  3. DHT22 on Arduino Pro Mini 8Mhz 3.3V - Failed
23 Posts 4 Posters 10.6k Views 3 Watching
  • Puneit ThukralP
    Puneit ThukralP
    Puneit Thukral
    Hello
    I have been struggling with this since few days now. I wired up a DHT22 with an arduino Pro mini 3.3V 8 MHz and the DHT22 does not work for me. I connected the same DHT22 to arduino Uno and it works on the same sketch.
    I am using the Mysensors DHT Library and skecth . I Googled and Googled for a solution and one exists but it is not something I am able to do on my own. I am not a programmer.
    The problem is because I am using a 8MHz arduino and the DHT library (https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/DHT) seemigly is not working for me. How do I fix this?
    Error is
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
    !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=fail:2.0.0
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=fail:0
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=3,st=fail:TemperatureAndHumidity
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=4,st=fail:1.1
    !TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=5,st=fail:
    TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=6,st=ok:
    Request registration...
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=fail:2
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=ok:2
    TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=1, parent=0, distance=1, registration=1
    Failed reading temperature from DHT!
    Failed reading humidity from DHT
    and the sketch is
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    //#define MY_RS485
    #include <DHT.h>
    #define DHT_DATA_PIN 4
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      metric = getConfig().isMetric;
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    The DHT libray that does not work is0_1479028841721_arduino-DHT-master (works for me but not with mysensors).zip
    • scalzS
      scalzS
      wrote on last edited by scalz
      Hi.
      Looks like you have a communication problem between your nodes. Not really dht related. Logs show that it is searching for a parent, and no ack. Which explains why the raw examples is working ;)
      Can be a power issue.
      How is your node wired ?
      Puneit ThukralP 1 Reply Last reply
      • scalzS scalz
        Hi.
        Puneit ThukralP
        Puneit ThukralP
        Puneit Thukral
        @scalz That's because I had my gateway turned off while I was troubleshooting. If you scroll down the log, the gateway goes back online and the DHT error pops up. Sorry for the confusion
        • Puneit ThukralP Puneit Thukral
          @Puneit-Thukral there are lots of st=fail just before the dht errors, so it is most likely a power issue.
            Puneit ThukralP
            Puneit ThukralP
            Puneit Thukral
            @mfalkvidd What should I do ? Will adding a transistor help?
              @Puneit-Thukral if you are not following the recommendation to use a capacitor then yes, following the recommendation will probably help.
                Puneit ThukralP
                Puneit ThukralP
                Puneit Thukral
                @mfalkvidd the 4.7uF capacitor is connected between ground and VCC on the radio.
                  @Puneit-Thukral ok, great.
                  https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help has a flowchart on troubleshooting power and range issues.
                  How is the pro mini powered? Battery? If so, what type of battery? Any regulator? Same questions for the radio and the dht.
                    Puneit ThukralP
                    Puneit ThukralP
                    Puneit Thukral
                    @mfalkvidd pro mini is powered through a 3.3 V power supply. There is no voltage leak ground terminals on the power supply. It measures 0 volt. Let me try everything again and I will post the results. I must also share that I used another DHT library and DHT22 test sketch on the same setup, and I was able to read data on serial interface.
                    I am not ruling out what you said about power issues, but just wanted to put this on the table.
                    I will continue to debug. Its frustrating at times, but good fun. !
                      @Puneit-Thukral the library has worked for may users, so I find it unlikely to be the culprit even though it could be the case. The larger difference is that you are not using the radio when trying the other library, right? Radio consumes power.
                      • Puneit ThukralP
                        Puneit ThukralP
                        Puneit Thukral
                        I changed the powersupply and tried again. Also, I checked for any loose connections.
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:CHKID:OK (ID=1)
                        TSM:UPL
                        TSP:CHKUPL:OK
                        TSM:UPL:OK
                        TSM:READY
                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                        !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                        !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=fail:TemperatureAndHumidity
                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=ok:1.1
                        TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                        !TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=fail:
                        Node registration=1
                        I am still stuck. Should I try another arduino and radio and sensor?
