  3. Next generation dust sensor for MySensors
30 Posts 12 Posters 31.3k Views 17 Watching
  • N Offline
    N Offline
    #21
    BTW, I hooked up the Honeywell, and this is the total amount of what it displays:
    PS- Reading Particle Measurements...
    PS- Sending cmd: 68 1 4 93
    PS- Waiting for cmd resp...
    PS- Received valid data!!!
    PM 2.5: 3 ug/m3
    PM 10: 4 ug/m3
    It shows less for PM2.5 and PM10 than the PMS5003. I presume the numbers are more trustworthy, though, since it was factory calibrated.
    • S Offline
      subs
      Hi. I am late here but i will ask anyways. So what is the review between PMS7003 and Honeywell HPM sensors?
      I'd like to build a low cost opensource AQI device for Indian cities with added temperature, humidity and ambient pressure data and then send it to cloud using GPRS/GSM or Wifi (esp8266 as MCU). But i am confused about the Honeywell HPM sensor - its accuracy as compared to BAM or other PM measurement standards. Any help will be great!
      SebexS 1 Reply Last reply
      • S subs
        SebexS Offline
        SebexS Offline
        Sebex
        @NeverDie could you share your Honeywell code, I have trouble getting it to work. An example will help me a lot t learn from!
        N N 2 Replies Last reply
        • SebexS Sebex
          N Offline
          N Offline
          @Sebex Hi, I had looked into this for the purpose of testing the effectiveness of air filtration on a 3D printer enclosure. Unfortunately, for lack of effective, yet quiet, filtration at the time, I shelved the project until a future date and so didn't keep the files. However, I'm pretty sure there were libraries for the sensor on github, so I recommend you look there. Good luck!
          • SebexS Sebex
            N Offline
            N Offline
            @Sebex said in Next generation dust sensor for MySensors:
            I made a library for that, I'm updating it to autodetect some various PM, CO2, Formaldehyde UART sensors but I'll find the old version for Honeywell only tomorrow if you want. If I forget, harass me by MP :D
            skywatchS 1 Reply Last reply
            • N Nca78
              skywatchS Offline
              skywatchS Offline
              skywatch
              @Nca78 Do you have any updates on the sensor you were building or the Honeywell code?
              I am thinking of moving the existing sensor to another room and getting a new noe for the bedroom.
              • skywatchS skywatch
                N Offline
                N Offline
                Hello @skywatch, I will put a library online today. Sorry for the long delay.
                  N Offline
                  N Offline
                  @skywatch here you go :
                  https://github.com/Nca78/NcaPMSensorLight
                  @Sebex in case you're still looking for a code, you might be interested.
                  • N Nca78
                    skywatchS Offline
                    skywatchS Offline
                    skywatch
                    @Nca78 Thanks :)
                    I didn't purchase another sensor yet, but will in the furure for sure. Thanks for sharing it will help a lot of people I expect (not just me)! ;)
                    • mfalkviddM Offline
                      #30
                      https://www.bosch-sensortec.com/products/environmental-sensors/particulate-matter-sensor/bmv080/ could be the next generation. No moving parts. Measures PM2.5. Datasheet: https://www.bosch-sensortec.com/media/boschsensortec/downloads/product_flyer/bst-bmv080-fl000.pdf
