  3. ESp arduino + domoticz + read light switch status (on / off)
7 Posts 2 Posters 4.9k Views 2 Watching
  • marcin.kasinskiM
    marcin.kasinskiM
    marcin.kasinski
    HI,
    I use esp with relay to switch light.
    I integrated my arduino code with domoticz.
    Everything works great.
    I have only one problem.
    After esp restart I want to read actual (just before restart ) status of my light device (was it on or off)
    To save epprom I don't want to save device status on esp side.
    I know that I can read this status by sending http request : /json.htm?type=devices&rid=3 and parse response.
    My question is :
    Is there other simple way to read this status ?
    blaceyB 1 Reply Last reply
    • marcin.kasinskiM marcin.kasinski
      HI,
      My question is :
      blaceyB
      blaceyB
      blacey
      @marcin.kasinski All you need to do is ask the gateway for the light status in your setup() method. The gateway will respond to request() by sending a V_STATUS message for your light to your ESP node.
      NOTE: Currently there is a bug in the MYS 2.0 release that invokes the sketch setup() before presentation() and you can't send messages to the gateway until presentation() completes. You will need to upgrade to the development branch (next beta) in order for this to work (i.e. ensure that setup() is call after presentation().
        //Synchronize relay state with gateway - this will result in receive() being called.
        request( CHILD_ID, V_STATUS );
      • marcin.kasinskiM
        marcin.kasinskiM
        marcin.kasinski
        wrote on last edited by marcin.kasinski
        Hi.
        Thank you for your reply.
        I placed
        request(3, V_STATUS);
        in setup () and loop()
        This code does nothing.
        No log messages in domoticz.
        No debug messages on esp side.
        Another thing:
        After ESP restarts it isn't visible in domoticz automically.
        To connect it I have to log domoticz console and :
        Setup - >Hardware -> Click my device
        Then just click update
        Just after that I can see on esp side:
        0;255;3;0;9;Client 0 connected
        0;255;3;0;9;Client 0: 0;0;3;0;2;
        Another way is to wait 30 second for domoticz reconnect.
        I said that becouse I see that when esp invokes setup() function device is nor connected to device.
        Generally speaking I can not see any messages after request(3, V_STATUS);
        No receive() execution.
        Didn't I miss something ?
          Hi.
          I placed
          Another thing:
          blaceyB
          blaceyB
          blacey
          @marcin.kasinski said:
          I placed
          Did you upgrade to the development version of MySensors?
          Also, please post your entire sketch...
          Another thing:
          We will have to figure this problem out first. Maybe the sketch will include a hint.
          marcin.kasinskiM 1 Reply Last reply
          • blaceyB blacey
            I placed
            Another thing:
            marcin.kasinskiM
            marcin.kasinskiM
            marcin.kasinski
            wrote on last edited by blacey
            @blacey
            Hi Thank you for hour help.
            I do really need to solve it.
            I prepared sample as simple as possible:
            on ESP:
            0;255;3;0;9;Client 0: 0;0;3;0;18;PING
            On domoticz
            2016-11-23 08:50:12.675 MySensors: Gateway Version: 2.0.1-beta
            After restarting ESP (deploy code again)
            On ESP:
            áNɆŔü0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGE--,VER=2.0.1-beta
            scandone
            f 0, scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 3
            cnt
            connected with MK, channel 11
            dhcp client start...
            .....ip:192.168.1.129,mask:255.255.255.0,gw:192.168.1.1
            .IP: 192.168.1.129
            0;255;3;0;9;MCO:BGN:STP
            Setup request sent [0]
            0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
            pm open,type:2 0
            On domoticz :
            no new messages
            Then silent
            Then After Setup - >Hardware -> Click my device - > Click update
            ON esp:
            0;255;3;0;9;Client 0: 0;0;3;0;2;Get Version
            On domoticz:
            2016-11-23 08:55:47.768 MySensors: TCP/IP Worker stopped...
            2016-11-23 08:55:48.782 MySensors: trying to connect to: 192.168.1.129:5003
            2016-11-23 08:55:49.783 MySensors: connected to: 192.168.1.129:5003
            2016-11-23 08:55:49.784 MySensors: Gateway Ready...
            2016-11-23 08:55:49.788 MySensors: Node: 0, Sketch Name: Relay
            2016-11-23 08:55:49.790 MySensors: Node: 0, Sketch Version: 1.0
            2016-11-23 08:55:50.793 MySensors: Gateway Version: 2.0.1-beta
            2016-11-23 08:55:50.794 MySensors: Gateway Version: 2.0.1-beta
            My sketch:
            #define MY_BAUD_RATE 115200
            //#define MY_RADIO_NRF24
            #define MY_GATEWAY_ESP8266
            #define MY_ESP8266_SSID "xxx"
            #define MY_ESP8266_PASSWORD "xxx"
            // Enable UDP communication
            //#define MY_USE_UDP
            #define MY_ESP8266_HOSTNAME "sensor-gateway"
            #define MY_PORT 5003
            // Enable inclusion mode
            // #define MY_INCLUSION_BUTTON_FEATURE
            // Set blinking period
            // #define MY_DEFAULT_LED_BLINK_PERIOD 300
            // Flash leds on rx/tx/err
            // Led pins used if blinking feature is enabled above
            #if defined(MY_USE_UDP)
              #include <WiFiUdp.h>
            #include <ESP8266WiFi.h>
            bool ret=request(1, V_STATUS);
            Serial.printf("Setup request sent [%d]\n",ret);
            void presentation() {
                present(1, S_BINARY);
            int cmd = mGetCommand(message);
                   Serial.printf("RECEIVE sensor [%d] type [%d] command [%d]\n",message.type, cmd);
            Edited to use code blocks for readability.
              @blacey
              on ESP:
              On domoticz
              On ESP:
              scandone
              f 0, scandone
              state: 0 -> 2 (b0)
              state: 2 -> 3 (0)
              state: 3 -> 5 (10)
              add 0
              aid 3
              cnt
              .IP: 192.168.1.129
              pm open,type:2 0
              On domoticz :
              no new messages
              Then silent
              ON esp:
              On domoticz:
              My sketch:
              blaceyB
              blaceyB
              blacey
              @marcin.kasinski Hmmm, now I'm confused. Are you using ESP for your Gateway or Node or both? Do I understand correctly that you have not attached either an NRF24 or RFM69 radio to your node (all #defines for radio are commented out)? The MySensors gateway and nodes only communicate with each over NRF24 or RFM69 radios (i.e. not WiFi).
              • blaceyB blacey
                marcin.kasinskiM
                marcin.kasinskiM
                marcin.kasinski
                @blacey
                You are right.
                I don't use eighter NRF24 or RFM69.
                I have domoticz server and esp with relay connected only.
                All I want to do is switch on or off my relay connected to esp pin from domoticz.
                It works for me.
                I can see that domoticz sends comands to my ESP.
                I can see that receive function on esp side is executed every time I click on domoticz side.
                My only problem is "esp restart issue".
                I would like to ask domoticz for actual status (is it on or off) in esp setup() function to set my relay connected to esp module.
                Now you know my requirements.
                1. If you think my code works but I do it in not a proper way please correct me.
                2. If you know how to ask domoticz for device actual status please help me.
