  3. Minimal design thoughts
299 Posts 34 Posters 276.8k Views 17 Watching
  • T Tibus
    i'm also making my own sensor right now and the si7021 is very interesting for removing my BIG dht11. But for home made soldering, the center ground pad should be soldered or it's not necessary?
    tbowmoT
    tbowmoT
    tbowmo
    To my best knowledge, there is no "center ground pin" on the Si7021? Or I have missed something. A friend of mine got a couple of them for another project, so I'll check up with him on the physical appearance, next time we get together.
    @bjornhallberg said:
    Sounds very interesting! Though personally I'd rather have a good regulator / boost (even if it is in a separate module) than having to source particular components that will run at 1.8V.
    Btw. pricewise, comparing DHT22 and Si7021 they are about the same price (ebay price on DHT22, and mouser price for Si7021). So for sourcing DS18b20/DHT22, or sourcing the Si7021, is not that big a difference. I also can skip the stepup converter, and save a couple of $ there..
    How do you plan to integrate the nrf24? The "standard" or the "mini" version?
    It's the standard version, piggybacking on the minisensor. Actually (on the nrf24 modules that I have), the component area is 15x20mm (excluding the antenna part) So my arduino-clone could fit without "covering" the antenna..
    I would love it if the MySensors web site could have a department of open source pcb schematics just like it has models for 3D printing.
    That would be great.. :)
    Anyway, I'll take a few more stabs at the schematic / layout before I publish it here..
    T 1 Reply Last reply
    • tbowmoT tbowmo
      Tibus
      wrote on last edited by Tibus
      #22
      @tbowmo
      Yes there is a TGnd Pad in the middle :
      http://www.silabs.com/Support Documents/TechnicalDocs/Si7021.pdf
      page 26... But I'll buy a Hot Air soldering station, i'll be easier to solder no?
        Soldering sounds tricky, you'd either have to reflow or heat the underside of the DFN6 on the pcb. With extra flux and paste.
        Yes, I would gladly create a section for this on the main site. But maybe we could start a pinned thread linking the once available?
        • T Tibus
          @tbowmo
          bjornhallbergB
          bjornhallbergB
          bjornhallberg
          wrote on last edited by bjornhallberg
          #24
          @Tibus Or perhaps you have a hot air gun in the toolbox. Not as elegant but it might do.
          I'd much rather not try hot air (only have this at my disposal) and instead try to get at the pad from the backside of the pcb:
          http://www.eevblog.com/forum/projects/soldering-dfn-and-qfn-devices/
          With flux and paste possibly it should be quite easy. And besides, you'd need flux and/or paste for hot air reflow as well.
          • tbowmoT
            tbowmoT
            tbowmo
            #25
            Schematic as it is at the moment:
            And the board as it is right now
            I know it says eeprom for IC2, but the footprint is the same for SPI flashes.
            the eeprom is placed on the bottom layer. Also, the nrf24 is placed on the bottom (so the eeprom is "in the middle of the sandwich". The dimensions of the total board will be about 15x30mm. This is the same size as the radio module. The empty area on the top is the area below the antenna.
            Still need to make changes to the DFN package (upper right). and make a footprint for a bmp180 barometric sensor (and find a good home for it on the board).
            Also, need to tidy up the routing, I used the autorouter which is very bad at placing the traces (haven't got any better since I used eagle the last time 11 years ago..) So maybe I just end rip everything up and hand route it by hand (this is the fun part of pcb designs, trying to mingle everything in to place :) thinking about the things my teacers told me 20 years ago about PCB design (oh f*ck I feel like an old geezer now! :))
            Oh yeah, btw. there is also made room for a crystal (32Khz) on there.
            • tbowmoT
              tbowmoT
              tbowmo
              And yes, I know i'm missing pull ups on i2c bus, and decoupling capacitors on the 328
                This will be a very small board indeed! Not an expert but couldn't the radio interfere with MCU at these short distances?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @hek
                  It would be more the other way arround. The MCU is making trouble for the receive path of the radio module. But the radio module has a large gnd plane on the bottom towards the mcu board, so it should be shielded.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    A new schematic / layout
                    I'm almost ready for sending it off to China, and get some boards back :)
                    Changes since last:
                    2 LED's added (figured debug output could be nice)
                    pullups added on i2c bus
                    caps changed to 0603 footprint
                    added a couple of extra caps for decoupling (MCU)
                    Added BMP180 barometric sensor (only need 1 node with this one though)
                    Moved components arround, squeezing things a little bit more together.
