  3. Vera
  4. ESP8266 gateway with VeraPlus
11 Posts 3 Posters 7.2k Views 4 Watching
  • dbemowskD
    dbemowskD
    OK, pardon my ignorance. I have read a bunch of the threads on the ESP8266 used with a sonoff, but I am still slightly confused. My confusion comes on the Vera side of this. So if I use the gateway code on the sonoff, how is the Vera able to see and control the device? In my setup, I just have a serial nRF24L01 gateway connected to the Vera. Does the Vera use it's internal wifi to talk to the devices? Can someone outline a simple relay command from the Vera controller to the sonoff and how it communicates to the sonoff node? If I wanted to do node to node control from an nRF24 node to an ESP node, how would I bridge the gap?
    korttomaK 1 Reply Last reply
    • dbemowskD dbemowsk
      korttomaK
      korttomaK
      korttoma
      @dbemowsk I have not used any sonoff devices but the ESP8266 in any case would need to be added to Vera as another Gateway so that you have 2 Gateways in Vera like this:
      This means that you then have also 2 separate MySensors networks but the ESP8266 would have no transport layer (NRF24L01+ or RFM69 or something else).
      The sonoff local features needs to be added to the Gateway code as local sensors and actuators.
      Since this setup forms 2 separate networks there is no way to send any control commands directly from the nRF24 node to an ESP node. You need to handle this part in Vera.
      I have not looked in to the sonoff device but if it was possible to add a nRF24 to it then you could actually create additional nodes to this network which could then control the ESP local sensors/actuator also. It would be much easier to make some logic in Vera to forward some commands though.
      • Tomas
      dbemowskD 1 Reply Last reply
      • korttomaK korttoma
        dbemowskD
        dbemowskD
        @korttoma Thanks for the reply. My question then is, if I have multiple sonoffs/ESP8266 devices, do I need to present each as it's own gateway?
        I currently have one of these wifi outlets that I bought from walmart.
        0_1485493898513_upload-61118b76-e0fc-44b1-b790-d4d9d6027cb0
        These too run from an ESP8266 chip. I hacked this one with ESP Easy firmware from letscontrolit.com and I installed the HTTP Switch plugin on the Vera.
        0_1485494221921_upload-fc2712bb-34d4-4e0f-b548-e498e5f21a0d
        I had to do some tweaking to the lua file for the plugin to get it to work. but I can turn a light on and off.
        My main reason for this post was to see if I would gain anything in switching it to a MySensors node instead since I have a number of other MySensors devices. If I have to create scenes or someother lua code on the Vera side to get the nodes to talk to each other, I may just stick with the ESP Easy firmware.
          korttomaK
          korttomaK
          korttoma
          @dbemowsk yes each ESP is presented as another Gateway in Vera if you use the ESP Gateway sketch (currently this is the only MySensors implementation available). I say stick with the ESP Easy firmware since you gain nothing by using the MySensors ESP gateway implementation.
          Unless you can come up with something better ;)
          • Tomas
            dbemowskD
            dbemowskD
            @korttoma In that case, I agree. Base on what you are saying I think I would be better off with the ESP Easy firmware all around because if I am correct, Vera would show 2 objects for every ESP. Both the gateway device and the sensor device. With the ESP Easy I would just create another HTTP Switch. I wouldn't have to deal with the extra gateway object fort each one.
            I truly appreciate your feedback.
              korttomaK
              korttomaK
              korttoma
              @dbemowsk you would actually get 3 objects per ESP using the MySensors implementation.
              Gateway, Node 0 and Switch.
