  3. Next generation dust sensor for MySensors
30 Posts 12 Posters 31.7k Views 17 Watching
    So, which is better? 😀
    alexsh1A
    alexsh1A
    alexsh1
    @gohan This is hard to say. Every sensor has got its pros and cons. You may be happy with $2-3 sensor or need a more precision sensor for $25. It depends.
    I would say that PMS7003 is very advanced and precise enough. However, this is my subjective opinion.
    • alowhumA alowhum
      Here's MySensors Arduino code for the PMS-7003. Many thanks to scapeler.com for the core of the code.
       *  DESCRIPTION
       *  Plantower PMS-7003 fine dust sensor
       *  This sensor uses a frickin' laser to measure lots of different fine dust levels, between 0.3 and 10 microns.
       *  It communicates with your board over serial at 9600 speed.
       *  This code makes use of kindly shared code by Scapeler:
       *  Copyright 2017 Scapeler
       * Licensed under the Apache License, Version 2.0 (the "License");
       * you may not use this file except in compliance with the License.
       * You may obtain a copy of the License at
          http://www.apache.org/licenses/LICENSE-2.0
       * Unless required by applicable law or agreed to in writing, software
       * distributed under the License is distributed on an "AS IS" BASIS,
       * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
       * See the License for the specific language governing permissions and
       * limitations under the License.
      // if you uncomment this, you can get test and debug updates about the sensor' wireless connection by using the serial monitor tool.
      #define MY_RADIO_NRF24                              // A 2.4Ghz transmitter and receiver, often used with MySensors.
      #define MY_RF24_PA_LEVEL RF24_PA_MIN                // This sets a low-power mode for the radio. Useful if you use the verison with the bigger antenna, but don't want to power that from a separate power source. It can also fix problems with fake Chinese versions of the radio.
      // #define MY_RADIO_RFM69                           // 433Mhz transmitter and reveiver.
      // Choose if you want this sensor to also be a repeater.
      // #define MY_REPEATER_FEATURE                      // Just remove the two slashes at the beginning of this line to also enable this sensor to act as a repeater for other sensors. If this node is on battery power, you probably shouldn't enable this.
      // Are you using this sensor on battery power?
      // #define BATTERY_POWERED                          // Just remove the two slashes at the beginning of this line if your node is battery powered. It will then go into deep sleep as much as possible. While it's sleeping it can't work as a repeater!
      #include <SoftwareSerial.h>
      #define CHILD_ID_DUST_PM10 0
      #define CHILD_ID_DUST_PM25 1
      #define CHILD_ID_DUST_PM100 2
      // Mysensors settings.
      MyMessage msgDust10(CHILD_ID_DUST_PM10, V_LEVEL);   // Sets up the message format that we'l be sending to the MySensors gateway later.
      MyMessage msgDust10b(CHILD_ID_DUST_PM10, V_UNIT_PREFIX);
      MyMessage msgDust25(CHILD_ID_DUST_PM25, V_LEVEL);   // Sets up the message format that we'l be sending to the MySensors gateway later.
      MyMessage msgDust25b(CHILD_ID_DUST_PM25, V_UNIT_PREFIX);
      MyMessage msgDust100(CHILD_ID_DUST_PM100, V_LEVEL); // Sets up the message format that we'l be sending to the MySensors gateway later.
      MyMessage msgDust100b(CHILD_ID_DUST_PM100, V_UNIT_PREFIX);
      // These defines and variables can be changed:
      int dustSlowDown = 20;                              // The dust sensor is internally checked approximately every 700 or 800 milliseconds. Once in how many loops should it send the data?
      unsigned long dustMeasurementInterval = 700;        // This is a fickle thing. Changing it can give more time-outs.
      SoftwareSerial mySerial(10, 11);                    // RX, TX . You can choose other pins if you prefer.
      // PROBABLY BEST NOT TO CHANGE THESE VARIABLES
      int inputHigh = 0;
      int inputLow = 0;
      uint16_t inputChecksum = 0;                         // variable to caclulate checksum input variables
      uint16_t concPM1_0_CF1;                             // Lots of sensor variables
      uint16_t concPM2_5_CF1;
      uint16_t concPM10_0_CF1;
      uint16_t concPM1_0_amb;
      uint16_t concPM2_5_amb;
      uint16_t concPM10_0_amb;
      uint16_t rawGt0_3um;
      uint16_t rawGt0_5um;
      uint16_t rawGt1_0um;
      uint16_t rawGt2_5um;
      uint16_t rawGt5_0um;
      uint16_t rawGt10_0um;
      uint8_t  version;
      uint8_t  errorCode;
      uint16_t checksum;
      int dustSlowDownCounter = 0;
        sendSketchInfo("Air Quality Sensor PMS-7003", "1.1");
        // Register all sensors to gateway (they will be created as child devices):
        present(CHILD_ID_DUST_PM10, S_DUST);
        send(msgDust10b.set("um/m3"));
        present(CHILD_ID_DUST_PM25, S_DUST);
        send(msgDust25b.set("um/m3"));
        present(CHILD_ID_DUST_PM100, S_DUST);
        send(msgDust100b.set("um/m3"));
        delay(1000);
        mySerial.begin(9600);
        delay(1000);
        Serial.println("hello world, I am a sensor.");
        // The dust sensor sends its data continuously, so let's  catch that data.
