  3. Ping Pong with ESP8266 results in !TSM:FPAR:NO REPLY [solved]
29 Posts 3 Posters 7.5k Views 4 Watching
    The controller is needed for auto ID, but it can also be used myscontroller. It is also written in different places that manual id should be set also in case of problems.
    mppM
    mppM
    mpp
    @gohan indeed you're right. What did you mean with "myscontroller"?
    Setting the node id manually for the ping pong sketch makes them communicate to the Gateway:
    #define MY_NODE_ID 201
    Would auto ID work with the ESP MQTT Gateway and OpenHab controller?
    I have an MQTT server up and running and OpenHab is installed with the following configuration in /etc/openhab2/services/mqtt.cfg:
    broker.url=tcp://127.0.0.1:1883
    broker.clientId=OpenHab
    broker.retain=true
    broker.async=false
    Yet I still get !TSM:FPAR:NO REPLY
    MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
      https://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors
      I'd start from the ethernet gateway and work it out from there, myscontroller works with ethernet gateway. In openhab I don't know how to enable auto id, but there must be something in documentation. To be honest assigning manually ID has to be done only once because it is saved in eeprom and read at every boot, so I don't see it so mandatory to have the controller handling it.
      mppM 1 Reply Last reply
        mppM
        mppM
        mpp
        @gohan, do you mean http://www.mycontroller.org? I can't find any project page with downloads on the link you provided. There is a download link to a zip file somewhere in the comments but impossible to say if that is still up to date as it dates from 2015.
          yes, it's the zip file. It is a windows app. Mycontroller it is actually a controller like Domoticz or Openhab. I know it is a little old, but it works.
          • mppM
            mppM
            mpp
            wrote on last edited by mpp
            @gohan, I switched over to mycontroller (from OpenHab) and I'm using Arduino's nodes and I'm still getting errors not finding the parent.
            I'm using the Mock sketch and tested with setting the ID manually but no luck.
            4 TSM:INIT
            4 TSF:WUR:MS=0
            108 TSM:INIT:TSP OK
            110 TSM:INIT:STATID=99
            112 TSF:SID:OK,ID=99
            114 TSM:FPAR
            3241 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            5249 !TSM:FPAR:NO REPLY
            5251 TSM:FPAR
            8378 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            10385 !TSM:FPAR:NO REPLY
            10387 TSM:FPAR
            13514 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            15521 !TSM:FPAR:NO REPLY
            15523 TSM:FPAR
            Edit: adding a 4.7 capacitor didn't change this. Neither did downgrading to 2.0.
            Starting sensor (RRNNA-, 2.0.0)
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=254)
            TSM:FPAR
            TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            Any idea?
              On the gateway do you see any message received? Can you post the gateway log when nodes are registering?
                mppM
                mppM
                mpp
                @gohan, when using the WemosD1 (without capacitor!) and a static ID, I get the following:
                0;255;3;0;9;TSF:MSG:READ,253-253-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSF:MSG:BC
                0;255;3;0;9;TSF:MSG:FPAR REQ,ID=253
                0;255;3;0;9;TSF:PNG:SEND,TO=0
                0;255;3;0;9;TSF:CKU:OK
                0;255;3;0;9;TSF:MSG:GWL OK
                0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                0;255;3;0;9;TSF:MSG:PINGED,ID=253,HP=1
                0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
                0;255;3;0;9;Sending message on topic: mpp-mygateway1-out/253/255/0/0/17
                When I do the same for the Pro Mini, there is nothing to see. When I flash a Moteino test sketch it works properly.
                gohanG 1 Reply Last reply
                • mppM mpp
                  @mpp the gateway is getting the message and it replies so you could either have a power issue on gateway or range problem. How far are the gw and node?
                    mppM
                    mppM
                    mpp
                    @gohan tested with less than a meter up to 10 meters. In fact the Wemos Node now is working as it shows up in mycontroller but the Pro Mini doesn't receive a response from the GW.
                      wrote on last edited by gohan
                      #24
                      Do you have other radio modules to try? If not, if you swap the radios do you see any changes? Are the radio rfm69 right?
