  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 76.6k Views 25 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    #49
    @Koresh My 2032 died in 2 days and I noticed that power consumption is 3.5mA. OK, maybe bad soldering - I desoldered Si1132, but the consumption is still 0.14mA while sleeping. For 2032 this is a huge consumption. Did you measure consumption at all? I am using CW radio
    Si1132 must be consuming around < 500 nA standby current according to the datasheet. Not sure why consumption was increased with Si1132.
    KoreshK 1 Reply Last reply
    • alexsh1A alexsh1
      KoreshK
      KoreshK
      Koresh
      wrote on last edited by Koresh
      #50
      @alexsh1 Do not forget put BH1750 into sleep mode. Unfortunatelly standart library do not put the sensor into this mode. I described it on the github page.
        /*  Please comment out private declaration in BH1750.h
         *   Otherwise you can't call lightMeter.write8(BH1750_POWER_DOWN); and BH1750 will not sleep!
         *  //private:
         *   void write8(uint8_t data);
      alexsh1A 1 Reply Last reply
      • KoreshK Koresh
           *  //private:
        alexsh1A
        alexsh1A
        alexsh1
        #51
        @Koresh I did it on the first day I got the sensor. The consumption above is with BH1750 in the sleeping mode as per your github
        Y 1 Reply Last reply
        • alexsh1A alexsh1
          Y
          Y
          yury
          @alexsh1 said in 💬 Button size radionode with sensors swarm extension:
          Could you post the code you use? and links for the libs. we will check tomorrow consumption with your code . mysensors 2.0 or 2.2?
          • Y yury
            alexsh1A
            alexsh1A
            alexsh1
            @yury It is the latest bh1750 lib -> https://github.com/claws/BH1750
            I am using MySensors 2.2.0b
            I am using a default code :
            https://github.com/EasySensors/ButtonSizeNode/blob/master/ButtonSizeNode.ino
            alexsh1A KoreshK 2 Replies Last reply
            • alexsh1A alexsh1
              alexsh1A
              alexsh1A
              alexsh1
              #54
              @yury One thing I did notice is this. To put BH1750 into a sleep mode (1uA consumption), it has to be called as follows:
              void setup()  {
              lightMeter.begin(BH1750_ONE_TIME_HIGH_RES_MODE);
              After a one time measurement it goes to sleep automatically.
              Please see -> https://github.com/claws/BH1750/blob/master/examples/BH1750advanced/BH1750advanced.ino
              I have tried above, but still getting 0.14mA consumption in a sleep mode. Very odd!
              • alexsh1A alexsh1
                KoreshK
                KoreshK
                Koresh
                @alexsh1 Very strange. I can't see a method write8 in current lib version (https://github.com/claws/BH1750). So I can't understand how is it possible to compile default code with this string
                I couldn't put this sensor into power down mode without this.
                alexsh1A 2 Replies Last reply
                • alexsh1A alexsh1
                  void setup()  {
                  KoreshK
                  KoreshK
                  Koresh
                  #56
                  I've read the claws library briefly again. I'm a litte doubt that this code:
                  _delay_ms(10);
                  is enough to ensure correctly timings and sensors work :)
                  • KoreshK Koresh
                    _delay_ms(10);
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @Koresh It does work, I have just test it, but there is a delay, i.e. the sensor is lagging one reading behind.
                    • KoreshK Koresh
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @Koresh said in 💬 Button size radionode with sensors swarm extension:
                      I tried it with the original (old) library -> https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/BH1750
                      I commended out "private" in bh1750.h
                      Consumption has not changed - 0.14mA
                      • KoreshK Koresh
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @Koresh One more observation. If I comment out:
                        //lightMeter.write8(BH1750_POWER_DOWN);
                        from the original sketch, the consumption goes up to 0.27mA.
                        So BH1750 is not a problem. Something else is eating up a few milliamps.
                        • Y
                          Y
                          yury
                          yes seems your board has bad capacitors. After rechecking many boards we found one eating a lot - 0.4 mA. Replacing caps fixed issue.
                          2_1499267230472_noLDO.jpg 1_1499267230472_LDO.jpg 0_1499267230471_gooodCap.jpg
                          can you check?
                          • Y yury
                            can you check?
                            alexsh1A
                            alexsh1A
                            alexsh1
                            #61
                            @yury There are two yellow caps in your photo. Do I have to change both of them? What's nominal please?
                            EDIT: both are 107J SMD Tantalum
                            • Y yury
                              can you check?
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @yury I was suspecting EEPROM (CS pin with pull-up resistor?) to be a culprit
                              • Y
                                Y
                                yury
                                combined capacitance of booth should be 100 --200 microfarads . It is input capacitors.
                                please try replacing them
                                re:
                                not pullups...
                                • Y
                                  Y
                                  yury
                                  0.4 ma here with the bad cap
                                  • alexsh1A alexsh1
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    @alexsh1 you can solder one or two capacitors ~50-200uf. But you should remove both because we do not know which of them is bad. Do not forget about polarity ;) Dot-key on the board means positive, so tantalum has positive key, but electrolitic capacitors has negative key.
                                    • KoreshK Koresh
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #66
                                      @Koresh thanks. It does not matter which caps, right?
                                      I have a few 1206 100uF ceramic caps. They are not polarised and may be a good fit size wise
                                      • Y yury
                                        re:
                                        not pullups...
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @yury what's your estimate of battery life based on a new consumption of about 25uA and the default sketch?
                                        • alexsh1A alexsh1
                                          Y
                                          Y
                                          yury
                                          @alexsh1 220 mAh(Duracell) / 0.025 (mA) = 8800 hrs = 366 days.
                                          12.5k
