  3. Binary switch not working
4 Posts 2 Posters 1.6k Views 2 Watching
  • DickD
    DickD
    Dick
    Can anybody help me out. I have a working combination node with 2 temp sens0rs, button and relais. it works fine but I needed a binary switch in it. I added the switch to the code but it will not work. I think the problem is in the "LOOP" part. I am always strugling with the {}. Perhaps somebode can take a look in the code and what I added to the working code has the comment "//radar". pls let me know.
    #include <Bounce2.h>
    #include <OneWire.h>
    // Partie Température
    unsigned long SLEEP_TIME = 900000; // Sleep time between reads (in milliseconds)
    int numSensors = 0;
    boolean metric = true;
    MyMessage msg(0, V_TEMP);
    // Partie Relay
    #define RELAY_PIN  A1  // Arduino Digital I/O pinnumber for relay
    #define BUTTON_PIN  A3   // Arduino Digital I/O pin number for button
    #define CHILD_ID 17   // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define CHILD_ID1 5  //radar
    #define BUTTON_PIN1 A5  //radar
    Bounce debouncerA3 = Bounce();
    int oldValueA3 = 0;
    bool state;
    unsigned long previousMillis = 0;
    MyMessage msg2(CHILD_ID, V_LIGHT);
    Bounce debouncerA5 = Bounce(); //radar
    int oldValueA5 = -1; //radar
    MyMessage msgA5(CHILD_ID, V_TRIPPED);
      sensors.begin();
      pinMode(BUTTON_PIN1, INPUT); //radar
      digitalWrite(BUTTON_PIN1, HIGH); //radar
      debouncerA5.attach(BUTTON_PIN1);  //radar
      debouncerA5.interval(5);  //radar
      gw.present(CHILD_ID1, S_DOOR); //radar
      gw.begin();
      gw.sendSketchInfo("Relay & Button", "1.0");
      gw.sendSketchInfo("Temperature Sensor", "1.1");
      Serial.print(numSensors);
      Serial.println(" temperature sensors detected");
      // Setup the button
      pinMode(BUTTON_PIN, INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN, HIGH);
      debouncerA3.attach(BUTTON_PIN);
      debouncerA3.interval(5);
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++)
        gw.present(i, S_TEMP);
        gw.present(CHILD_ID, S_LIGHT);
        pinMode(RELAY_PIN, OUTPUT);
        state = gw.loadState(CHILD_ID);
        digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
      gw.process();
      // Relay button
      debouncerA3.update();
      // Get the update value
      int value = debouncerA3.read();
      if (value != oldValueA3 && value == 0)
        gw.send(msg2.set(state ? false : true), true); // Send new state and request ack back
      oldValueA3 = value;
      //int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
      // gw.wait(conversionTime);
      if (currentMillis - previousMillis >= SLEEP_TIME)
        // save the last time you read temperature
        previousMillis = currentMillis;
          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
    #if COMPARE_TEMP == 1
    #else
          if (temperature != -127.00 && temperature != 85.00)
            gw.send(msg.setSensor(i).set(temperature, 1));
            lastTemperature[i] = temperature;
          debouncerA5.update();  //radar
          int value = debouncerA5.read();  //radar
          if (value != oldValueA5)   //radar
            // Send in the new value
            gw.send(msg.set(value == HIGH ? 1 : 0)); //radar
            oldValueA5 = value;  //radar
      if (message.isAck())
      if (message.type == V_LIGHT)
        // Change relay state
        state = message.getBool();
        // Store state in eeprom
        gw.saveState(CHILD_ID, state);
        // Write some debug info
        Serial.print(message.sensor);
    AWIA 1 Reply Last reply
    • DickD Dick
      int numSensors = 0;
      // Partie Relay
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValueA3 = 0;
      bool state;
        sensors.begin();
        gw.begin();
        // Setup the button
        gw.process();
        // Relay button
        oldValueA3 = value;
      #else
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @Dick You are checking the button only after the sensor is read. Put it before or after temperature reading... i.e.
      // put you button (//radar) code here
      DickD 1 Reply Last reply
      • AWIA AWI
        DickD
        DickD
        Dick
        @AWI I changed it and compiling worked good. But what I noticed that if i connect the A5 (Binary pin) to - I see no Send led on my nano. Perhaps another issue? al the other sensors are working still but only the binary switch Not.
        Any idea?
        int numSensors = 0;
        // Partie Relay
        #define RELAY_ON 1
        #define RELAY_OFF 0
        int oldValueA3 = 0;
        bool state;
          sensors.begin();
          gw.begin();
          // Setup the button
           Example on how to asynchronously check for new messages from gw
          gw.process();
            // Relay button
            oldValueA3 = value;
        #else
        • DickD Dick
          Any idea?
          int numSensors = 0;
          // Partie Relay
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValueA3 = 0;
          bool state;
            sensors.begin();
            gw.begin();
            // Setup the button
            gw.process();
              // Relay button
              oldValueA3 = value;
          #else
          AWIA
          AWIA
          AWI
          enable debug and put some print() statements in to see what happens.
