  3. send(msg(double)); gives an error
3 Posts 2 Posters 2.6k Views 2 Watching
  • Martin TellblomM
    Martin TellblomM
    Martin Tellblom
    I have defiened a MyMessage as this:
    MyMessage msgSpeed(WIND_CHILD_ID, V_WIND);
    Present it like this:
    present(WIND_CHILD_ID, S_WIND);
    And I get an error for this row since windSpeed is a double.
    send(msgSpeed.set(windSpeed));
    Get the error message:
    Wind:94: error: call of overloaded 'set(double&)' is ambiguous
    Is it so that I can't send anything other than an INT for windspeed?
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
    AWIA 1 Reply Last reply
    • Martin TellblomM Martin Tellblom
      AWIA
      AWIA
      AWI
      @Martin-Tellblom It depends on the type of the variable (windspeed) you are trying to send how you send it. sometimes you need to specify decimals. See below taken from the API
      // Setters for payload
      MyMessage& set(void* payload, uint8_t length);
      MyMessage& set(const char* value);
      MyMessage& set(uint8_t value);
      MyMessage& set(float value, uint8_t decimals);
      MyMessage& set(unsigned long value);
      MyMessage& set(long value);
      MyMessage& set(unsigned int value);
      MyMessage& set(int value);
      • Martin TellblomM
        Martin TellblomM
        Martin Tellblom
        Thank you @AWI , I missed that one.
