  3. RelayActuator message not going threw
17 Posts 3 Posters 5.5k Views 1 Watching
  • frenchoF
    frenchoF
    frencho
    wrote on last edited by frencho
    Hi ,
    I'm trying to make a realy actuator on my system :
    Gateway serial working with temp sensor v2 using the standard program provided with the myConfig configured for RFM69
    The node with the relay runs the following code :
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_REPEATER_FEATURE
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    void before() {
        pinMode(pin, OUTPUT);
        present(sensor, S_BINARY);
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    The node has the ID 65, when I send via MYScontroller, or my domotic controler (Jeedom) a message to set the relay on/off the node doesn't receive anything
    here are the log on node side :
    0 MCO:BGN:INIT REPEATER,CP=RRNRA--,VER=2.0.1-beta
    4 MCO:BGN:BFR
    6 TSM:INIT
    8 TSM:INIT:TSP OK
    10 TSF:SID:OK,ID=65
    12 TSM:FPAR
    145 TSF:MSG:SEND,65-65-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    825 TSF:MSG:READ,0-0-65,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    831 TSF:MSG:FPAR OK,ID=0,D=1
    2152 TSM:FPAR:OK
    2152 TSM:ID
    2154 TSM:ID:OK
    2156 TSM:UPL
    2164 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2183 TSF:MSG:READ,0-0-65,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2189 TSF:MSG:PONG RECV,HP=1
    2191 TSM:UPL:OK
    2193 TSM:READY
    2203 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2373 !TSF:MSG:SEND,65-65-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=NACK:2.0.1-beta
    2390 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:0
    4405 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
    4419 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    4435 TSF:MSG:SEND,65-65-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4450 TSF:MSG:SEND,65-65-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4466 TSF:MSG:SEND,65-65-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4481 TSF:MSG:SEND,65-65-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4487 MCO:REG:REQ
    4497 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4554 TSF:MSG:READ,0-0-65,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4560 MCO:PIM:NODE REG=1
    4564 MCO:BGN:STP
    4567 MCO:BGN:INIT OK,ID=65,PAR=0,DIS=1,REG=1
    601131 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    601137 TSF:MSG:BC
    601284 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
    601292 TSF:MSG:FWD BC MSG
    601425 TSF:MSG:SEND,0-65-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    1199908 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    1199915 TSF:MSG:BC
    1200738 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
    1200746 TSF:MSG:FWD BC MSG
    1200879 TSF:MSG:SEND,0-65-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    The message sent to trun on//off the relay for is for exemple :
    65;4;1;1;2;1 or 0
    any Idea why the messages is not going threw ?
    thanks
    Your second life begins when you understand you only have one !
    tekkaT 1 Reply Last reply
    • frenchoF frencho
      Hi ,
      void before() {
      4 MCO:BGN:BFR
      6 TSM:INIT
      8 TSM:INIT:TSP OK
      10 TSF:SID:OK,ID=65
      12 TSM:FPAR
      2152 TSM:FPAR:OK
      2152 TSM:ID
      2154 TSM:ID:OK
      2156 TSM:UPL
      2191 TSM:UPL:OK
      2193 TSM:READY
      4487 MCO:REG:REQ
      4564 MCO:BGN:STP
      601137 TSF:MSG:BC
      1199915 TSF:MSG:BC
      65;4;1;1;2;1 or 0
      thanks
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @frencho Without additional information it's hard to guess - Please also provide the debug log from the GW.
      frenchoF 1 Reply Last reply
      • tekkaT tekka
        frenchoF
        frenchoF
        frencho
        @tekka
        here we go the gateway log
        03/11/2016 21:12:31	INFO	Connected to COM12
        03/11/2016 21:12:33	RX	0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
        03/11/2016 21:12:33	RX	0;255;3;0;9;TSM:INIT
        03/11/2016 21:12:33	RX	0;255;3;0;9;TSM:INIT:TSP OK
        03/11/2016 21:12:33	RX	0;255;3;0;9;TSM:INIT:GW MODE
        03/11/2016 21:12:33	RX	0;255;3;0;9;TSM:READY
        03/11/2016 21:12:33	RX	0;255;3;0;14;Gateway startup complete.
