  3. Monitoring battery charging
3 Posts 3 Posters 1.7k Views 3 Watching
    A Former User
    Hey guys, just starting out here!
    I've set a RPi up with Home Assistant, and have a MightyHat I'm using as a serial gateway plugged in to the RPi. The MightyHat has a back up battery (a UPS if you will) I want to read the battery voltage and report that back as well as if its charging or not!
    For the battery voltage should I use V_VOLTAGE under the Multimeter, or use sendBatteryLevel()? What would be the best way to report if its charging or not?
    mfalkviddM Boots33B 2 Replies Last reply
    • ? A Former User
      @phill21 sendBatteryLevel is meant for reporting the battery level of the node itself (for a battery powered node). Controllers treat this differently from V_VOLTAGE. For example, there is no way to get a graph of the batteryLevel in Domoticz, but V_VOLTAGE will give a graph.
      For charging or not you can use a binary switch/light (on means charging, off not charging) or send the amount of current or power (V_CURRENT or V_WATT)
      • ? A Former User
        Boots33B
        Boots33B
        Boots33
        @phill21 Have a look at this project i did a while back. you may get some inspiration from there :)
