  3. Clear EEPROM - sketch after that not working-HELP
3 Posts 3 Posters 4.2k Views 3 Watching
  • pepsonP
    pepsonP
    pepson
    Hi all. I am begginer. Please help me. I clear EEPROM in my Arduino Mini Pro by this manual:
    https://www.arduino.cc/en/Tutorial/EEPROMClear
    Write this as sketch. After that i write sketch to control 2x Relays in MySensors and sketch upload successfull. But not working... No connect to MySensorns Gateway and Relay not start. I test it also on second device and the same problem. Connection wire is all ok. I check it.
    This problem is after clear EEPROM. Please help me .... Please.
    • FotoFieberF
      FotoFieberF
      FotoFieber
      Could you please:
      • attach your sketch
      • enable debug and attach the serial output
      I can thin of
      • problems with assigning a new node-id (controller)
      • problems with encryption keys stored in eeprom
        That sketch initialises EEPROm to zeroes which isn't the factory value, 0xff.
        Use the MySensors provided sketch instead:
        https://www.mysensors.org/build/debug#clearing-eeprom