        03/11/2016 21:12:33	DEBUG	Update child id=255, type=ARDUINO_RELAY
        03/11/2016 21:12:33	RX	0;255;0;0;18;2.0.1-beta
        03/11/2016 21:12:33	RX	0;255;3;0;9;MCO:REG:NOT NEEDED
        03/11/2016 21:12:33	RX	0;255;3;0;9;MCO:BGN:STP
        03/11/2016 21:12:33	RX	0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
        03/11/2016 21:12:48	RX	0;255;3;0;9;TSF:MSG:READ,65-65-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        03/11/2016 21:12:48	RX	0;255;3;0;9;TSF:MSG:BC
        03/11/2016 21:12:48	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=65
        03/11/2016 21:12:48	RX	0;255;3;0;9;TSF:PNG:SEND,TO=0
        03/11/2016 21:12:48	RX	0;255;3;0;9;TSF:CKU:OK
        03/11/2016 21:12:48	RX	0;255;3;0;9;TSF:MSG:GWL OK
        03/11/2016 21:12:49	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        03/11/2016 21:12:50	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        03/11/2016 21:12:50	RX	0;255;3;0;9;TSF:MSG:PINGED,ID=65,HP=1
        03/11/2016 21:12:50	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        03/11/2016 21:12:50	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        03/11/2016 21:12:50	RX	0;255;3;0;9;!TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
        03/11/2016 21:12:50	RX	0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
        03/11/2016 21:12:50	RX	0;255;3;0;9;TSM:INIT
        03/11/2016 21:12:50	RX	0;255;3;0;9;TSM:INIT:TSP OK
        03/11/2016 21:12:50	RX	0;255;3;0;9;TSM:INIT:GW MODE
        03/11/2016 21:12:50	RX	0;255;3;0;9;TSM:READY
        03/11/2016 21:12:50	RX	0;255;3;0;14;Gateway startup complete.
        03/11/2016 21:12:50	DEBUG	Update child id=255, type=ARDUINO_RELAY
        03/11/2016 21:12:50	RX	0;255;0;0;18;2.0.1-beta
        03/11/2016 21:12:50	RX	0;255;3;0;9;MCO:REG:NOT NEEDED
        03/11/2016 21:12:50	RX	0;255;3;0;9;MCO:BGN:STP
        03/11/2016 21:12:51	RX	0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
        03/11/2016 21:12:51	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
        03/11/2016 21:12:51	TX	65;255;3;0;6;M
        03/11/2016 21:12:51	RX	65;255;3;0;6;0
        03/11/2016 21:12:52	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
        03/11/2016 21:12:52	RX	65;255;3;0;11;Relay
        03/11/2016 21:12:52	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        03/11/2016 21:12:52	RX	65;255;3;0;12;1.0
        03/11/2016 21:12:52	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
        03/11/2016 21:12:52	DEBUG	Update child id=1, type=LIGHT
        03/11/2016 21:12:52	RX	65;1;0;0;3;
        03/11/2016 21:12:53	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=2,c=0,t=3,pt=0,l=0,sg=0:
        03/11/2016 21:12:53	DEBUG	Update child id=2, type=LIGHT
        03/11/2016 21:12:53	RX	65;2;0;0;3;
        03/11/2016 21:12:53	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
        03/11/2016 21:12:53	DEBUG	Update child id=3, type=LIGHT
        03/11/2016 21:12:53	RX	65;3;0;0;3;
        03/11/2016 21:12:53	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=4,c=0,t=3,pt=0,l=0,sg=0:
        03/11/2016 21:12:53	DEBUG	Update child id=4, type=LIGHT
        03/11/2016 21:12:53	RX	65;4;0;0;3;
        03/11/2016 21:12:53	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
        03/11/2016 21:12:53	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
        03/11/2016 21:13:02	TX	65;4;1;1;2;0
        03/11/2016 21:13:47	TX	65;3;1;1;2;0
        03/11/2016 21:13:52	TX	65;2;1;1;2;0
        03/11/2016 21:13:56	TX	65;1;1;1;2;0
        If you need anything else ....
        I was actually hoping it would be some set up I would have forgotten or some like that !
        • frenchoF frencho
          @tekka
          tekkaT
          tekkaT
          tekka
          @frencho Looks like the GW does not receive your message (debug output missing after sending). Describe your GW HW (type, connection, speed) & upload the GW sketch.
          • tekkaT tekka
            frenchoF
            frenchoF
            frencho
            @tekka thanks for the analysis !
            I have tryied two different GW : one was with gertsanders arduino module, one with a arduino pro mini 3.3V/8Mhz ATM328
            they are connected with FTDI to the computer / domotic box
            the speed is set to 115200 baud
            here is the GW sketch
            // Enable serial gateway
            #define MY_GATEWAY_SERIAL
            // Enable inclusion mode
            // Set blinking period
            // Flash leds on rx/tx/err
            void presentation() {
            • frenchoF frencho
              tekkaT
              tekkaT
              tekka
              @frencho Hmm, sketch looks fine - what surprises me are the two GW init messages:
              You should try with a different FTDI adapter or power your GW with a good power supply.
