  3. SOFT-SPI on Arduino Nano
7 Posts 4 Posters 6.4k Views 2 Watching
  • foad62F
    foad62F
    foad62
    My goal is to connect an LCD to Arduino Nano. I'm using Arduino Nano because of it's small size. Since SPI port is used by NRF24 module, is it possible to enable SOFT-SPI on arduino nano and connect the LCD to it?
    sundberg84S frishrashF 2 Replies Last reply
    • foad62F foad62
      @foad62 - what kind of LCD is it?
      I used i2c instead to connect my LCD to avoid conflict with SPI and it worked great. (Sorry, dont know the answer to your qustion about soft-spi).
      • foad62F
        foad62F
        foad62
        It is 1.8" TFT LCD (TFT-LCD-ST7735).
        I'm not sure if it supports I2C connection!
        • foad62F foad62
          @foad62 - checked the adafruit library out but I coudlnt find anything about i2c either...
          • tbowmoT
            tbowmoT
            tbowmo
            @foad62
            You could try sharing the SPI bus.. In most cases it will work, only W5100 ethernet module is special, in that way it doesn't tri-state the MISO line when it's not deselected with the normal CS line..
            Just pick a separate pin for CS for the display, than the one for the NRF module, and configure your TFT library accordingly.
            foad62F 1 Reply Last reply
            • foad62F foad62
              frishrashF
              frishrashF
              frishrash
              @foad62 I don't know if it helps but you can modify the default pins MySensors expects the NRF chip to be connected to. Here is an example, works on my Nano with MySensors 2.0:
              #define MY_SOFTSPI
              #define MY_RF24_CE_PIN 11
              #define MY_RF24_CS_PIN 6
              #define MY_SOFT_SPI_SCK_PIN 10
              #define MY_SOFT_SPI_MISO_PIN 9
              #define MY_SOFT_SPI_MOSI_PIN 7
              In my case I didn't try connecting another SPI device, I just moved the pins for easier NRF soldering on a perfboard.
              • tbowmoT tbowmo
                @foad62
                foad62F
                foad62F
                foad62
                @tbowmo
                Thank you. I'll give it a try.
