  3. HC-SR501 3.3V randomly sends tripped when radio is on
39 Posts 8 Posters 16.2k Views 8 Watching
  • B
    B
    burningstone
    @Yveaux
    I found your other post here in the forum regarding the 3AAA batteries. Could you please explain how I do this?
    Do I need to buy a battery pack for 3 batteries or is it possible do modify the battery pack I already have?
    Sorry for bothering you with this type of questions, I just recently started with this.
    • YveauxY Yveaux
      @burningstone no, just 3xAA.
      Power the arduino and radio from the first 2 only.
      YveauxY
      YveauxY
      @burningstone Here's a schematic representation of what I mean:
      0_1490118551766_upload-52d98145-abd5-4638-aec4-e113815f2474
      The red wire w.r.t. ground (black wire) will supply max. 4.5V (3xAA), the yellow one w.r.t ground will supply max. 3V.
      The load of the Arduino and nRF24 are small, so all batteries will more or less drain equally fast.
      It can easily be implemented by soldering an extra wire (the yellow one) to a 3xAA battery holder:
      0_1490118888468_upload-ff89e5ca-5fe9-49a3-93ce-f0d117426868
      Try it, and verify the output voltages with a DMM!
      • B
        B
        burningstone
        @Yveaux
        Thank you very much.
        I'll order a battery pack for 3 batteries, currently I have only a pack for 2 batteries.
        How long does it take approximately till the batteries are empty? I know that it depends on how frequent the sensor gets triggered, but maybe you can tell me some average values.
        YveauxY mfalkviddM 2 Replies Last reply
        • B burningstone
          @Yveaux
          YveauxY
          YveauxY
          @burningstone I have one next to my front door for exactly one year now, which triggers many times per day.
          Battery has only decreased from 100% to 89% ! :+1:
          • B
            B
            burningstone
            @Yveaux
            That sounds like exactly what I want :)
            Would it be possible to add a dht22 or would this interfere with the pir?
            • B burningstone
              @Yveaux
              @burningstone if you don't want to wait for the 3xAA holder you can do like this
              • B
                B
                burningstone
                @mfalkvidd
                Awesome! How do i connect the wires to the battery? Solder them or what?
                • B burningstone
                  @mfalkvidd
                  @burningstone the ugly way is to solder :) It works, but becomes a quite permanent solution.
                  I prefer using scotch tape. Or, if you have an extra 2xAA holder you can do like this (skip the fourth battery):
                  • B
                    B
                    burningstone
                    @mfalkvidd
                    And how can i tape the wire on the side of the battery holder? My battery holder package already has two wires connected like in the fritzing pictures.
                    YveauxY 1 Reply Last reply
                      Or put the wire between the battery and spring/contact
                      • B burningstone
                        @mfalkvidd
                        YveauxY
                        YveauxY
                        @burningstone tape a wire directly on the battery, or solder to the battery or the holder.
                        Look what you have lying around and be creative!
                        That's what MySensors is about!
                        B 1 Reply Last reply
                        • YveauxY Yveaux
                          B
                          B
                          burningstone
                          @Yveaux
                          Sorry I have been a long time away due to exams.
                          Now I finally have time to spend for mysensors :)
                          I tried your approach with the three batteries. My setup looks like this:
                          I modified the HC-SR501 as shown below:
                          The sketch is pretty simple, it sends the motion and the light level and then goes to sleep with interrupt for 30 minutes. I still get the false positives whenever the arduino doesn't wake up from intrerrupt.
                          What am I doing wrong?
                          YveauxY m26872M 2 Replies Last reply
                            Try adding a cap on the power of the pir sensor, start from 10uf and try to increase up to 100uf and see if it gets better
                            • B burningstone
                              @Yveaux
                              YveauxY
                              YveauxY
                              @burningstone what MySensors version are you running? I did solve an issue with waking from interrupts in 2.2 beta, that's still present in 2.1.x. This might be what's bothering you...
                              • B burningstone
                                @Yveaux
                                m26872M
                                m26872M
                                m26872
                                @burningstone You probably want to find the root cause to this but, as a quick fix, have you tried software-blocking the false trip with an additional sleep before the interrupt-activating sleep? Something like sleep(3000); before the last sleep(...). I do it with success for my mini-pirs.
                                nagelcN 1 Reply Last reply
                                • B
                                  B
                                  burningstone
                                  @Yveaux @gohan
                                  I updated the library to 2.2 and I put a 47uf cap between ground and vcc of the pir (hope that's what you mean't) and now it works.
                                  Thanks for your help!
                                  I soldered now everything onto a pcb and now the pir doesn't work. I feel like giving up, didn't think that it would be that hard for me to build one stable node. I spent almost 2 hours soldering and assembling and now it doesn't work :(
                                  dbemowskD 1 Reply Last reply
                                  • m26872M m26872
                                    nagelcN
                                    nagelcN
                                    nagelc
                                    @m26872 Thanks for this suggestion. I have had some PIR sensors that work normally and others that always trip immediately after going to sleep. It was really frustrating me. Adding the short sleep without interrupts solved this for me.
                                      the standard cheap PIR sensors are known to trigger false positives because of power fluctuations
                                      • B burningstone
                                        @Yveaux @gohan
                                        dbemowskD
                                        dbemowskD
                                        @burningstone Check connections with a continuity tester and measure your voltages coming to the arduino and PIR. When checking continuity, check directly from the jack on the PIR and/or temp sensor to the pro mini terminals, and also check pins near the connections for any possible shorts.