                        • Puneit ThukralP
                          Puneit ThukralP
                          Puneit Thukral
                          I tried again with a new arduino pro mini - no luck. Then I replicated the node on an Arduino Uno and same result "Failed to read". There must be something I must be doing wrong which I can't see.
                            Strange.
                            I just looked through the sketch and it looks fine to me.
                            The st=fail during presentation is worrisome.
                            What is the distance between the node and the gateway? Does moving the sensor further away (>2m) or closer help?
                            If you can, trying another radio and sensor might be the easiest way to pinpoint the problem.
                              Strange.
                              Puneit ThukralP
                              Puneit ThukralP
                              Puneit Thukral
                              @mfalkvidd Thanks for vetting the sketch.
                              For troubleshooting I brought the gateway and the node to the close to me (read centimeters between them).
                              Also, on the node on which I first discovered the error, serial print occurs at baud 230400 and on other nodes (arduinos running same sketch ) serial print occurs at baud 115200. I understand that the serial debug print should occur at 115200. Is it unexpected or odd that one arduino prints at 230400 while others are printing at 115200?
                              I will moving the nodes closer and away and report.
                              I bought 10 pro minis all 3.3v. So, for now, I think I should start something very simple. How about door close sensors? They should be pretty simple, right? If even these don't work, then either the hardware is bad or I am. Anyway, thanks a lot for your time. This is a great forum and resource and I hope I am able to foray into this amazing world of IoT.
                                @Puneit-Thukral if the baud rate is wrong, the Arduino runs at a different speed than was is selected in the Arduino IDE. Maybe you got a 5V 16Mhz instead of 3.3V 8Mhz? That could explain why the node doesn't get enough power.
                                  Puneit ThukralP
                                  Puneit ThukralP
                                  Puneit Thukral
                                  @mfalkvidd And the way to test that would be to input 9 v at RAW and measure the VCC, right? While I added 3.3 v to my ebay cart, the boards have 8Mhz 16 Mhz 3.3V 5V printed on them. This is what you get in India over ebay and Amazon. I trust that the seller picked and packed them correctly. I will (tomorrow) test the VCC after inputting 9 V at RAW and see if that changes anything.
                                    @Puneit-Thukral good plan. That's probably the easiest way to test. It might also be possible to read the text on the regulator, but reading the small text is usually pretty hard.
                                      Puneit ThukralP
                                      Puneit ThukralP
                                      Puneit Thukral
                                      @mfalkvidd
                                      The diagnosis solved the issue. The Arduino pro mini 3.3V 8 MHz sold to me was actually a 5v 16 MHz. No more Failed reading temperature from DHT!. However, there are still a few st:fail during initialisation but later goes away.
                                      Should I work towards eliminating these or would it be fine. The Openhab2 still is not reading from this node and shows NaN (even though the sensor is online).
                                      Thanks for your continued help.
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=1)
                                      TSM:UPL
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=fail:0
                                      !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=2,st=fail:TemperatureAndHumidity
                                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=ok:1.1
                                      TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                      Node registration=1
                                      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:24.6
                                      T: 24.60
                                      TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:41.9
                                      H: 41.90
                                      TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:42.0
                                      H: 42.00
                                        @mfalkvidd
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=1)
                                        TSM:UPL
                                        TSP:CHKUPL:OK
                                        TSM:UPL:OK
                                        TSM:READY
                                        Node registration=1
                                        T: 24.60
                                        H: 41.90
                                        H: 42.00
                                        @Puneit-Thukral Great work!
                                        The failed presentation could be preventing OpenHab2 from displaying the node correctly.
                                        Have you switched to a "real" 3.3V pro mini now or are you using the 5V? If 5V, do you use a regulator to 3.3V for the nrf?
                                          Puneit ThukralP
                                          Puneit ThukralP
                                          Puneit Thukral
                                          @mfalkvidd Yes, I connected the 3.3v regulator to VCC of the radio. I will continue to debug tonight. Maybe now something is amiss at the gateway side. The gateway radio is connected via dupont cables on the Uno and I am not very happy with dupont. I should solder the radio to Uno.