              • Tomas
                dbemowskD
                dbemowskD
                @korttoma Ahhhh, yes, I forgot the node object. That solidifies my decision even more. I just have a few more tweaks to figure out with the HTTP Switch code to make it a bit more flexible with ESP Easy. The biggest being how to define a variable for setting the GPIO pin under the advanced section of the device, and then figuring out how to access that variable in the lua code. Right now I have GPIO 15 hard coded in the lua file (L_HttpSwitch1.lua) as the pin to control the relay. The problem in that is that when I get the sonoffs, if they use a different GPIO pin to control the relays than the devices that I bought at walmart, that might be a problem. I just need to learn more about coding an app for Vera.
                camadortC 1 Reply Last reply
                  camadortC
                  camadortC
                  camadort
                  @dbemowsk said in ESP8266 gateway with VeraPlus:
                  L_HttpSwitch1.lua
                  @dbemowsk Can you share your L_HttpSwitch1.lua please.
                  • camadortC camadort
                    L_HttpSwitch1.lua
                    dbemowskD
                    dbemowskD
                    @camadort My appologies for the INSANELY late response to this. Not sure how I missed this. I am not sure if you are the one that just sent me an email requesting this, but here is more information.
                    The plugin that I have installed that this modified file originates from is the "HTTP Switch (WiFi Switch)" plugin. The icon for the plugin looks like this:
                    0_1498853761585_upload-de7bc467-3966-48df-a3c6-21197b99327f
                    It has been a while since I made the changes, so there may be a few other file changes that you need besides just the lua file for setting the GPIO pin. Here are my files:
                    L_HttpSwitch1.Lua
                    	local HS_SID = "urn:mios-nullx8-com:serviceId:HttpSwitch1"
                    	local HAD_SID = "urn:micasaverde-com:serviceId:HaDevice1"
                    	local DEFAULT_ADDRESS = "127.0.0.1"
                    	-- just a function to decode (decode only) json responses
                    	function decode_json(json)
                    		if (not json) then
                    			return nil
                    		end
                    		local str = {}
                    		local escapes = { r='\r', n='\n', b='\b', f='\f', t='\t', Q='"', ['\\'] = '\\', ['/']='/' }
                    		json = json:gsub('([^\\])\\"', '%1\\Q'):gsub('"(.-)"', function(s)
                    			str[#str+1] = s:gsub("\\(.)", function(c) return escapes[c] end)
                    			return "$"..#str
                    		end):gsub("%s", ""):gsub("%[","{"):gsub("%]","}"):gsub("null", "nil")
                    		json = json:gsub("(%$%d+):", "[%1]="):gsub("%$(%d+)", function(s)
                    		return ("%q"):format(str[tonumber(s)])
                    		end)
                    		return assert(loadstring("return "..json))()
                    	end
                    	local function log(text)
                    		local id = PARENT_DEVICE or "unknown"
                    			luup.log("HttpSwitch Plugin #" .. id .. " " .. text)
                    		end
                    	local function InitSettings(address)
                    		address = address or DEFAULT_ADDRESS
                    		luup.variable_set(HS_SID, "Address", address, parentDevice)
                    		luup.variable_set(HS_SID, "Poll", "120", parentDevice)
                    		luup.variable_set(HS_SID, "GPIO", "1", parentDevice)
                    		if (address == DEFAULT_ADDRESS) then
                    			luup.variable_set(HS_SID, "LinkStatus", "SET IP!", parentDevice)
                    		else
                    			luup.variable_set(HS_SID, "LinkStatus", "...", parentDevice)
                    		end
                    		luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", "0", parentDevice)
                    		luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Target", "0", parentDevice)
                    		log("Initialized variable: 'Address' = " .. address)
                    		log("Initialized variable: 'Target' = " .. Target)
                    		log("Initialized variable: 'Status' = " .. Status)
                    		log("Initialized variable: 'Poll' = " .. Poll)
                    		luup.task("Please restart Luup to initialize the plugin.", 1, "HttpSwitch Plugin", -1)
                    		return address
                    	end
                    	local function readLocalSettings(parentDevice)
                    		local address = luup.variable_get(HS_SID, "Address", parentDevice)
                    		local Poll = luup.variable_get(HS_SID, "Poll", parentDevice)
                    		local GPIO = luup.variable_get(HS_SID, "GPIO", parentDevice)
                    		if (address == nil) then
                    		log("Init Settings")
                    			address = InitSettings(address)
                    		end
