  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.1k Views 25 Watching
  • alexsh1A alexsh1
    @Koresh I got one of boards and would like to add Si1132-A10-GMR. What else I need to add? C8?
    Why are you not using this sensor on your board?
    KoreshK
    KoreshK
    Koresh
    @alexsh1 yes, you should solder the sensor and the bypass capacitor. I have a lot of si1132 sensors, but I can't find the correct library. Almost promo videos of commertial sensors based on the si1132 shows incorrect data ))) It shows correct UV and IR level, but incorrect visible light value. So I decided to not solder this sensor yet.
    alexsh1A 1 Reply Last reply
    • alexsh1A
      alexsh1A
      alexsh1
      #42
      @Koresh I would only use it for UV so this is good for me.
      No need to use a lib:
      // Distributed with a free-will license.
      // Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
      // SI1132
      // This code is designed to work with the SI1132_I2CS I2C Mini Module available from ControlEverything.com.
      // https://www.controleverything.com/content/Light?sku=SI1132_I2CS#tabs-0-product_tabset-2
      #include<Wire.h>
      // SI1132 I2C address is 0x60(96)
      #define Addr 0x60
      int response = 0;
        // Initialise I2C communication as MASTER
        Wire.begin();
        // Initialise Serial Communication, Baud rate = 9600
        Serial.begin(9600);
        // Enable UVindex measurement coefficients
        // Start I2C Transmission
        Wire.beginTransmission(Addr);
        // Select COFF-1 register
        Wire.write(0x13);
        // Default value
        Wire.write(0x29);
        // Stop I2C Transmission
        Wire.endTransmission();
        // Select COFF-2 register
        Wire.write(0x14);
        // Default value
        Wire.write(0x89);
        // Select COFF-3 register
        Wire.write(0x15);
        // Default value
        Wire.write(0x02);
        // Select COFF-4 register
        Wire.write(0x16);
        // Default value
        Wire.write(0x00);
        // Select PARAM_WR register
        Wire.write(0x17);
        // Enable uv, Visible, IR
        Wire.write(0xF0);
        // Select command register
        Wire.write(0x18);
        // Select CHLIST register in RAM
        Wire.write(0x01 | 0xA0);
        delay(10);
        // Select PARAM_RD register
        Wire.write(0x2E);
        // Request 1 byte of data
        Wire.requestFrom(Addr, 1);
        // Read 1 byte of data
        response = Wire.read();
        // Select HW_KEY register
        Wire.write(0x07);
        // Default value
        Wire.write(0x17);
        Wire.write(0x17);
        // Small IR photodiode
        Wire.write(0x00);
        // Select COMMAND register
        Wire.write(0x18);
        // Select ALS_IR_ADCMUX register in RAM
        Wire.write(0x0E | 0xA0);
        delay(10);
        Wire.write(0x2E);
        Wire.write(0x17);
        // Set ADC Clock divided / 1
        Wire.write(0x00);
        Wire.write(0x18);
        // Select ALS_IR_ADC_GAIN register in RAM
        Wire.write(0x1E | 0xA0);
        delay(10);
        Wire.write(0x2E);
        Wire.write(0x17);
        // Set 511 ADC Clock
        Wire.write(0x70);
        Wire.write(0x18);
        // Select ALS_IR_ADC_COUNTER register in RAM
        Wire.write(0x1D | 0xA0);
        delay(10);
        Wire.write(0x2E);
        Wire.write(0x17);
        Wire.write(0x00);
        Wire.write(0x18);
       // Select ALS_VIS_ADC_GAIN register in RAM
        Wire.write(0x11 | 0xA0);
        delay(10);
        Wire.write(0x2E);
        Wire.write(0x17);
        // High Signal Range
        Wire.write(0x20);
        Wire.write(0x18);
        // Select ALS_IR_ADC_MISC register in RAM
        Wire.write(0x1F | 0xA0);
        delay(10);
        Wire.write(0x2E);
        Wire.write(0x17);
        Wire.write(0x70);
        Wire.write(0x18);
        // Select ALS_VIS_ADC_COUNTER register in RAM
        Wire.write(0x10 | 0xA0);
        delay(10);
        Wire.write(0x2E);
        Wire.write(0x17);
        Wire.write(0x20);
        Wire.write(0x18);
        // Select ALS_VIS_ADC_MISC register in RAM
        Wire.write(0x12 | 0xA0);
        delay(10);
        Wire.write(0x2E);
        delay(300);
        unsigned int data[4];
        Wire.write(0x18);
        // Start ALS conversion
        Wire.write(0x0E);
        delay(500);
        // Select data register
        Wire.write(0x22);
        // Request 4 byte of data
        Wire.requestFrom(Addr, 4);
        // Read 4 bytes of data
        // visible lsb, visible msb, ir lsb, ir msb
        if (Wire.available() == 4)
          data[0] = Wire.read();
          data[1] = Wire.read();
          data[2] = Wire.read();
          data[3] = Wire.read();
        float visible = (data[1] * 256.0 + data[0]);
        float ir = (data[3] * 256 + data[2]);
        Wire.write(0x2C);
        // Request 2 bytes of data
        Wire.requestFrom(Addr, 2);
        // Read 2 bytes of data
        // uv lsb, uv msb