        int dustSensorOutput = pms7003ReadData();
      // MAIN FUNCTION FOR THE DUST SENSOR, Thanks to Scapeler.nl
      int pms7003ReadData() {
        // while (mySerial.read()!=-1) {};  //clear buffer
        if (mySerial.available() < 32) {
          if (mySerial.available() == 0) {
            delay(150);
            return -1;
          if (mySerial.available() > 16) {
            delay(10);
            return -1;
          if (mySerial.available() > 0) {
            delay(30);
            return -1;
          delay(100);
          return -1;
        if (mySerial.read() != 0x42) return -1;
        if (mySerial.read() != 0x4D) return -1;
        inputChecksum = 0x42 + 0x4D;
        inputHigh = mySerial.read();
        inputLow = mySerial.read();
        inputChecksum += inputHigh + inputLow;
        if (inputHigh != 0x00) return -1;
        if (inputLow != 0x1c) return -1;
        concPM1_0_CF1 = inputLow+(inputHigh<<8);
        concPM2_5_CF1 = inputLow+(inputHigh<<8);
        concPM10_0_CF1 = inputLow+(inputHigh<<8);
        concPM1_0_amb = inputLow+(inputHigh<<8);
        concPM2_5_amb = inputLow+(inputHigh<<8);
        concPM10_0_amb = inputLow+(inputHigh<<8);
        rawGt0_3um = inputLow+(inputHigh<<8);
        rawGt0_5um = inputLow+(inputHigh<<8);
        rawGt1_0um = inputLow+(inputHigh<<8);
        rawGt2_5um = inputLow+(inputHigh<<8);
        rawGt5_0um = inputLow+(inputHigh<<8);
        rawGt10_0um = inputLow+(inputHigh<<8);
        inputChecksum += inputLow;
        version = inputLow;
        errorCode = inputLow;
        Serial.print("PMS7003;");
        // The measurement recalculated to micrograms per cubic meter, a common standard.
        Serial.print(concPM1_0_CF1);
        Serial.print(';');
        Serial.print(concPM2_5_CF1);
        Serial.print(';');
        Serial.print(concPM10_0_CF1);
        Serial.print(';');
        // The measurement recalculated to micrograms per cubic meter, a common standard. Not quite sure what the difference is..
        Serial.print(concPM1_0_amb);
        Serial.print(';');
        Serial.print(concPM2_5_amb);
        Serial.print(';');
        Serial.print(concPM10_0_amb);
        Serial.print(';');
        // this is the 'raw' data that the sensor gathers internally, before it calculates the above values.
        Serial.print(rawGt0_3um); // This indicates total number or particles in 0.1 liter of air that have a diameter above 0.3um. This will be the biggest number, as it measures the most particles. But it's very imprecise: 50% accuracy..
        Serial.print(';');
        Serial.print(rawGt0_5um); // This indicates the total number or particles in 0.1 liter of air that have a diameter above 0.5um (so it will be a smaller count than the line above)
        Serial.print(';');
        Serial.print(rawGt1_0um); // This indicates the total number or particles in 0.1 liter of air that have a diameter above 1 micron. And so on..
        Serial.print(';');
        Serial.print(rawGt2_5um);
        Serial.print(';');
        Serial.print(rawGt5_0um); // Acording to the datashet, at this point the accuracy has reached at 98%.