                    		if (Poll == nil) then
                    			Poll = InitSettings(address)
                    		end
                    		if (GPIO == nil) then
                    			GPIO = InitSettings(address)
                    		end
                    		return address, Poll, GPIO
                    	end
                    	function GetRemoteStatus()
                    		local address, Poll = readLocalSettings(parentDevice)
                    		--status command for ESP Easy
                    		local url = "http://".. address .."/control?cmd=status,GPIO," .. GPIO
                    		local status, result = luup.inet.wget(url,6)
                    		if status == 0 then
                    			local data = decode_json(result)
                    			local PowerState = data.state
                    			luup.variable_set(HS_SID, "Status", PowerState, parentDevice)
                    			luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", PowerState, parentDevice)
                    			luup.variable_set(HS_SID, "LinkStatus", LinkStatus, parentDevice)
                    		end
                    		luup.call_delay ("GetRemoteStatus", Poll, "")
                    	end
                    	function PingCheck()
                    		pingcommand = "ping -c 1 " ..address
                    		log("executing [ ping -c 1 " .. address .. " ]")
                    		pingresponse = os.execute(pingcommand)
                    		if (pingresponse == 0) then
                    			luup.variable_set(HS_SID,"PingStatus","up",parentDevice)
                    			luup.variable_set(HS_SID, "LinkStatus", "Online!", parentDevice)
                    			log("Ping reply ")
                    		else
                    			luup.variable_set(HS_SID,"PingStatus","down",parentDevice)
                    			luup.variable_set(HS_SID, "LinkStatus", "Offline!", parentDevice)
                    			log("No ping reply ")
                    		end
                    		PingInterval = luup.variable_get(HS_SID,"Poll", parentDevice)
                    		luup.call_delay("PingCheck", Poll, "")
                    	end
                    	function main(parentDevice)
                    		-- Note these are "pass-by-Global" values that refreshCache will later use.
                    		PARENT_DEVICE = parentDevice
                    		log("starting up..")
                    		luup.variable_set(HAD_SID, "LastUpdate", os.time(os.date('*t')), parentDevice)
                    		luup.variable_set(HAD_SID, "Configured", "1", parentDevice)
                    		-- Validate that the Address/Delay are configured in Vera, otherwise this
                    		-- code wont work.
                    		local address = readLocalSettings(parentDevice)
                    		local Poll = readLocalSettings(parentDevice)
                    			log("could not be started.")
                    			log("adress value " .. address)
                    			luup.set_failure(true, parentDevice)
                    			return false
                    		end
                    		luup.call_delay ("GetRemoteStatus", 30, "")
                    		luup.call_delay("PingCheck", 10, "")
                    		return true
                    	end
                    	local function FlipOn()
                        		luup.inet.wget("http://" .. address .. "/control?cmd=gpio," .. GPIO .. ",1")
                    		luup.variable_set("urn:upnp-org:serviceId:SwitchPower1", "Status", "1", parentDevice)
                            	luup.variable_set(HS_SID, "Status", "1", parentDevice)
                    		GetRemoteStatus()
                    	end
                    	local function FlipOff()
                        		luup.inet.wget("http://" .. address .. "/control?cmd=gpio," .. GPIO .. ",0")
                            	luup.variable_set(HS_SID, "Status", "0", parentDevice)
                    		GetRemoteStatus()
                    	end
                    -- last line
                    D_HttpSwitch1.json
                       "flashicon":"icons/Binary_Light.png",
                       "imgIconBody":"",
                       "imgIconDimmable":"",
                       "imgIconTurnable":"",
                       "imgIconMin":"icons/Binary_Light_0.png",
                       "imgIconMax":"icons/Binary_Light.png",
                       "halloIconsDir":"pics/hallo",
                       "state_icons":[
                             "img":"binary_light_off.png",
                             "conditions":[
                                   "service":"urn:upnp-org:serviceId:SwitchPower1",
                                   "variable":"Status",
                                   "operator":"==",
                                   "value":0,
                                   "subcategory_num":0
                             "img":"binary_light_on.png",
                             "conditions":[
                                   "operator":"==",
                                   "value":1,
                                   "subcategory_num":0
                       "x":"2",
