Ping Pong with ESP8266 results in !TSM:FPAR:NO REPLY [solved]
On the gateway do you see any message received? Can you post the gateway log when nodes are registering?
@gohan, when using the WemosD1 (without capacitor!) and a static ID, I get the following:
0;255;3;0;9;TSF:MSG:READ,253-253-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 0;255;3;0;9;TSF:MSG:BC 0;255;3;0;9;TSF:MSG:FPAR REQ,ID=253 0;255;3;0;9;TSF:PNG:SEND,TO=0 0;255;3;0;9;TSF:CKU:OK 0;255;3;0;9;TSF:MSG:GWL OK 0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 0;255;3;0;9;TSF:MSG:PINGED,ID=253,HP=1 0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1 0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1 0;255;3;0;9;Sending message on topic: mpp-mygateway1-out/253/255/0/0/17When I do the same for the Pro Mini, there is nothing to see. When I flash a Moteino test sketch it works properly.
@mpp the gateway is getting the message and it replies so you could either have a power issue on gateway or range problem. How far are the gw and node?
Do you have other radio modules to try? If not, if you swap the radios do you see any changes? Are the radio rfm69 right?
@gohan I have several RFM69 radio's and they're all working (with the Moteino sketch) on a Pro Mini.
Here's my config:
#define MY_RADIO_RFM69 #define MY_RFM69_FREQUENCY RF69_433MHZ #define MY_IS_RFM69HW #define MY_RF69_IRQ_PIN 4 #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN #define MY_RF69_SPI_CS 15 #define MY_RFM69_NETWORKID 99 #define MY_NODE_ID 123 -
Here's my config:
#define MY_RADIO_RFM69 #define MY_RFM69_FREQUENCY RF69_433MHZ #define MY_IS_RFM69HW #define MY_RF69_IRQ_PIN 4 #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN #define MY_RF69_SPI_CS 15 #define MY_RFM69_NETWORKID 99 #define MY_NODE_ID 123Removing some of the config lines seems to have an effect:
0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1 4 TSM:INIT 4 TSF:WUR:MS=0 8 TSM:INIT:TSP OK 10 TSF:SID:OK,ID=254 12 TSM:FPAR 143 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 1232 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0 1239 TSF:MSG:FPAR OK,ID=0,D=1 2150 TSM:FPAR:OK 2150 TSM:ID 2152 TSM:ID:OK 2154 TSM:UPL 2285 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1 2314 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0 2320 !TSF:MSG:LEN,0!=8 2435 TSF:MSG:READ,0-0-254,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2441 TSF:MSG:PONG RECV,HP=1 2443 TSM:UPL:OK 2445 TSM:READY:ID=254,PAR=0,DIS=1 2580 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100 2717 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=1,l=1,sg=0:1 2723 !TSF:MSG:LEN,0!=8 2795 TSF:MSG:READ,0-0-254,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 2936 !TSF:MSG:SEND,254-254-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=NACK:2.1.1 3076 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=NACK:0 3110 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100 3117 !TSF:MSG:LEN,0!=9 Send Sketch Info: 5197 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=3,st=OK:MockMySensors 5341 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=NACK:v0.5 MockMySensors v0.5 5480 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100 5486 !TSF:MSG:LEN,0!=9 Get Config: Metric Presenting Nodes ________________ S_DOOR 6375 TSF:MSG:SEND,254-254-0-0,s=1,c=0,t=0,pt=0,l=12,sg=0,ft=1,st=OK:Outside Door ________________ 6434 MCO:REG:REQ 6567 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2 6664 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100 6670 !TSF:MSG:LEN,0!=9 6744 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1 6750 MCO:PIM:NODE REG=1 6752 MCO:BGN:STP GW Started 7254 MCO:BGN:INIT OK,TSP=1 ######################### RandomNumber:36 Send Battery Level 7290 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:36 Request Time 7929 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=NACK: Door is: Open 8509 TSF:MSG:SEND,254-254-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1 System is: Armed 8646 !TSF:MSG:SEND,254-254-0-0,s=1,c=1,t=15,pt=1,l=1,sg=0,ft=0,st=NACK:1 8783 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=NACK:36 8792 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1 8798 !TSF:MSG:LEN,0!=8 #########################So now the node is sending data but there's no ack/Invalid message length.
@mpp said in Ping Pong with ESP8266 results in !TSM:FPAR:NO REPLY [solved]:
So now the node is sending data but there's no ack/Invalid message length..
@gohan they're all HW, yes. I tested with single wire and coil antenna's. Atm I'm testing with authentic Moteino's with single wire. They all result in !TSM:FPAR:FAIL.
Any progress on this front? I got the exact same things as the log you posted; loads of NACK's.
Checked/replaced radios, antennes and caps ..