        Serial.print(';');
        Serial.print(rawGt10_0um);
        Serial.print(';');
        Serial.print(version);
        Serial.print(';');
        Serial.print(errorCode);
        Serial.println("---");
        checksum = inputLow+(inputHigh<<8);
        if (checksum != inputChecksum) {
          Serial.print(';');
          Serial.print(checksum);
          Serial.print(';');
          Serial.print(inputChecksum);
        // Time to send the results to the gateway.
        dustSlowDownCounter = dustSlowDownCounter + 1;
        if(dustSlowDownCounter > dustSlowDown){
          /*  MEASUREMENT  */
          if(rawGt1_0um > 0){
            Serial.println(" Dust1_0 = " + String(concPM1_0_CF1));
            send(msgDust10.set(concPM1_0_CF1,1));
          if(rawGt2_5um > 0){
            Serial.println(" Dust1_0 = " + String(concPM2_5_CF1));
            send(msgDust25.set(concPM2_5_CF1,1));
          if(rawGt10_0um > 0){
            Serial.println(" Dust1_0 = " + String(concPM10_0_CF1));
            send(msgDust100.set(concPM10_0_CF1,1));
          /*  RAW DATA  */
          if(rawGt0_3um > 0){
            Serial.println(" Dust03 = " + String(rawGt0_3um));
            send(msgDust03.set(rawGt0_3um,1));
          if(rawGt0_5um > 0){
            Serial.println(" Dust05 = " + String(rawGt0_5um));
            send(msgDust05.set(rawGt0_5um,1));
          if(rawGt1_0um > 0){
            Serial.println(" Dust10 = " + String(rawGt1_0um));
            send(msgDust10.set(rawGt1_0um,1));
          if(rawGt2_5um > 0){
            Serial.println(" Dust25 = " + String(rawGt2_5um));
            send(msgDust25.set(rawGt2_5um,1));
          if(rawGt5_0um > 0){
            Serial.println(" Dust50 = " + String(rawGt5_0um));
            send(msgDust50.set(rawGt5_0um,1));
            Serial.println(" Dust100 = " + String(rawGt10_0um));
            send(msgDust100.set(rawGt10_0um,1));
        } // End of sensing message.
        delay(700);  // Data will come between 200 and 800 miliseconds. If you set this be be higher than 700 you will get checksum errors.
        return concPM2_5_CF1; // this data doesn't really go anywhere..
      G
      G
      Gavin Nicholson
      wrote on last edited by Gavin Nicholson
      @alowhum Firstly thanks for the code! Just a question to see if this is a cut and paste error. In the section under /* MEASUREMENT */ should the second and third serial.println be Dust2_5 and Dust10_0?
      Also I cant get my head around one thing. The RAW data seems logical in that your comments say that the 0.3 micron values will be the largest as it is measuring everything bigger than that. The 10 should be larger than 25 which will be larger than 100. In my case the raw values match that relationship. HOWEVER, the values sent back (concPMx_y_CF1) are reversed. They start small and go bigger? Is this correct?
      • alowhumA
        alowhumA
        alowhum
        @gohan - I went with the PM7003 because it has less dust buildup and because I spoke with people in the field who were using it as part of scientific sensor networks.
        @Gavin-Nicholson - Yes you are right on the serial print output. I don't know about the reversed output though. I haven't used the sensor in a while. I'll see if I can dig it up.
        G 1 Reply Last reply
        • alowhumA alowhum
          G
          G
          Gavin Nicholson
          @alowhum I am not sure the recalculated figures are correct so I am just going to modify the code and send the raw values.
          • alowhumA alowhum
            After some more research and some reaching out, it seems the PMS7003 is a good fit.
            I've ordered one online.
            It's available on both eBay and Aliexpress. It's important to get the version with the little wired plug so that you can connect the wires to the Arduino easily.
            If anyone has any other thoughts: please share them!
            @alowhum said in Next generation dust sensor for MySensors:
            Dos the PMS7003 have the same interface as the PMS5003? The PMS5003 is the one that Adafruit has adopted, and they have a library for it.
            That said, there are many github libraries for the SDS011, and it can communicate over serial (or USB if using a common TTL-to-USB converter).
            My motivation in getting one of these is to measure particle emissions from my 3D printer. I'll probably build an enclosure for my 3D printer so as to contain these emissions until they can be safely exhausted or filtered.
            • alowhumA
              alowhumA
              alowhum
              I own both the SDS011 and the PMS7003. A little review:
              PMS7003
              • Three times as small as the SDS011 (!).
              • Metal housing (thin folded aluminium).
              • Can be run on batteries, as it's fan is so tiny.
              • Has 1,25mm spacing on its header, requiring some soldering to connect to Arduino.
              • Complex data output, many particle sizes output (bins), as well as raw particle counts.
              • Haven't tested 5v tolerance on the serial interface.
              SDS001
              • Huge.
              • Has an air-intake valve which you can connect at most a 1 meter hose to.
              • Plastic (with reflective coating so it looks like metal).
              • Can be directly connected with normal female Dupont wires. So you can buy it without the serial adapter an save a dollar..
              • Runs fine with power directly from nano 5v pin.
              • The serial interface is 5v tolerant (currently running it with an Arduino nano).
              • Very simple data output. The data is immediately useful.
              • Very basic control (sleep, wake up).
