  3. Most reliable light switch
4 Posts 3 Posters 2.2k Views 3 Watching
  • A
    A
    Alexander Ivanov
    I'm moving to Vera+MySensors and will do all light management under MySensors.
    Months before I raised a discussion to allow node to be operated individually, even if it's not connected to MySensor network. Unfortunately, it will not happen - once node is not connected - it will stop working.
    I definitely don't want to put my house in the dark because something went wrong. Does anybody created a reliable switch, based (maybe) on MySensor node + (say) Arduino ? Can anybody share good experience?
    • D
      D
      DavidZH
      I am working on such a node, but am still in the programming and testing stage. I will come back here when I have positive results!
      A 1 Reply Last reply
      • D DavidZH
        A
        A
        Alexander Ivanov
        @DavidZH, sounds promising. Give me something for tests, I will spend next few months on this.
        Boots33B 1 Reply Last reply
        • A Alexander Ivanov
          Boots33B
          Boots33B
          Boots33
          @Alexander-Ivanov
          The information in these posts may be of use.
          mys-library-startup-control-after-onregistration
          my_transport_dont_care_mode
          In mySensors V2.1 the basic sketch for a switch that will work even if the controller/gateway is down would look something like this
          #define MY_TRANSPORT_WAIT_READY_MS 3000     //set how long to wait for transport ready.
          #include <Bounce2.h>
          #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
          #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
          #define RELAY_ON 1
          #define RELAY_OFF 0
          Bounce debouncer = Bounce();
          int oldValue = 0;
          bool state;
          MyMessage msg(CHILD_ID, V_STATUS);
            pinMode(BUTTON_PIN, INPUT);              // Setup the button pin
            digitalWrite(BUTTON_PIN, HIGH);           // Activate internal pull-up
            debouncer.attach(BUTTON_PIN);
            debouncer.interval(5);
            pinMode(RELAY_PIN, OUTPUT);               // set relay pin in output mode
            digitalWrite(RELAY_PIN, RELAY_OFF);      // Make sure relay is off when starting up
          void presentation()  {
            sendSketchInfo("Relay & Button", "1.0");
            present(CHILD_ID, S_BINARY);
            debouncer.update();
            // Get the update value
            int value = debouncer.read();
            if (value != oldValue && value == 0) {                          // check for new button push
              state =  !state;                                               //Toggle the state
              send(msg.set(state), false);                                   // send new state to controller, no ack requested
              digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);         // switch the relay to the new state
            oldValue = value;
              state = message.getBool();                                  // get the current state
              digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to current state
              // Write some debug info
              Serial.print(message.sensor);
