  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
  • alexsh1A alexsh1
    I found this interesting fella
    https://www.tindie.com/products/closedcube/tps63030-high-efficient-buck-boost-up-to-96/
    Anyone tinkered with tps63030?
    NeverDieN
    NeverDieN
    @alexsh1
    Is it any better than:
    https://www.openhardware.io/view/276/33v-Buck-Boost-DC-DC-Converter
    alexsh1A 1 Reply Last reply
    • NeverDieN NeverDie
      @alexsh1
      alexsh1A
      alexsh1A
      alexsh1
      @NeverDie said in How best to find the "best" small solar panel of a particular size?:
      @alexsh1
      Interesting buck-boost converter, but Input voltage is from 1.8v to 5.5v.
      I'm looking at the one with a better range of 0.9-5.5V
      I need to use two 2.7V super caps in series with a maximum efficiency
      NeverDieN 1 Reply Last reply
        It's kind of pricey 😧
        alexsh1A
        alexsh1A
        alexsh1
        @gohan said in How best to find the "best" small solar panel of a particular size?:
        Not cheap, I agree, but ideally I'm looking to use the whole range from 0 to 5.5V in two 2.7V super caps in series. If you have an idea of a good buck-boost converter outputing 3.3V, I'm all ears
        • C ceech
          @alexsh1 I use it. On this board:
          http://www.ebay.com/itm/ATmega328p-board-w-NRF24l01-socket-LTC4079-battery-charger-in-Arduino-PRO-form-/331800929918?ssPageName=STRK:MESE:IT
          It works.
          alexsh1A
          alexsh1A
          alexsh1
          @ceech no wonder I like your board. These buck-boost converter works really well with a solar panel
            I already have one boost buck converter, I only need the supercap charge controller for 2 supercap or use the 5.5v 4F I have
              alexsh1A
              alexsh1A
              alexsh1
              @gohan what's the input voltage for your buck-boost converter?
                https://m.aliexpress.com/s/item/32757272432.html
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @gohan I think it looked at it. I liked the range, but I think it is a noisy one. Did you test it with oscilloscope?
                    Nope, no oscilloscope available 😇
                    • alexsh1A alexsh1
                      @alexsh1
                      NeverDieN
                      NeverDieN
                      @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
                      According to its datasheet (http://www.ti.com/product/TPS63030), the TPS63030 has exactly the same Input Voltage Range: 1.8 V to 5.5 V
                      • C
                        C
                        ceech
                        There is a Maxim integrated buck-boost converter, that goes down to 0.7V
                        http://www.mouser.com/ds/2/256/MAX1584-MAX1585-43040.pdf
                        It's quite complex though
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @NeverDie you are correct - TPS63030 has got 1.8-5.5V input voltage.
                          I wonder if there is a buck-boost converter with lower than 1V lower voltage?
                          • C ceech
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @ceech you bet - personally I'd stick to something much more simple
                            • alexsh1A alexsh1
                              NeverDieN
                              NeverDieN
                              You'd probably get the biggest range by combining a separate boost converter with a separate buck converter, rather than using a single integrated buck-boost unit.
                                Well, so far the green supercap isn't holding its charge any better. I'll leave it in-circuit for two or three days, though, and see if that improves. It's encouraging that the rate of voltage decrease is decreasing. Some supercaps apparently improve their ability to retain charge if they are forced to hold a charge long enough, though I have no idea why that is. For instance, some capacitor leakage test protocols call for holding a capacitor at its rated voltage for 72 hours before running the leakage test.
                                NeverDieN
                                NeverDieN
                                #195
                                Well, try as I might, I just can't recommend these Chinese supercaps. I've held them at rated voltage for days on end, and I've power cycled them too. For whatever reason, they just don't perform as well as the branded supercaps that I've ordered from Digikey. I'll use-up the few I have on some throw-away prototype experiments, and I won't be ordering any more of them. Presently I think the 10F supercap on Digikey for $2 from Illinois Capacitor continues to be the best of the "value" capacitors. For best performance, I've been pleased with the AVX brand of supercaps.
                                However, if someone finds something better, either by value or by performance, please do post and let me know.
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #196
                                  @NeverDie I have a few AVX caps and they are really good
                                  • C
                                    C
                                    ceech
                                    wrote on last edited by ceech
                                    #197
                                    A few boards arrived and a couple are assembled
                                    The board charges four 1.5F 2.7V super capacitors. It also provides a boost circuit with 3.45V output on main and sub outputs. It works down to 180mV and provides 3.5mA for 30 minutes. I'll report on leakage.
                                    There are two outputs main and sub. Main is on all the time and sub is switched with high signal on the mode connector.
                                    gohanG 1 Reply Last reply
                                    • C ceech
                                      @ceech is the output clean enough to power a nrf24?
                                      wallyllamaW 1 Reply Last reply
                                        wallyllamaW
                                        wallyllamaW
                                        wallyllama
                                        @gohan if not you could add.... wait for it.... a capacitor. (Weak, I know, but I couldnt resist)
                                          Unfortunately it's not that easy, it depends on the type of "noise" created by the booster so one type of capacitor is better than another, a low pass filter may be needed.