                       "y":"4",
                       "inScene":"1",
                       "DisplayStatus":{
                          "Service":"urn:upnp-org:serviceId:SwitchPower1",
                          "Variable":"Status",
                          "MinValue":"0",
                          "MaxValue":"1"
                       "doc_url":{
                          "doc_language":1,
                          "doc_manual":1,
                          "doc_version":1,
                          "doc_platform":0,
                          "doc_page":"devices"
                       "ToggleButton":1,
                       "Tabs":[
                             "Label":{
                                "lang_tag":"tabname_control",
                                "text":"Control"
                             "Position":"0",
                             "TabType":"flash",
                             "ControlGroup":[
                                   "id":"1",
                                   "isSingle":"1",
                                   "scenegroup":"1"
                                   "id":"2",
                                   "isSingle":"1",
                                   "scenegroup":"1"
                                   "id":"3",
                                   "isSingle":"1",
                                   "scenegroup":"2"
                                   "id":"4",
                                   "isSingle":"1",
                                   "scenegroup":"3"
                             "SceneGroup":[
                                   "id":"1",
                                   "top":"2",
                                   "left":"0",
                                   "x":"2",
                                   "y":"1"
                                   "id":"2",
                                   "top":"-0.9",
                                   "left":"-1.13",
                                   "x":"2",
                                   "y":"1"
                                   "id":"3",
                                   "top":"-0.4",
                                   "left":"-1.13",
                                   "x":"2",
                                   "y":"1"
                             "Control":[
                                   "ControlGroup":"2",
                                   "ControlType":"button",
                                   "top":"0",
                                   "left":"1",
                                   "Label":{
                                      "lang_tag":"cmd_on",
                                      "text":"On"
                                   "Display":{
                                      "Value":"1",
                                      "Top":20,
                                      "Left":150,
                                      "Width":75,
                                      "Height":20
                                   "Command":{
                                      "Service":"urn:mios-nullx8-com:serviceId:HttpSwitch1",
                                      "Action":"On",
                                      "Parameters":[
                                            "Name":"newTargetValue",
                                            "Value":"1"
                                   "ControlGroup":"1",
                                   "ControlType":"variable",
                                   "top":"-1",
                                   "left":"0",
                                   "text_align":"left",
                                   "Display":{
                                      "Variable":"LinkStatus",
                                      "Top":21,
                                      "Left":2,
                                      "Width":240,
                                      "Height":20
                                   "ControlGroup":"1",
                                   "top":"0",
                                   "left":"0",
                                   "Label":{
                                      "lang_tag":"cmd_off",
                                      "text":"Off"
                                   "Display":{
                                      "Value":"0",
                                      "Top":20,
                                      "Left":50,
                                      "Width":75,
                                      "Height":20
                                   "Command":{
                                      "Action":"Off",
                                      "Parameters":[
                                            "Value":"0"
                             "Label":{
                                "lang_tag":"advanced",
                                "text":"Advanced"
                             "Position":"2",
                             "TabType":"javascript",
                             "ScriptName":"shared.js",
                             "Function":"advanced_device"
                             "Label":{
