  3. MySensor auto node ID
7 Posts 4 Posters 5.4k Views 4 Watching
  • benyaB
    benyaB
    benya
    Setup:
    • Raspberry Pi serial gateway.
    • Node on Arduino Nano. Bare minimum code.
    Problem:
    Node fails to register when neither NODE_ID or MY_NODE_ID defined. It registers fine when MY_NODE_ID defined explicitly.
    Sketch:
    #define MY_BAUD_RATE 38400
    #define SENSOR_ID 1
    #define OPEN 1
    #define CLOSE 0
    MyMessage msg(SENSOR_ID, V_TRIPPED);
    uint8_t value = OPEN;
        present(SENSOR_ID, S_DOOR);
        value = value == OPEN ? CLOSE : OPEN;
        send(msg.set(value));
        sleep(10000);
    Gateway log when node uses MY_NODE_ID=AUTO:
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0-beta
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.2.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    Node's log with MY_NODE_ID=AUTO:
    10 TSM:INIT
    12 TSF:WUR:MS=0
    22 TSM:INIT:TSP OK
    28 !TSF:SID:FAIL,ID=0
    34 TSM:FAIL:CNT=1
    38 TSM:FAIL:PDT
    10045 TSM:FAIL:RE-INIT
    10051 TSM:INIT
    10061 TSM:INIT:TSP OK
    10067 !TSF:SID:FAIL,ID=0
    10074 TSM:FAIL:CNT=2
    10080 TSM:FAIL:PDT
    20086 TSM:FAIL:RE-INIT
    20092 TSM:INIT
    20103 TSM:INIT:TSP OK
    20109 !TSF:SID:FAIL,ID=0
    20115 TSM:FAIL:CNT=3
    20121 TSM:FAIL:PDT
    Gateway log when node uses MY_NODE_ID=1:
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
    mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=1
    mysgw: TSF:PNG:SEND,TO=0
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    mysgw: TSF:MSG:PINGED,ID=1,HP=1
    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    mysgw: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    mysgw: TSF:MSG:READ,1-1-0,s=1,c=0,t=0,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    mysgw: !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysgw: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=1,l=1,sg=0:0
    mysgw: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=1,l=1,sg=0:1
    Node log with MY_NODE_ID=1:
    10 TSM:INIT
    12 TSF:WUR:MS=0
    22 TSM:INIT:TSP OK
    28 TSM:INIT:STATID=1
    36 TSF:SID:OK,ID=1
    43 TSM:FPAR
    79 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    354 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    368 TSF:MSG:FPAR OK,ID=0,D=1
    2101 TSM:FPAR:OK
    2105 TSM:ID
    2109 TSM:ID:OK
    2113 TSM:UPL
    2117 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2136 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2150 TSF:MSG:PONG RECV,HP=1
    2158 TSM:UPL:OK
    2162 TSM:READY:ID=1,PAR=0,DIS=1
    2207 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
    2228 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2256 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.1.1
    2293 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4313 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4331 MCO:REG:REQ
    4370 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
    6397 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
    6416 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    6430 MCO:PIM:NODE REG=1
    6436 MCO:BGN:INIT OK,TSP=1
    6453 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
    6469 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
    6483 MCO:SLP:TPD
    6490 MCO:SLP:WUP=-1
    What's wrong with my setup?
    • benyaB benya
      Setup:
      Problem:
      Sketch:
      #define SENSOR_ID 1
      #define OPEN 1
      #define CLOSE 0
          sleep(10000);
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      10 TSM:INIT
      12 TSF:WUR:MS=0
      22 TSM:INIT:TSP OK
      34 TSM:FAIL:CNT=1
      38 TSM:FAIL:PDT
      10051 TSM:INIT
      10080 TSM:FAIL:PDT
      20092 TSM:INIT
      20121 TSM:FAIL:PDT
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      mysgw: TSF:MSG:BC
      mysgw: TSF:CKU:OK
      10 TSM:INIT
      12 TSF:WUR:MS=0
      22 TSM:INIT:TSP OK
      36 TSF:SID:OK,ID=1
      43 TSM:FPAR
      2101 TSM:FPAR:OK
      2105 TSM:ID
      2109 TSM:ID:OK
      2113 TSM:UPL
      2158 TSM:UPL:OK
      4331 MCO:REG:REQ
      6483 MCO:SLP:TPD
      6490 MCO:SLP:WUP=-1
      @benya it looks to me like AUTO has been redefined from 255 to 0. Could you check if there are any redefine warnings in the compile output? Adding a Serial.println(AUTO) in before() might help to check the value as well. Or try to set the node ID to the value 255.
      benyaB 1 Reply Last reply
        Did you use the node for something else earlier? Like a gateway? Try clearing EEPROM to get rid of old settings.
          benyaB
          benyaB
          benya
          @mfalkvidd I added
          #if MY_NODE_ID==255
          #error MY_NODE_ID==255
          And compiler reported
          dummy_mysensor:16: error: #error MY_NODE_ID==255
          exit status 1
          So MY_NODE_ID is 255.
          Yes, I cleared EEPROM as well.
            Did you use the provided clear sketch or do a clear yourself? If the latter, node that you should write 0xff to all positions.
            F benyaB 2 Replies Last reply
              F
              F
              flopp
              You can confirm that you have Cleared the EEPROM by opening the Serial Monitor and see what happens
                benyaB
                benyaB
                benya
                @hek That was it. Got node registered after clearing with 0xff.
                Thanks a lot! :joy:
