Motionsensor
Hi guys,
I just build my first motionsensor but i think I have some problems. Everything is working and the sensors send 1 and 0 to my gateway, but my problem is that it looks like this in the serial monitor.
1 0 1 0 0 1 0 1 1 0 1 1 0 1 1 0 1 0 0 1 0 1 1 0 1 1 0 1 1 0 1 0 1 1 0 1 1 0 1 1 0 1 0The problem is that I get like 10 - 20 updates / second and as you see, its 1 and 0 at the same time and its pointed at a clean wall with no motions.
Anyone have any thoughts how to solve this?
Cheers
I had my PIR sensor triggering randomly until I powered it directly from the 5v power supply and not from the arduino 5V pin.
Also you may add a check to report only when status actually change, add a little delay on loop function or even better a sleep like this from the examples
// Sleep until interrupt comes in on motion sensor. Send update every two minute. sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME); -
I'm running the example sketch so the sleepfunction is allready there. So it's the 5V power that's the issue?