              • tekkaT tekka
                frenchoF
                frenchoF
                frencho
                @tekka thanks again. Which two init message are unusual ?
                I just tried an other FDTI adapter nothing changed.
                The gateway is power via the FDTI/USB !! this thing is driving me crazy !
                I'll try also tonight to power GW with 2 AA bat, and read Serial only with the FDTI
                I think I'm going to buy a moteino, I hope it will solve my problems.
                • frenchoF frencho
                  tekkaT
                  tekkaT
                  tekka
                  @frencho
                  These two, of particular interest is the second init message...
                  ...as it appears right after
                  What Arduino IDE version and AVR board def version are you using?
                  • tekkaT tekka
                    @frencho
                    frenchoF
                    frenchoF
                    frencho
                    @tekka arduino 1.6.11 and AVRISP mkII
                    It looks like the Tx serial from PC to GW is not working ! when I send a command, I see the Tx from FDTI blinking, ...
                    I posted other msg on the forum previously, beacause I can't get ride of the fail debug below
                    I'll try today to program the gateway from my Mac
                    • frenchoF frencho
                      tekkaT
                      tekkaT
                      tekka
                      @frencho regarding the NACK: this has been addressed here: https://github.com/mysensors/MySensors/pull/630
                      • tekkaT tekka
                        frenchoF
                        frenchoF
                        frencho
                        @tekka I recompiled everything with the latest Dev Branch, the init problem of the GW is solved.
                        On GW Side :
                        06/11/2016 14:56:51	INFO	Connected to COM10
                        06/11/2016 14:56:52	RX	0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
                        06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:INIT
                        06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:INIT:TSP OK
                        06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:INIT:GW MODE
                        06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:READY
                        06/11/2016 14:56:52	RX	0;255;3;0;14;Gateway startup complete.
                        06/11/2016 14:56:52	DEBUG	Update child id=255, type=ARDUINO_RELAY
                        06/11/2016 14:56:52	RX	0;255;0;0;18;2.0.1-beta
                        06/11/2016 14:56:52	RX	0;255;3;0;9;MCO:REG:NOT NEEDED
                        06/11/2016 14:56:53	RX	0;255;3;0;9;MCO:BGN:STP
                        06/11/2016 14:56:53	RX	0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                        06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:READ,65-65-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:BC
                        06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=65
                        06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:PNG:SEND,TO=0
                        06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:CKU:OK
                        06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:GWL OK
                        06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                        06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                        06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:PINGED,ID=65,HP=1
                        06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                        06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=0,t=18,pt=0,l=10,sg=0:2.0.1-beta
                        06/11/2016 14:57:27	NODE	New node discovered, node id=65
                        06/11/2016 14:57:27	CHILD	New child discovered, node id=65, child id=internal
                        06/11/2016 14:57:27	DEBUG	Update child id=255, type=ARDUINO_RELAY
                        06/11/2016 14:57:27	RX	65;255;0;0;18;2.0.1-beta
                        06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                        06/11/2016 14:57:27	TX	65;255;3;0;6;M
                        06/11/2016 14:57:27	RX	65;255;3;0;6;0
                        06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                        06/11/2016 14:57:29	RX	65;255;3;0;11;Relay
                        06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                        06/11/2016 14:57:29	RX	65;255;3;0;12;1.0
                        06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                        06/11/2016 14:57:29	CHILD	New child discovered, node id=65, child id=1
                        06/11/2016 14:57:29	DEBUG	Update child id=1, type=LIGHT
                        06/11/2016 14:57:29	RX	65;1;0;0;3;
                        06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=2,c=0,t=3,pt=0,l=0,sg=0:
                        06/11/2016 14:57:29	CHILD	New child discovered, node id=65, child id=2
                        06/11/2016 14:57:29	DEBUG	Update child id=2, type=LIGHT
                        06/11/2016 14:57:29	RX	65;2;0;0;3;
                        06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
                        06/11/2016 14:57:30	CHILD	New child discovered, node id=65, child id=3
                        06/11/2016 14:57:30	DEBUG	Update child id=3, type=LIGHT
                        06/11/2016 14:57:30	RX	65;3;0;0;3;
                        06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=4,c=0,t=3,pt=0,l=0,sg=0:
                        06/11/2016 14:57:30	CHILD	New child discovered, node id=65, child id=4
                        06/11/2016 14:57:30	DEBUG	Update child id=4, type=LIGHT
                        06/11/2016 14:57:30	RX	65;4;0;0;3;
                        06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                        06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                        06/11/2016 14:59:38	TX	65;1;1;0;2;