                        mppM
                        mppM
                        mpp
                        @gohan I have several RFM69 radio's and they're all working (with the Moteino sketch) on a Pro Mini.
                        Here's my config:
                        #define MY_RADIO_RFM69
                        #define MY_IS_RFM69HW
                        #define MY_RF69_IRQ_PIN 4
                        #define MY_RF69_SPI_CS 15
                        #define MY_RFM69_NETWORKID 99
                        #define MY_NODE_ID 123
                        • mppM mpp
                          Here's my config:
                          mppM
                          mppM
                          mpp
                          Removing some of the config lines seems to have an effect:
                          4 TSM:INIT
                          4 TSF:WUR:MS=0
                          8 TSM:INIT:TSP OK
                          10 TSF:SID:OK,ID=254
                          12 TSM:FPAR
                          143 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          1232 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          1239 TSF:MSG:FPAR OK,ID=0,D=1
                          2150 TSM:FPAR:OK
                          2150 TSM:ID
                          2152 TSM:ID:OK
                          2154 TSM:UPL
                          2285 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          2314 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          2320 !TSF:MSG:LEN,0!=8
                          2435 TSF:MSG:READ,0-0-254,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          2441 TSF:MSG:PONG RECV,HP=1
                          2443 TSM:UPL:OK
                          2445 TSM:READY:ID=254,PAR=0,DIS=1
                          2580 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                          2717 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=1,l=1,sg=0:1
                          2723 !TSF:MSG:LEN,0!=8
                          2795 TSF:MSG:READ,0-0-254,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          2936 !TSF:MSG:SEND,254-254-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=NACK:2.1.1
                          3076 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=NACK:0
                          3110 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100
                          3117 !TSF:MSG:LEN,0!=9
                          Send Sketch Info: 5197 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=3,st=OK:MockMySensors
                          5341 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=NACK:v0.5
                          MockMySensors v0.5
                          5480 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100
                          5486 !TSF:MSG:LEN,0!=9
                          Get Config: Metric
                          Presenting Nodes
                          ________________
                            S_DOOR
                          6375 TSF:MSG:SEND,254-254-0-0,s=1,c=0,t=0,pt=0,l=12,sg=0,ft=1,st=OK:Outside Door
                          ________________
                          6434 MCO:REG:REQ
                          6567 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                          6664 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100
                          6670 !TSF:MSG:LEN,0!=9
                          6744 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          6750 MCO:PIM:NODE REG=1
                          6752 MCO:BGN:STP
                          GW Started
                          7254 MCO:BGN:INIT OK,TSP=1
                          RandomNumber:36
                          Send Battery Level
                          7290 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:36
                          Request Time
                          7929 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
                          Door is: Open
                          8509 TSF:MSG:SEND,254-254-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                          System is: Armed
                          8646 !TSF:MSG:SEND,254-254-0-0,s=1,c=1,t=15,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          8783 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=NACK:36
                          8792 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          8798 !TSF:MSG:LEN,0!=8
                          So now the node is sending data but there's no ack/Invalid message length.
                            Are they RFM69HW? What antenna are you using on them?
                              mppM
                              mppM
                              mpp
                              @gohan they're all HW, yes. I tested with single wire and coil antenna's. Atm I'm testing with authentic Moteino's with single wire. They all result in !TSM:FPAR:FAIL.
                              • O
                                O
                                Omemanti
                                wrote on last edited by Omemanti
                                #29
                                @mpp said in Ping Pong with ESP8266 results in !TSM:FPAR:NO REPLY [solved]:
                                So now the node is sending data but there's no ack/Invalid message length..
                                Any progress on this front? I got the exact same things as the log you posted; loads of NACK's.
                                Checked/replaced radios, antennes and caps ..
