming
130 Posts 46 Posters 79.6k Views 44 Watching
  • A
    A
    arraWX
    Is it possible to do FOTA from my raspberry pi (serial gateway + domoticz)?
    As it is now I move the gateway from the rpi to a windows pc running MYSController. It would be nice to avoid this step.
    V 1 Reply Last reply
    • A arraWX
      V
      V
      Viciousman
      wrote on last edited by Viciousman
      #62
      @arraWX you can create a Ethernet gateway in raspberry pi and connect MYScontroller to you raspberry pi gateway.
      See instructions to create raspberrypi ethernet gateway on https://www.mysensors.org/build/raspberry
      From there you can perform FOTA in MYScontroller.
      A 1 Reply Last reply
      • V Viciousman
        A
        A
        arraWX
        @Viciousman Thank you!
        How do I create a Ethernet gateway?
        Will I have to build this: https://www.mysensors.org/build/ethernet_gateway
        or
        Will I have to do some kind of configuration on the rpi and continue using my serial gateway?
        • A arraWX
          or
          V
          V
          Viciousman
          @arraWX I find more simple to simply connect nrf24 to raspberry pi as instructed in https://www.mysensors.org/build/raspberry
          But you can also build the Ethernet gateway with W5100.
          • T
            Tommas
            Dear all!
            I have an mysensors ethernet gateway and nodes with nrf24 . I have an openhab2 controller. Could i use the above solution to program my nodes over the air through my current gateway? So i write my sketch on windows arduino and send it through my gateway to the node? Or i have to connect my computer direct to nodes over air?
              You can use myscontroller to connect to the ethernet gateway and assign the firmware to upload for each node
              T V 2 Replies Last reply
                Tommas
                Dear @gohan
                Thank you! Superb!
                  V
                  V
                  vikasjee
                  wrote on last edited by vikasjee
                  #68
                  @gohan , Thanks for this idea... I am going to try this with a serial gateway instead. Do you perceive a problem? Will this work only with an ethernet gw?
                    Myscontroller works only as ethernet. Mycontroller should also work with mqtt gateway but I'm not sure about serial.
                      V
                      V
                      vikasjee
                      @gohan Ook! Are you talking about installing MysController on Raspberrypi (I think not)? If you are going to run it on Windows and connect to Raspi Ethernet gateway remotely then using the the same option we can remotely connect to a serially connected gateway on Raspberrypi (using a USB port) from MysController running on Windows.
                      Are there steps somewhere to install MysController on Raspi [some Windows pre-installer running on Debian Linux]? I remember reading some Mysensors posts here a couple of years back(!!!), but cant seem to locate it now...
                        MyScontroller is a windows application.
                        MyController is a controller that you can install anywhere. I personally try to avoid the usb gateways because of the limitations.
                        • Nca78N
                          Nca78N
                          @scalz do you have any specific reason why you use avrdudes to burn the fuses and burn bootloader separately, instead of using some board definitions matching the bootloader and using the burn bootloader method for Arduino interface ? I think that method is far more user intuitive for the average MySensors user ?
                          • scalzS
                            scalzS
                            @Nca78 just old school habit ;) I think in the video both ways are explained. But I'll take a look at the howto to make it simpler, agree.
                            thx for reminding me!
                            • A
                              A
                              arraWX
                              wrote on last edited by arraWX
                              #74
                              Using FOTA in myscontroller works only occasionally for me. Sometimes it works fine. But most often I get the following messages and nothing more happens.
                              The node is a sensebender micro. Gateway is rpi ethernet.
                              Has anyone experienced something similar? Anyone knows how to solve the problem?
                              EDIT: Problem solved. Reading this post I now understand that in order to get new fw into the node one has to update the sketch, refresh the repo in MysController and assign it the node.
                                Once I managed to burn the sensbender micro bootloader to the pro mini, how do I connect the external flash? Just connect it to pins D10 to D13? Is this the correct way of managing the fota in the sketch before the sleep?
                                  A
                                  A
                                  arraWX
                                  #76
                                  @gohan I recently had some problems with fota and the sensebender sketch you refer to. In this thread @tekka suggested me to enable smart sleep. I used
                                  smartSleep(MEASURE_INTERVAL);
                                  It seems that the smartSleep function has a "built in" MY_SMART_SLEEP_WAIT_DURATION_MS (which defaults to 500 ms). This makes the OTA_WAIT_PERIOD in the sensebender sketch redundant. I deleted it from the sketch.
                                  FOTA now works successfully with my sensebender boards.
                                    I am still in the build phase, I still have to understand how to connect the flash and what to do in the code; also I need to find how to test if everything is is correct
                                    • J
                                      J
                                      jkandasa
                                      @gohan, Yes, MyController works with Serial, Ethernet, and MQTT as well.
                                      gohanG 1 Reply Last reply
                                      • J jkandasa
                                        @jkandasa I know that but I don't know how to work with the flash chip at the moment
                                        • L
                                          L
                                          Luca Calcaterra
                                          Hi guys! I burned mysbootloader but now rs485 doesn't work.. It's normal situation ? A would like to know if is possible to remote upload firmware via rs485 instead of radio. Thanks! Luca