        if (Wire.available() == 2)
        // Convert the data
        float uv = (data[1] * 256 + data[0]);
        // Output data to screen
        Serial.print("Visible Light of Source : ");
        Serial.print(visible);
        Serial.println(" lux");
        Serial.print("IR Of Source : ");
        Serial.print(ir);
        Serial.print("UV Of the Source : ");
        Serial.print(uv);
        delay(500);
      • alexsh1A alexsh1
        // SI1132
        #include<Wire.h>
        #define Addr 0x60
        int response = 0;
          Wire.begin();
          Serial.begin(9600);
          Wire.write(0x13);
          // Default value
          Wire.write(0x29);
          Wire.write(0x14);
          // Default value
          Wire.write(0x89);
          Wire.write(0x15);
          // Default value
          Wire.write(0x02);
          Wire.write(0x16);
          // Default value
          Wire.write(0x00);
          Wire.write(0x17);
          Wire.write(0xF0);
          Wire.write(0x18);
          delay(10);
          Wire.write(0x2E);
          Wire.write(0x07);
          // Default value
          Wire.write(0x17);
          Wire.write(0x17);
          Wire.write(0x00);
          Wire.write(0x18);
          delay(10);
          Wire.write(0x2E);
          Wire.write(0x17);
          Wire.write(0x00);
          Wire.write(0x18);
          delay(10);
          Wire.write(0x2E);
          Wire.write(0x17);
          Wire.write(0x70);
          Wire.write(0x18);
          delay(10);
          Wire.write(0x2E);
          Wire.write(0x17);
          Wire.write(0x00);
          Wire.write(0x18);
          delay(10);
          Wire.write(0x2E);
          Wire.write(0x17);
          Wire.write(0x20);
          Wire.write(0x18);
          delay(10);
          Wire.write(0x2E);
          Wire.write(0x17);
          Wire.write(0x70);
          Wire.write(0x18);
          delay(10);
          Wire.write(0x2E);
          Wire.write(0x17);
          Wire.write(0x20);
          Wire.write(0x18);
          delay(10);
          Wire.write(0x2E);
          delay(300);
          Wire.write(0x18);
          Wire.write(0x0E);
          delay(500);
          Wire.write(0x22);
          Wire.write(0x2C);
          // uv lsb, uv msb
          // Convert the data
          Serial.print(ir);
          Serial.print(uv);
          delay(500);
        alexsh1A
        alexsh1A
        alexsh1
        @Koresh BTW, Found this library - working fine for my needs
        https://github.com/hardkernel/WEATHER-BOARD/tree/master/libraries/ODROID_Si1132
        I am using this sensor purely for UV Index.
        PS Got your sensor. Soldered it to the mote. Works just fine
        • KoreshK Koresh
          alexsh1A
          alexsh1A
          alexsh1
          @Koresh I can see Si1132 visible light is twice more than BH1750.
          Not sure what's wrong, but as you said it reports incorrect value.
          UV Index is in line with VEML6070
          • alexsh1A alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            The sensor looks more complicated that I thought:
            2.2. Ambient Light
            The Si1132 has photodiodes capable of measuring both vi
            sible and infrared light. Howe
            ver, the visible photodiode
            is also influenced by infrared light. The measurement of illuminance require
            s the same spectral response as the
            human eye. If an accurate lux measurement is desired, the
            extra IR response of the vi
            sible-light photodiode must
            be compensated. Therefore, to allow the host to make corrections to the infrared light’s influence, the Si1132
            reports the infrared light measurement on a separate channel. The separate visible and IR photodiodes lend
            themselves to a variety of algorithmic solutions. The
            host can then take these two measurements and run an
            algorithm to derive an equivalent lux level as perceive
            d by a human eye. Having
            the IR correction algorithm
            running in the host a
            llows for the most flexibility in adjusting for system-dependent
            variables. For example, if the
            glass used in the system blocks visibl
            e light more than infrared light, the
            IR correction needs to be adjusted.
            I will have to spend more time to understand how to extract the correct ambient light
            • Y
              Y
              yury
              This post is deleted!
              • alexsh1A alexsh1
                2.2. Ambient Light
                alexsh1A
                alexsh1A
                alexsh1
                The sketch I posted above contains some errors
                (it sets COFFs 0x29, 0x89, 0x02 and 0x00 to the 0x13, 0x14, 0x15 and 0x16 registers).
                The correct UCOEF values are 0x7B, 0x6B, 0x01, and 0x00
                The sensor is quite complex.