              • Seems to have analog data output too, but I haven't found any code using that.
              I'd recommend the SDS011 for beginners. It's more foolproof.
              I'd recommend the PMS7003 for portable projects.
              Ideally, both devices' data should be cleaned up by using the data from a moisture sensor. When there is a lot of moisture in the air, the sensor tends to see this as dust.
              I'm still looking for a bit of code that does this. Does anyone have that by any chance?
              • alowhumA alowhum
                PMS7003
                SDS001
                • Huge.
                Did you ever find code which does this?
                Also, regarding your OP, I think the Honeywell would be the best bet, since it's factory calibrated. The only regrettable thing is that it doesn't seem to measure the really tiny particles that some of the others claim to.
                • alowhumA
                  alowhumA
                  alowhum
                  Is this is the Honeywell you're talking about: HPMA115S0
                  https://www.aliexpress.com/item/PM2-5-sensor-HONEYWELL-HPMA115S0-XXX-laser-pm2-5-air-quality-detection-sensor-module-Super-dust/32829242280.html
                  From looking at the datasheet there are some other downsides:
                  • 1,25mm molex connector (so not as easy to connect to as the SDS011, which takes normal Dupont wires)
                  • Doesn't send data by itself? See this thread.
                  • Precision seems poorer than the Chinese models (although they may just be more honest?). +-15ug at levels below 100, while the Chinese sensors claim +-10 below 50.
                  • Can't find anything about it being 5v tolerant.
                  What does look good is the estimated life of the laser, 20.000 years. That's 7 years if you use it 8 hours a day.
                  • alowhumA alowhum
                    yes
                      #21
                      BTW, I hooked up the Honeywell, and this is the total amount of what it displays:
                      PS- Reading Particle Measurements...
                      PS- Sending cmd: 68 1 4 93
                      PS- Waiting for cmd resp...
                      PS- Received valid data!!!
                      PM 2.5: 3 ug/m3
                      PM 10: 4 ug/m3
                      It shows less for PM2.5 and PM10 than the PMS5003. I presume the numbers are more trustworthy, though, since it was factory calibrated.
                        subs
                        Hi. I am late here but i will ask anyways. So what is the review between PMS7003 and Honeywell HPM sensors?
                        I'd like to build a low cost opensource AQI device for Indian cities with added temperature, humidity and ambient pressure data and then send it to cloud using GPRS/GSM or Wifi (esp8266 as MCU). But i am confused about the Honeywell HPM sensor - its accuracy as compared to BAM or other PM measurement standards. Any help will be great!
                        SebexS 1 Reply Last reply
                        • S subs
                          SebexS
                          SebexS
                          Sebex
                          @NeverDie could you share your Honeywell code, I have trouble getting it to work. An example will help me a lot t learn from!
                          NeverDieN Nca78N 2 Replies Last reply
                          • SebexS Sebex
                            @Sebex Hi, I had looked into this for the purpose of testing the effectiveness of air filtration on a 3D printer enclosure. Unfortunately, for lack of effective, yet quiet, filtration at the time, I shelved the project until a future date and so didn't keep the files. However, I'm pretty sure there were libraries for the sensor on github, so I recommend you look there. Good luck!
                            • SebexS Sebex
                              @Sebex said in Next generation dust sensor for MySensors:
                              I made a library for that, I'm updating it to autodetect some various PM, CO2, Formaldehyde UART sensors but I'll find the old version for Honeywell only tomorrow if you want. If I forget, harass me by MP :D
                              skywatchS 1 Reply Last reply
                              • Nca78N Nca78
                                skywatchS
                                skywatchS
                                skywatch
                                @Nca78 Do you have any updates on the sensor you were building or the Honeywell code?
                                I am thinking of moving the existing sensor to another room and getting a new noe for the bedroom.
                                • skywatchS skywatch
                                  Hello @skywatch, I will put a library online today. Sorry for the long delay.
                                    @skywatch here you go :
                                    https://github.com/Nca78/NcaPMSensorLight
                                    @Sebex in case you're still looking for a code, you might be interested.
                                    • Nca78N Nca78
                                      skywatchS
                                      skywatchS
                                      skywatch
                                      @Nca78 Thanks :)
                                      I didn't purchase another sensor yet, but will in the furure for sure. Thanks for sharing it will help a lot of people I expect (not just me)! ;)
                                      • mfalkviddM
                                        #30
                                        https://www.bosch-sensortec.com/products/environmental-sensors/particulate-matter-sensor/bmv080/ could be the next generation. No moving parts. Measures PM2.5. Datasheet: https://www.bosch-sensortec.com/media/boschsensortec/downloads/product_flyer/bst-bmv080-fl000.pdf