                                "lang_tag":"notifications",
                                "text":"Notifications"
                             "Position":"5",
                             "Function":"device_notifications"
                       "sceneList":{
                          "group_1":{
                             "cmd_1":{
                                "label":"ON",
                                "serviceId":"urn:mios-nullx8-com:serviceId:HttpSwitch1",
                                "action":"On",
                                "arguments":{
                                   "newTargetValue":"1"
                                "display":{
                                   "service":"urn:mios-nullx8-com:serviceId:HttpSwitch1",
                                   "value":"1"
                             "cmd_2":{
                                "label":"OFF",
                                "action":"Off",
                                "arguments":{
                                   "newTargetValue":"0"
                                "display":{
                                   "value":"0"
                       "eventList2":[
                             "id":1,
                             "label":{
                                "lang_tag":"a_device_is_turned_on_off",
                                "text":"A device is turned on or off"
                             "argumentList":[
                                   "id":1,
                                   "dataType":"boolean",
                                   "defaultValue":"1",
                                   "allowedValueList":[
                                         "Off":"0",
                                         "HumanFriendlyText":{
                                            "lang_tag":"hft_device_turned_off",
                                            "text":"_DEVICE_NAME_ is turned off"
                                         "On":"1",
                                            "lang_tag":"hft_device_turned_on",
                                            "text":"_DEVICE_NAME_ is turned on"
                                   "name":"Status",
                                   "comparisson":"=",
                                   "prefix":{
                                      "lang_tag":"which_mode",
                                      "text":"Which mode"
                                   "suffix":{
                       "DeviceType":"urn:mios-nullx8-com:device:HttpSwitch:1"
                    D_HttpSwitch1.xml
                    <?xml version="1.0" encoding="UTF-8"?>
                    <root xmlns="urn:schemas-upnp-org:device-1-0">
                       <specVersion>
                          <major>1</major>
                          <minor>13</minor>
                       </specVersion>
                       <device>
                          <deviceType>urn:upnp-org:serviceId:SwitchPower1</deviceType>
                          <staticJson>D_HttpSwitch1.json</staticJson>
                          <friendlyName>KK-SP3 Smart WiFi Switch</friendlyName>
                          <manufacturer>nullx8</manufacturer>
                          <protocol>cr</protocol>
                          <handleChildren>0</handleChildren>
                          <serviceList>
                             <service>
                                <serviceType>urn:mios-nullx8-com:service:HttpSwitch:1</serviceType>
                                <serviceId>urn:mios-nullx8-com:serviceId:HttpSwitch1</serviceId>
                                <SCPDURL>S_HttpSwitch1.xml</SCPDURL>
                             </service>
                             <service>
                                <serviceType>urn:schemas-upnp-org:service:SwitchPower:1</serviceType>
                                <serviceId>urn:upnp-org:serviceId:SwitchPower1</serviceId>
                                <SCPDURL>S_SwitchPower1.xml</SCPDURL>
                             </service>
                          </serviceList>
                          <implementationList>
                             <implementationFile>I_HttpSwitch1.xml</implementationFile>
                          </implementationList>
                       </device>
                    </root>
                      L_HttpSwitch1.Lua
                      		if (not json) then
                      			return nil
                      		end
                      		local str = {}
                      			return "$"..#str
                      		end)
                      	end
                      		end
                      		else
                      		end
                      		return address
                      	end
                      		end
                      		end
                      		end
                      	end
                      		if status == 0 then
                      		end
                      	end
                      			log("Ping reply ")
                      		else
                      		end
                      	end
                      		-- code wont work.
