  3. display with RTC showing wrong time
11 Posts 3 Posters 3.9k Views 1 Watching
  • D
    D
    dayve218
    hey, ive put together the sensor and its showing the wrong time, its currently 7:30pm, and its displaying 8pm.
    any ideas?
    RJ_MakeR 1 Reply Last reply
      You have to give us some more information about your environment.
      Which controller? What does the logs say?
      • D
        D
        dayve218
        sorry @hek, im using the vera lite. how do i view the logs?
        • D dayve218
          any ideas?
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @dayve218 I believe the RTC time is set @ sketch compilation?
          RJ_Make
            The example sketch requests time from Vera at startup. So if you have the wrong time or timezone in Vera things will be wrong in the sensor too.
            D 1 Reply Last reply
              D
              D
              dayve218
              @hek im using the example sketch, and the time on my vera seems to be right?
                What does the serial monitor in IDE say when you have sensor attached to computer?
                • D
                  D
                  dayve218
                  @hek
                  sensor started, id 4
                  send: 4-4-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                  send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                  read: 4-1-0 s=255,c=3,t=6,pt=1,l=1:0
                  read: 0-0-4 s=255,c=3,t=6,pt=0,l=2:M
                  send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=9,st=ok:RTC Clock
                  send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                  send: 4-4-0-0 s=255,c=3,t=1,pt=0,l=3,st=ok:1.0
                  read: 4-1-0 s=255,c=3,t=1,pt=0,l=3:1.0
                  requesting time
                  read: 0-0-4 s=255,c=3,t=1,pt=0,l=11:1416699687
                  Time value received: 1416699687
                    What timezone and time have you set in Vera?
                    • D
                      D
                      dayve218
                        @dayve218 said:
                        1416699687
                        You can try converting the timestamp to date here:
                        http://www.onlineconversion.com/unix_time.htm