                    Routed manually this time, not that big a board, so no need to use the autorute function
                    Testpads on upper right corner of the pcba is GND, RXD/TXD and VCC, again nice to have serial available for debugging the first couple of boards.
                    Board is designed with dirtypcbs.com in mind for production (Used their DRU file in eagle to check things).
                    Schematic:
                    and pcb layout:
                    • bjornhallbergB
                      bjornhallbergB
                      bjornhallberg
                      Fantastic! But I agree that is is perhaps a bit odd to have a footprint for a BMP180 on every board. You'll get a lot of boards when ordering 10x 5x5cm PCBs.
                      0603 ... time to get soldering. Haha. But those solder pads look pretty big actually. Is this the issue where Eagle actually makes 0603 caps more solderable than 0805 by making the pads longer?
                      tbowmoT 1 Reply Last reply
                        tbowmoT
                        tbowmoT
                        tbowmo
                        I know, but I thought that I just as well could put one in there when I was designing the pcb. Otherwise I would have to get it on an external pcb (sparkfun sells bmp180 breakut boards). And there was room for it :)
                        Don't know, last time I used eagle (about 10 years ago) I made layouts with 0805 components, (and an atmega8). Actually I think that the board I made back then is still being used in production.
                        /Thomas
                        • bjornhallbergB
                          bjornhallbergB
                          bjornhallberg
                          #32
                          Any thoughts on how to panelize it? You'd get like six boards on a 5x5 if those dimensions hold? Perhaps you could do some alternative layouts for different sensors? I understand dirtypcbs no longer do grooving (if they ever did) ... how much pcb space is lost to routing typically?
                          In case anyone else is wondering about dirtypcbs, they seem to do an ok job typically:
                          http://lab.kjlr.dk/p/handystick
                          http://hackers.gallery/236/electronics/pcb-itead-studio-vs-dirtypcbs
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            The full size is 16x31 mm at the moment. So it's almost the same size as the normal nrf24 modules on ebay. So if I panelize them i can get 4 modules in total on a single 5x5 area.
                            Let's see when i come around to order them. I just like the dirty pcb as it reminds me of a song from my favorite rockband (ac/dc) :)
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              #34
                              Arh.. just found out that the pinheader for the radio was turned 180 degrees, so instead of the 2 boards being on top of eatch other, they would "go in two different directions". Had to rip up most of the board, and re-arrange things again.
                              only changes on the schematic, is that the LED's are moved to a couple of other pins.
                              / Thomas
                              • N
                                N
                                NotYetRated
                                Very interesting, this one board would cover all that I need for the majority of my sensors. Would need a couple of sensors with IR, and a couple of others. Is the reason for this the reduced foot print, a reduced cost over arduino pro's, or something else?
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @NotYetRated
                                  One of the reasons is that I wanted to go with battery, without all the extra "cruft" that is on standard arduino boards (like regulators etc.),
                                  Also I want to make it as clean as possible, as I'm planning on creating 10-20 nodes in total I don't like to make them as "birdsnests" with multiple boards stiched together with wires.
                                  It also almost became an obsesson to see how small I could get it :).
                                  Maybe I can save a little $ by roling my own layout, but not the main driving force.
                                  N 1 Reply Last reply
                                  • tbowmoT tbowmo
                                    @NotYetRated
                                    N
                                    N
                                    NotYetRated
                                    @tbowmo Ahh, understood! I too plan for, somewhere around 20 nodes. However I plan to wall wort power most of mine. The only real exception will be a few outside, and inconvenient to reach places.
                                    I do like the idea of eliminating as much of the "birds nest" as possible... My first couple of, what I am currently calling prototype sensors, are, well inside their boxes, very ugly. haha.
                                    • daulagariD
                                      daulagariD
                                      daulagari
                                      @tbowmo Very nice design!
                                      Personally I would make something similar but with the option to charge things using an external solar cell or just a charger. With the new generation of low-leakage NiMH rechargeable batteries I am very tempted using these to power the sensor.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @daulagari
                                        Is it necessary to use solar power? A couple of standard AA batteries, is probably good for 2000mAh, and with a consumption of below 50uA, you got battery power for 4-5 years..
                                        Also the sun doesn't shine inside my house ;)
                                        / Thomas
                                        • daulagariD
                                          daulagariD
                                          daulagari
                                          Sounds great, 4-5 years without changing batteries but will that be real? The bad thing is that if true it take 4-5 years to prove it.
                                          But a solar cell does not need solar to generate (some) current unless your house is completely dark ;-)
                                          But yes, if it is only 2-3 year going with rechargeable batteries is overkill.
