  3. Minimal design thoughts
299 Posts 34 Posters 276.8k Views 17 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @Anticimex
    My plan is to just run your test code, to verify that i can talk to the device. Just like i did with the external Flash chip.
    AnticimexA 1 Reply Last reply
    • tbowmoT tbowmo
      @Anticimex
      AnticimexA
      AnticimexA
      Anticimex
      @tbowmo
      Alright. Just so you know, I have not adapted it for your board pinout yet. I will change my breadboard prototype accordingly and retest when I implement the non-UART support in the personalizer. I hope to be finished with that before you get your samples.
      • tbowmoT
        tbowmoT
        tbowmo
        #183
        Hmm.. I like dirtypcbs "honest" approach to things:
        Hey Thomas Mørch,
        Your PCB order number xxxxx has been shipped.
        If you used DHL/FEDEX/UPS a tracking number will be sent later. We hope it is provided within 48hours, but our logistics company is being painfully slow with updates and provides incorrect numbers. We fired them, and will start working directly with DHL October 1st, 2014.
        • AnticimexA
          AnticimexA
          Anticimex
          I'm going to enjoy this ^^
          • tbowmoT
            tbowmoT
            tbowmo
            @Anticimex
            :) The whole site of dirtypcbs are made up like that, trash talking their own product.. But so far the service has been ok from them. This is first time I ordered with express shipment, hopefully they'll arive later this week..
            • AnticimexA
              AnticimexA
              Anticimex
              @tbowmo said:
              dirtypcbs
              Well, for a site that in their website footer prints
              "No bull, just crappy PCBs"
              what can possibly go wrong :D
              RJ_MakeR 1 Reply Last reply
              • AnticimexA Anticimex
                @tbowmo said:
                dirtypcbs
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @Anticimex said:
                @tbowmo said:
                dirtypcbs
                LOL
                RJ_Make
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @Anticimex
                  Just received the tracking number.. (so it took them 2 days to go from the factory to the shipping company :))
                  Anyway, now I have a tracking number, so I can keep an eye on things :)
                  • tbowmoT tbowmo
                    I'm thinking about spinning up the good old eagle cad program again, and start creating sensor boards (Like so many others here :))
                    Only thing is, that unlike (almost) everyone else, that are using normal arduino micro boards, I'm thinking about skipping that part, and create my "own" arduino board, thinking about the following:
                    1. use atmega 328 tqfp (That's doable for home soldering :))
                    2. pads for a 32Khz crystal, for timing purposes
                    3. Standard atmel programming header.
                    4. ftdi header like on arduino mini, so could use arduino bootloader (could be some details about the baudrate though, as it's running off internal RC oscillator)
                    5. Using Si7021 integrated humidity / temperature sensor, footprint for bmp180 barometric sensor
                    6. skip power converters, run everything off a battery directly (disable brownout detection in atmel)
                    7. SPI flash / e2prom onboard. Using same connections as moteino from lowpowerlabs, so should be able to use same bootloader for updates to firmware
                    8. pinheader for connecting radio module
                    9. Pinheader for D3-D7 on one side, and SDA/SCL + A0/A1 and power on the other side
                    10. Formfactor is 30x17.5mm (almost same size as the NRF24 module).
                    11. ATSHA204A sot23 footprint on board (Connected to A3). Can be used for SHA256 key exchange and verification
                    12. status LED (on A2)
                    Any thoughts about this? Or should I wait for the all in one mysensors battery sensor board? (When will that be available?)
                    / Thomas
                    (Spec updated January 28th, 2015)
                    C
                    C
                    CodeIt
                    @tbowmo Since Domoticz (home automation software) got support for MySensors i have been looking for cool sensors. I want to place a MySensor node in every room in my house with temp/humidity motion and reed contact, run directly from battery. Your board looks very promising. I only have one question. Is it possible to have two interrupts (for the motion sensor and reed contact)?
                    hekH 1 Reply Last reply
                    • C CodeIt
                      wrote on last edited by hek
                      #190
                      @CodeIt
                      D2 is connected to radio socket IRQ pin.
                      But as it currently not used by the library you could just cut the leg on radio and connect it to whatever you want.
                      • axillentA
                        axillentA
                        axillent
                        wrote on last edited by axillent
                        #191
                        it is also possible to use PCINT interrupt on mostly any digital or even analog pin
                        sense and drive
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          What bootloader should I go for, for the prodcution run? (that is preload a bootloader into the atmega) ?
                          I am also thinking about preloading a default sketch as well, so it's almost plug'n'play.
                          (@hek, this default sketch should probably be included in the mysensors git repo, right ?)
                          / Thomas
                            #193
                            Yep, a default sketch would be nice that reports temp/hum. Think it should be added to examples-folder like the others.
                            Would be fun to test the flash as well... Haven't seen @ToSa (the bootloader developer) around here for a while. Ideally a new bootloader should be adopted and MySensors library store bootloader update messages (in flash) at normal "runtime".
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @hek
                              I have been trying to get DualOptiboot from lowpowerlabs to run.. because it's able to use the external flash. It also seems like it is starting up as it flashes the LED during bootup, but it doesn't respond when I try to download via serial port using arduino. I might be blind or something, as I can't seem to figure out what the *beep' is going on :)
                              I have a sketch now, that is running on the first prototype here.. Should I make a pull request, to add it?
                              Btw. I have tested the external flash, by writing "random" bytes to it, and read it back again.. So I know it is working.
                              hekH tekkaT 2 Replies Last reply
                              • tbowmoT tbowmo
                                @hek
                                Yep, do that.. And include the libraries for flash/hum/temp if needed.
                                • tbowmoT tbowmo
                                  @hek
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @tbowmo which flash ic are you using?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @tekka
                                    It's an adesto AT25DF512C-SSHN-B. Chosen because supply range is 1.8 - 3.6V (It's a bit hard finding flash chips that cover the whole range)
                                      @tbowmo
                                      Regarding bootloader I stumbled upon this:
                                      http://hallard.me/ulpnode-bootloader/
                                      http://hallard.me/ulpnode-bootloader-1/
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @hek
                                        I don't have problems with bootloaders in general, I tried the standard arduino bootloader, and it works ok. It's just the DualOptiboot from lowpowerlab I can't get to work.. And it drives me crazy :)
                                        Think I need to figure out some way of debugging the bugger, to figure out what it is doing, but it's hard to find time for it, when I only have one hour every now and then for debugging..
                                        tekkaT 1 Reply Last reply
                                        • tbowmoT tbowmo
                                          @hek
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @tbowmo yup, debugging these things is a pain in the neck - I've been working on the OTA bootloader for a while (mainly optimizing size, speed and additional features). What works best for me, is using debugwire in atmel studio...but sometimes quite cryptic and not straight forward :)
                                          tbowmoT 1 Reply Last reply
