  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
  • jerseyguy1996J jerseyguy1996
    This may be a stupid question, but I'm using the mysgateway on a Raspberry Pi as my controller which is described here:
    Building a Raspberry Pi Gateway
    The Raspberry pi runs headless and I do everything through ssh. Is there any way to use MYSBootloader using the mysgateway and initiating the OTA update using the command line?
    RedferneR
    RedferneR
    Redferne
    @jerseyguy1996
    You'll need a Controller to update the firmware in the nodes. I'm using MyController.org running on a RPI3 with a MySensors serial Gateway. Works great!
    • karlheinz2000K
      karlheinz2000K
      karlheinz2000
      For all who have problems with serial (debug) output using MYSBootloader:
      When you burn the 8MHz bootloader, it sets avr fuses to internal 8MHz RC oscillator. This has high tolerance. The serial baudrate was only 108000baud in my case and Arduino IDE did not work.
      Setting the fuse to use the external quartz/resonator lead to 111000baud, which was close enough to 115200, to get arduino IDE to read serial data.
      • T
        tlustoch
        Please, can you provide source code? I need to configure radio pins (default MySensors CE and CS pins 9 and 10 are PWM so I need to connect the radio in other way). Thanks a lot!
        • TigroenotT
          TigroenotT
          Tigroenot
          Please help to debug:
          0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
          4 TSM:INIT
          4 TSF:WUR:MS=0
          12 !TSM:INIT:TSP FAIL
          14 TSM:FAIL:CNT=1
          16 TSM:FAIL:PDT
          LorenzoL 1 Reply Last reply
          • TigroenotT Tigroenot
            4 TSM:INIT
            4 TSF:WUR:MS=0
            14 TSM:FAIL:CNT=1
            16 TSM:FAIL:PDT
            LorenzoL
            LorenzoL
            Lorenzo
            @Tigroenot Hi,
            TSM Transmission
            TSP Transport
            PDT Power Down
            !TSM:INIT:TSP FAIL Error during Transport initialization (Radio)
            TSM:FAILURE Error on Transmition (of course, you have a radio error)
            TSM:FAILURE:PDT Radio in Power Down (due to the error)
            Check your radio cabling. If all ok add a capacitor on radio power pins
            • TigroenotT
              TigroenotT
              Tigroenot
              The radio is not wired, it's directly soldered as a chip. I use MySensors Stable Node by @Koresh, but the nrf chips I got from China are probably counterfeit or don't work at all :)
              • karlheinz2000K
                karlheinz2000K
                karlheinz2000
                After flasing a node with ISP (bootloader+sketch) the node will not start since the eeprom is emty (forgot to enable eeprom safe). Node needs to get a ID from controller, even if ID is defined in the sketch. After receiving a ID from controller the node starts and uses the ID from sketch.
                Any solution to overcome this?
                • karlheinz2000K karlheinz2000
                  #68
                  @karlheinz2000 that should not happen. Starting from empty eeprom is normal, that's what all nodes do the first time.
                  Could you post debug output of the node and the gateway when it fails to use the defined id?
                  Just to check: the id was defined before including MySensors.h right?
                  • karlheinz2000K
                    karlheinz2000K
                    karlheinz2000
                    Attached the log file from MYSC. After activating AUTO ID the node starts. No other GW active.
                    No serial output during this time.
                    Node ID is defined before including .h.
                    Node is flashed via ISP (Dragon) with "...with_bootloader.hex".
                    0_1483653188071_MySensors_20170105-223345.log
                    tekkaT 1 Reply Last reply
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      #70
                      @karlheinz2000 I'm not sure I understand you correctly:
                      With a cleared EEPROM, the bootloader will not know any ID defined in the sketch. Instead, the bootloader will fetch a new ID from the controller and store it in EEPROM. Once the sketch starts it will either overtake this newly assigned ID (if MY_NODE_ID == AUTO) or overwrite and use a static ID (if MY_NODE_ID != AUTO) from now on. Does this answer your question?
                      • karlheinz2000K
                        karlheinz2000K
                        karlheinz2000
                        Understood.
                        But if I'm not using MYSB, I can flash a sketch with defined ID and this will work instantly in the network.
                        With MYSB I always have to do assign a new ID just to get the node to run the first time after flashing.
                        Any chance to get MYSB to know, if a sketch is an flash?
                        And start this sketch, which then will use the defined ID or request a new ID from controller and writes the eeprom?
                          Understood.
                          tekkaT
                          tekkaT
                          tekka
                          Yes
                          Only true if EEPROM (i.e. ID address location) was cleared.
                          During booting, MYSBootloader calculates the FW CRC in flash and verifies it against the FW CRC stored in EEPROM (which is written after a successful OTA FW update) - if it matches, the sketch starts, if not, the bootloader remains active.
                          • berkseoB
                            berkseoB
                            berkseo
                            This post is deleted!
