  3. [SOLVED] Using interupt - partial
3 Posts 2 Posters 1.3k Views 2 Watching
  • A
    A
    afick
    wrote on last edited by afick
    UPDATE: now i realized that when node will go sleep i will lose ability to on/off realy - is there any solution for that ?
    I have problem with my code.
    I build sensor from:
    • Arduino nano v3 (clone)
    • DHT11
    • Relay
    • Window/door switch
    I put all 3 examples into 1 piece ,create some function.
    What i want to get is -
    -send msg when debounce status will change (open/close door)- this is workin fine
    -remote on/off relay - this is workin fine
    • get temp and hum - this is working finr
    • sleep for 10000ms but wake when debounce status will change - THIS IS NOT WORKING.
      My sensor is working all the time and sending msg all time instead go to sleep ...
    Can anyone look at this code and say what is wrong ?
     * Version 1.0 - Henrik Ekblad
    #define MY_REPEATER_FEATURE
    //dht
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 39
    #define CHILD_ID_TEMP 40
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    //kontakt
    #include <Bounce2.h>
    #define CHILD_ID 33
    #define BUTTON_PIN 2  // Arduino Digital I/O pin for button/reed switch
    #define INTERRUPT BUTTON_PIN-2
    unsigned long SLEEP_TIME = 120000;
    Bounce debouncer = Bounce();
    int oldValue=-1;
    //relay
    #define RELAY_1  6  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before() {
        pinMode(pin, OUTPUT);
    //kontaktron
    // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      //dht
    void loop ()
    check_debounce();
    check_temp();
    sleep(BUTTON_PIN-2, CHANGE, SLEEP_TIME);
    void check_debounce()
      //kontaktron
    debouncer.update();
      // Get the update value
      int value = debouncer.read();
    Serial.println(value);
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
      sendSketchInfo("Kurczakowo", "0.1");
        present(sensor, S_LIGHT);
    present(CHILD_ID_HUM, S_HUM);
      metric = getConfig().isMetric;
    //kontaktron
    present(CHILD_ID, S_DOOR);
    void check_temp()
      //dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
      You cannot sleep a node where you expect incoming commands.
      • A
        A
        afick
        hmmm ok thanks. CASE CLOSED :>
