  3. MyMessage with bool value from relay state to controller (fhem)?
3 Posts 2 Posters 1.2k Views 2 Watching
  • dirkcD
    dirkcD
    dirkc
    wrote on last edited by dirkc
    I have a 4 channel relay in my node (version 2.11).
    It can be controlled by FHEM. Working fine so far :-)
    Additionally I have a RCSwitch (https://github.com/sui77/rc-switch) receiver connected to the same node to switch the same 4 channel relay via a remote control (one of those cheep 433Mhz remote controls / seems to be stupid, but is necessary as backup)
    When I receive the messages from the remote control via RCSwitch I want to send a MyMessage to the controller and front-end to visualize the status.
    send(msgRelay.setSensor(CHILD_ID_RELAY1+id).set((bool)bValue));
    The UI doesn't seem to receive these messages, instead the log shows
    MYSENSORS_DEVICE MYSENSOR_1: ignoring C_SET-message no reading-mapping for childId 1, type tripped
    I define the message like: MyMessage msgRelay(CHILD_ID_RELAY1, V_TRIPPED);
    Any idea? Thanks in advance
    Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
      are you sure v_tripped is the right type?
      dirkcD 1 Reply Last reply
        dirkcD
        dirkcD
        dirkc
        @gohan I don't know. I also tried V_STATUS, doesn't work either ...
        edit: V_STATUS works, was a wrong configuration in FHEM
