  3. Minimal design thoughts
299 Posts 34 Posters 276.8k Views 17 Watching
    @doblanch
    The board has humidity/temperature build in. So we only need space for maybe one extra sensor (question is how large volume this would need?).
    Punch out holes for wires to external things like permanent power, buttons or reed-switches.
    Click on cover would be nice but requires more accuracy in the making. A screw wouldn't be a big problem.
    Many variables... ;)
    D
    D
    doblanch
    @hek I know , yes for the T/H sensor. As we put 2 AA battery, we have to know if we want to stack sensor/battery or not...otherwise, battery and sensor will be on the same plan.
    I think that we can start without extra sensor, and add it in function of request, I'm going to buy a 3D printer, It will be my first tests.
    • tbowmoT
      tbowmoT
      tbowmo
      Today the production files have been sent off to China, for the first batch of 5 prototypes build by them. We then need to verify them, and if they are found OK, we start a larger production run.
      Feeling like Christmas is comming up :)
        markusand
        I'm too late for my suggestion, but maybe it can be implemented in future versions if considered. Just in order to simplify connectivity with sensors, spare pins could be accessible via grove connectors. However the board looks amazingly small!
        • Ivan ZI
          Ivan ZI
          Ivan Z
          Why do not use CR123A accumulator?
          It is smaller and can be charged.
          And not nide regulator
          I use box with charger. With CR123A accumulator.
          http://www.ebay.com/itm/2600Mah-USB-Portable-External-Battery-Charger-Power-Bank-for-Cell-Mobile-Phone-/301514424642?pt=LH_DefaultDomain_0&var=&hash=item4633a90142
          Very cheap
          jendrushJ 1 Reply Last reply
          • Ivan ZI Ivan Z
            Very cheap
            jendrushJ
            jendrushJ
            jendrush
            @Ivan-Z Really nice idea for battery powered nodes:)
            • korttomaK
              korttomaK
              korttoma
              @Ivan-Z how did you connect the power to the arduino? How are you powering the Radio? Is it a Pro Mini 3.3V? How long does the battery last? Did you do anything special to the arduino ( hardware changes or something else? )
              • Tomas
              • Ivan ZI
                Ivan ZI
                Ivan Z
                wrote on last edited by Ivan Z
                #267
                CR123A in full charge has 4.07v
                Gas counter started 2014/11/01.
                In winter, temperatures drop below -10
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @Ivan-Z
                  You say that it don't need a regulator? the battery voltage is 4.07 when fully charged, that is 0.47V above the absolute maximum rating of the NRF24L01+, as it's only rated to 3.6V maximum. Same goes for the Si7021, maximum supply voltage is 3.6V.
                  So CR123A is not a good battery, unless you put a regulator in the loop, which then again uses current, and causes a voltage drop from battery supply
                  • Ivan ZI
                    Ivan ZI
                    Ivan Z
                    #269
                    DHT22 = 3.3-6V DC
                    CR123A = 3.6v ( Bat full charge i have 4.07v )
                    NRF24L01+ = 3.6
                    I have 8 device and his work with CR123A for 6 months
                    When charge some device cannot translate packets, but after work
                    AWIA 1 Reply Last reply
                    • Ivan ZI Ivan Z
                      DHT22 = 3.3-6V DC
                      NRF24L01+ = 3.6
                      AWIA
                      AWIA
                      AWI
                      @Ivan-Z I think you are lucky... I burned a few radio's with a similar setup (with LiPO solar charger) I like your minimal design. If you replace the DHT sensor with a htu21 you can make it even smaller. There are a few htu21d boards with a 3.3v regulator on it which you could use to power the radio.
                      • Ivan ZI
                        Ivan ZI
                        Ivan Z
                        @AWI
                        What regulator do you use?
                        I do not use the regulator because it has a extremeconsumption
                        AMS1117-3.3 = 5~10mV in idle
                        • Ivan ZI Ivan Z
                          @AWI
                          AWIA
                          AWIA
                          AWI
                          @Ivan-Z I use the XC6206 series regulator. most of the times. The quiescent current for this one is very low 1-3 uA. This regulator is used by many of the sensor board suppliers to supply sensors with 3.3v Eg. In many cases (eg Adafruit) you can use the board as a "3.3v power supply"
                          upload-087eda80-75af-457b-804a-a16e6d67612f
                          • Roberto BrunialtiR
                            Roberto BrunialtiR
                            Roberto Brunialti
                            wrote on last edited by Roberto Brunialti
                            #273
                            Hi guys. I'm waiting for your board!
                            the only concern is about the 2xAA batteries adoption that could increase the overall size of a sensor node to a "normal node" size ( http://www.seeedstudio.com/depot/s/devduino.html?search_in_description=0).
                            I would like a stack as following: battery+board+radio. with the same footprint of the radio module.
                            The battery could be a CR123 with regulator, and the holder could be a pcb holder as this: http://www.memoryprotectiondevices.com/datasheets/BH-CR2-PC-datasheet.pdf
                            I actually ordered some of these: http://www.elecrow.com/devduino-sensor-node-v4-atmega-328-p-1201.html, at this moment the closest to my size requirements.
                            What do you think.?
                            • Roberto BrunialtiR Roberto Brunialti
                              What do you think.?
                              AWIA
                              AWIA
                              AWI
                              @Roberto-Brunialti I am looking forward to this board also. I deployed a few Devduino V4's. These are really well built but lack the "minimal" size, have only a few connectors (enough in most cases as a good temp/hum sensor is on board).. And "restrict" you to the use of non-rechargable CR123 cells (3V,no regulator). I will love the very small footprint combined with the flexibility in power sources (and extra features) in the "Minimal design thoughts" design. :heart_eyes:
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                Think we should rename the thread to "Mysensors Micro" as this is the new name, since it's the first "official" board from mysensors.
                                Anyway, just got a couple of pictures from the factory in China, they have build the first batch of 5 pcb's that they are verifying at the moment, and then they should be shipped to us (either @hek or me?) and then we need to verify it, before giving a go on the production.
                                So we are comming closer to a "launch" of the device.
                                hekH 1 Reply Last reply
                                • tbowmoT tbowmo
                                  @tbowmo
                                  Yep, might also be good to create a new thread in Announcement when it has been launched (and is for sale) with a back-reference here for history/design decisions made by you.
                                  I should probably start working on a more complete page on the main site with more details and illustrations.
                                  • T
                                    Tibus
                                    In your design, C3, the nrf 4u7 capacitor, is a classic ceramic capacitor. In the mysensors tutorial, they write a polarized capacitor is better for the NRF. I use tantalum capacitor wich are bigger but is there a difference with the ceramic one for the nrf. I would like to use a ceramic 0603 too if there is no difference for nrf.
                                    Thank's
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Tibus
                                      In theory ceramic capacitors should be better, it has a lower ESR, and are better suited to reduce ripple, or noise on the supply locally, as it has a faster response to power requirements, than equivalent electrolytic capacitors.
                                        Mickey
                                        will it be possible to use this board pcb without soldering the sensor , flash and security chip?
                                        tbowmoT 1 Reply Last reply
                                        • M Mickey
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @Mickey
                                          Yes, you can use it without those mounted. But I don't think that we are going to sell it without those components mounted