                • alexsh1A alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  I got the following values from the sensor:
                  1. V_VOLTAGE (3.21)
                  2. V_HUM (51
                  3. V_TEMP (30)
                  4. V_LIGHT_LEVEL (4466)
                  5. V_UV (1.74)
                  6. V_LIGHT_LEVEL (3367)
                  7. V_LIGHT_LEVEL (3367)
                  Clearly, Si1132 is not in line with BH1750. VEML6075 is giving me UV Index 1.65, which is close to the Si1132.
                  Moreover, depending where it is used, the coeff in formula has to change (I am using 0.282 for the direct sunlight) :
                  Visible Photodiode
                  Response
                  Sunlight
                  ALS_VIS_ADC_GAIN=0
                  VIS_RANGE=0
                  0.282
                  2500K incandescent bulb
                  ALS_VIS_ADC_GAIN=0
                  VIS_RANGE=0
                  0.319
                  “Cool white” fluorescent
                  ALS_VIS_ADC_GAIN=0
                  VIS_RANGE=0
                  0.146
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    #49
                    @Koresh My 2032 died in 2 days and I noticed that power consumption is 3.5mA. OK, maybe bad soldering - I desoldered Si1132, but the consumption is still 0.14mA while sleeping. For 2032 this is a huge consumption. Did you measure consumption at all? I am using CW radio
                    Si1132 must be consuming around < 500 nA standby current according to the datasheet. Not sure why consumption was increased with Si1132.
                    KoreshK 1 Reply Last reply
                    • alexsh1A alexsh1
                      KoreshK
                      KoreshK
                      Koresh
                      wrote on last edited by Koresh
                      #50
                      @alexsh1 Do not forget put BH1750 into sleep mode. Unfortunatelly standart library do not put the sensor into this mode. I described it on the github page.
                        /*  Please comment out private declaration in BH1750.h
                         *   Otherwise you can't call lightMeter.write8(BH1750_POWER_DOWN); and BH1750 will not sleep!
                         *  //private:
                         *   void write8(uint8_t data);
                      • KoreshK Koresh
                           *  //private:
                        alexsh1A
                        alexsh1A
                        alexsh1
                        #51
                        @Koresh I did it on the first day I got the sensor. The consumption above is with BH1750 in the sleeping mode as per your github
                        Y 1 Reply Last reply
                        • alexsh1A alexsh1
                          Y
                          Y
                          yury
                          @alexsh1 said in 💬 Button size radionode with sensors swarm extension:
                          Could you post the code you use? and links for the libs. we will check tomorrow consumption with your code . mysensors 2.0 or 2.2?
                          • Y yury
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @yury It is the latest bh1750 lib -> https://github.com/claws/BH1750
                            I am using MySensors 2.2.0b
                            I am using a default code :
                            https://github.com/EasySensors/ButtonSizeNode/blob/master/ButtonSizeNode.ino
                            alexsh1A KoreshK 2 Replies Last reply
                            • alexsh1A alexsh1
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #54
                              @yury One thing I did notice is this. To put BH1750 into a sleep mode (1uA consumption), it has to be called as follows:
                              void setup()  {
                              lightMeter.begin(BH1750_ONE_TIME_HIGH_RES_MODE);
                              After a one time measurement it goes to sleep automatically.
                              Please see -> https://github.com/claws/BH1750/blob/master/examples/BH1750advanced/BH1750advanced.ino
                              I have tried above, but still getting 0.14mA consumption in a sleep mode. Very odd!
                              • alexsh1A alexsh1
                                KoreshK
                                KoreshK
                                Koresh
                                @alexsh1 Very strange. I can't see a method write8 in current lib version (https://github.com/claws/BH1750). So I can't understand how is it possible to compile default code with this string
                                I couldn't put this sensor into power down mode without this.
                                alexsh1A 2 Replies Last reply
                                • alexsh1A alexsh1
                                  void setup()  {
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  #56
                                  I've read the claws library briefly again. I'm a litte doubt that this code:
                                  _delay_ms(10);
                                  is enough to ensure correctly timings and sensors work :)
                                  • KoreshK Koresh
                                    _delay_ms(10);
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @Koresh It does work, I have just test it, but there is a delay, i.e. the sensor is lagging one reading behind.
                                    • KoreshK Koresh
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @Koresh said in 💬 Button size radionode with sensors swarm extension:
                                      I tried it with the original (old) library -> https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/BH1750
                                      I commended out "private" in bh1750.h
                                      Consumption has not changed - 0.14mA
                                      • KoreshK Koresh
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @Koresh One more observation. If I comment out:
                                        //lightMeter.write8(BH1750_POWER_DOWN);
                                        from the original sketch, the consumption goes up to 0.27mA.
                                        So BH1750 is not a problem. Something else is eating up a few milliamps.
                                        • Y
                                          Y
                                          yury
                                          yes seems your board has bad capacitors. After rechecking many boards we found one eating a lot - 0.4 mA. Replacing caps fixed issue.
                                          2_1499267230472_noLDO.jpg 1_1499267230472_LDO.jpg 0_1499267230471_gooodCap.jpg
                                          can you check?