                      			return false
                      		end
                      		return true
                      	end
                      		GetRemoteStatus()
                      	end
                      		GetRemoteStatus()
                      	end
                      -- last line
                      D_HttpSwitch1.json
                         "imgIconBody":"",
                         "state_icons":[
                               "conditions":[
                                     "operator":"==",
                                     "value":0,
                                     "subcategory_num":0
                               "conditions":[
                                     "operator":"==",
                                     "value":1,
                                     "subcategory_num":0
                         "x":"2",
                         "y":"4",
                         "inScene":"1",
                         "DisplayStatus":{
                            "MinValue":"0",
                            "MaxValue":"1"
                         "doc_url":{
                            "doc_language":1,
                            "doc_manual":1,
                            "doc_version":1,
                            "doc_platform":0,
                         "ToggleButton":1,
                         "Tabs":[
                               "Label":{
                                  "text":"Control"
                               "Position":"0",
                               "TabType":"flash",
                               "ControlGroup":[
                                     "id":"1",
                                     "isSingle":"1",
                                     "scenegroup":"1"
                                     "id":"2",
                                     "isSingle":"1",
                                     "scenegroup":"1"
                                     "id":"3",
                                     "isSingle":"1",
                                     "scenegroup":"2"
                                     "id":"4",
                                     "isSingle":"1",
                                     "scenegroup":"3"
                               "SceneGroup":[
                                     "id":"1",
                                     "top":"2",
                                     "left":"0",
                                     "x":"2",
                                     "y":"1"
                                     "id":"2",
                                     "top":"-0.9",
                                     "left":"-1.13",
                                     "x":"2",
                                     "y":"1"
                                     "id":"3",
                                     "top":"-0.4",
                                     "left":"-1.13",
                                     "x":"2",
                                     "y":"1"
                               "Control":[
                                     "ControlGroup":"2",
                                     "top":"0",
                                     "left":"1",
                                     "Label":{
                                        "text":"On"
                                     "Display":{
                                        "Value":"1",
                                        "Top":20,
                                        "Left":150,
                                        "Width":75,
                                        "Height":20
                                     "Command":{
                                        "Action":"On",
                                        "Parameters":[
                                              "Value":"1"
                                     "ControlGroup":"1",
                                     "top":"-1",
                                     "left":"0",
                                     "Display":{
                                        "Top":21,
                                        "Left":2,
                                        "Width":240,
                                        "Height":20
                                     "ControlGroup":"1",
                                     "top":"0",
                                     "left":"0",
                                     "Label":{
                                        "text":"Off"
                                     "Display":{
                                        "Value":"0",
                                        "Top":20,
                                        "Left":50,
                                        "Width":75,
                                        "Height":20
                                     "Command":{
                                        "Action":"Off",
                                        "Parameters":[
                                              "Value":"0"
                               "Label":{
                                  "text":"Advanced"
                               "Position":"2",
                               "Label":{
                               "Position":"5",
                         "sceneList":{
                            "group_1":{
                               "cmd_1":{
                                  "label":"ON",
                                  "action":"On",
                                  "arguments":{
                                  "display":{
                                     "value":"1"
                               "cmd_2":{
                                  "label":"OFF",
                                  "action":"Off",
                                  "arguments":{
                                  "display":{
                                     "value":"0"
                         "eventList2":[
                               "id":1,
                               "label":{
                               "argumentList":[
                                     "id":1,
                                     "defaultValue":"1",
                                           "Off":"0",
                                           "On":"1",
                                     "name":"Status",
                                     "comparisson":"=",
                                     "prefix":{
                                        "text":"Which mode"
                                     "suffix":{
                      D_HttpSwitch1.xml
                         <specVersion>
                            <major>1</major>
                            <minor>13</minor>
                         </specVersion>
                         <device>
                            <serviceList>
                               <service>
                               </service>
                               <service>
                               </service>
                            </serviceList>
                         </device>
                      </root>
                      camadortC
                      camadortC
                      camadort
                      @dbemowsk Thanks!
                        @dbemowsk Thanks!
                        dbemowskD
                        dbemowskD
                        @camadort Let me know if you have trouble. Someone else was emailing me about this issue and they mentioned this thread. I thought it was you, but it wasn't. I don't know if he got his going or not.
                        Anyways, his email to me prompted me to do a blog post on my website about this topic.
                        http://dan.bemowski.info/2017/07/04/using-a-sonoff-with-espeasy-and-a-vera-home-controller/
                        I have a link to the zip file with the three HttpSwitch files. These files have exactly what I posted above, but they are the actual files pulled from my vera in the event that you have trouble creating your own with the above code. It also has instructions on configuring both the device and the Vera side of things.