                        06/11/2016 14:59:43	TX	65;1;1;0;2;1
                        06/11/2016 14:59:48	TX	65;1;1;1;2;1
                        on node side :
                        4 MCO:BGN:BFR
                        6 TSM:INIT
                        8 TSM:INIT:TSP OK
                        10 TSF:SID:OK,ID=65
                        12 TSM:FPAR
                        493 TSF:MSG:READ,0-0-65,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        497 TSF:MSG:FPAR OK,ID=0,D=1
                        2152 TSM:FPAR:OK
                        2152 TSM:ID
                        2154 TSM:ID:OK
                        2156 TSM:UPL
                        2191 TSM:UPL:OK
                        2193 TSM:READY
                        2326 TSF:MSG:READ,0-0-65,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        2385 TSF:MSG:SEND,65-65-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
                        2402 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        4419 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
                        4433 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                        4450 TSF:MSG:SEND,65-65-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                        4464 TSF:MSG:SEND,65-65-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                        4481 TSF:MSG:SEND,65-65-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                        4495 TSF:MSG:SEND,65-65-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                        4501 MCO:REG:REQ
                        4511 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                        4569 TSF:MSG:READ,0-0-65,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        4575 MCO:PIM:NODE REG=1
                        4579 MCO:BGN:STP
                        4581 MCO:BGN:INIT OK,ID=65,PAR=0,DIS=1,REG=1
                        The other problem is still here, nothing happen when I try to change state of relay.
                        I tryed to send the the only Tx message sent during communication between GW and Node
                        and nothing
                        I also noticed every now and then that the Node is forwarding some broadcast message from GW :
                        477822 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                        477831 TSF:MSG:BC
                        478488 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                        478496 TSF:MSG:FWD BC MSG
                        478629 TSF:MSG:SEND,0-65-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                        It's got to be a problem bewteen PC/Rasp and GW ... maybe my FDTI ... but I have 2 different !
                        • frenchoF frencho
                          On GW Side :
                          on node side :
                          4 MCO:BGN:BFR
                          6 TSM:INIT
                          8 TSM:INIT:TSP OK
                          10 TSF:SID:OK,ID=65
                          12 TSM:FPAR
                          2152 TSM:FPAR:OK
                          2152 TSM:ID
                          2154 TSM:ID:OK
                          2156 TSM:UPL
                          2191 TSM:UPL:OK
                          2193 TSM:READY
                          4501 MCO:REG:REQ
                          4579 MCO:BGN:STP
                          and nothing
                          477831 TSF:MSG:BC
                          frenchoF
                          frenchoF
                          frencho
                          @tekka I have tried the FDTI with a dummy sketch. I confirm that the RX/TX is working as I change the value of a variable via serial port.
                          Multiple speed have been tested, from 9600 to 115200.
                          Looking at the failure tree, I see no other branch to cut down !
                          Serial com is working
                          the GW and node seems fine (regarding log)
                          So why the GW doesn't react when it gets serial messages ?
                          • frenchoF frencho
                            tekkaT
                            tekkaT
                            tekka
                            @frencho Hmm, something seems to disturb the serial traffic. What happens if you use the Arduino serial monitor (change line ending to NR & CR) and enter:
                            65;0;3;0;13;0
                            (this is a reboot command)
                            Also, what version of MYSController are you on?
                            frenchoF 2 Replies Last reply
                            • tekkaT tekka
                              65;0;3;0;13;0
                              frenchoF
                              frenchoF
                              frencho
                              @tekka tried what you asked, and some more stuff, still nothing happening
                              the reboot command send doesn't do anything, the MYSController version is 0.1.2.282
                              • tekkaT tekka
                                65;0;3;0;13;0
                                frenchoF
                                frenchoF
                                frencho
                                @tekka could it come from something i setup wrong in the Myconfig.h ?
                                • frenchoF frencho
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @frencho Depends, what did you change in MyConfig.h? Also, try using the latest version of MYSController (1.0.0beta, >=3314)
                                  • tekkaT tekka
                                    F
                                    F
                                    frenchclem
                                    @tekka unbelievable !!! I tried with NRF24 and arduino nano, it's working like a charm !!!
                                    If I use the same sketch, on a pro mini using one of my ftdi as serial interface the Tx don't go threw anymore !!!
                                    Ftdi use a 1047 chip
                                    Arduino nano use a CH340 for which I had to install a Chinese driver for it !?!? !!!!
